Question about Frigidaire PLES389D Electric Kitchen Range
Broiling and Baking Element Stopped working
I was cooking last week and right in the middle of cooking, the baking and broiling element wouldn't work. Door engaging button still works as convection fan turns on and stops when I open the oven door. Everythng else still works!
  • dan_pastirik Dec 10, 2008
    thanks! I will check the thermostat and wiring out!
    i tried to type this earlier, but had a technician look at it and they said it was a faulty electronic timing element that needed to be replaced. they said it was commonplace on these ranges....
    Habit-Forming:
  • 171 Answers
The thermostat is bad that's the one that turns bake and broiler elements,but before you replace anything check for power on wires connecting to the elements.
Posted on Dec 10, 2008
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
Tip
Broiling and baking element in my electric oven are not heating.
Hi.
If both broiling and baking element are not heating, then the most common fault causing the problem is a defective temperature probe.
The probe is located inside the oven cavity.
On most ovens there is only one temperature sensor, connected in series on the circuit from electroning oven control to elements. The probe will control both baking and broiling element, opening the circuit when limit temperature is reached.
When the probe fails, it will affect both baking and broiling function.
The temperature probe is tested reching the probe, cutting or disconnecting its wiring, and testing the probe at room temperature, with a multimeter set on impedance at Rx1. If the multimeter reads no continuity (circuit open), then the probe must be replaced.
If the temperature probe is good, then parts that may be responsible for the fault are oven electronic control and wiring. Having both elements failing at the same time would be rather unusual.
Regards.
on Mar 03, 2010 | Whirlpool RBS275PD Electric Single Oven
First start up
You're actually referring to the "broiler" elements. Most electric ovens have these at the top of the main oven space. (Some gas ovens are set up the same way, but many put the broiler elements in a bottom drawer.)
As their name implies, broiler elements are active only when you're broiling. They will not go on for baking.
Broiling is the process of cooking food by exposing it directly to a high heat source at close range. To broil a steak, for example, you would place the pan holding the steak on an oven rack raised to the top or next to top position in the oven (consult the manual) and set the oven to broil. The top elements will then turn on and cook the meat by direct radiation.
Most people, however, use ovens for baking far more often than for broiling. Baking is the process of cooking food (cakes, casseroles, roasts etc) by indirect heat. In other words you raise the oven to a certain temperature, put the food on a rack more in the middle of the oven, and let the surrounding heat cook it over time. When you bake the top broiler elements usually don't come on at all.
I hope this helps.
Apr 30, 2014 | KitchenAid Ovens
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
Cant get the fan oven to heat up is this a element problem or a program problem.
Hi.
If the fan assisted cooking programs are the only one not working and the oven is otherwise heating and cooking, then problems can be:
Fan motor.
Wiring harness to fan.
The relay that activates the fan. That is usually part of control module.
If instead the fan oven is not heating at all, then check if problem is with broiling, baking, or with both. If the problem affects both broiling or baking replace the temperature probe. before replacement the probe can be tested using an Ohm meter. The probe will read about 1080 Ohms at room if good.
If problem is only with one of baking/broiling functions, then test elements or valve/ignitors, depending if oven is gas or electric.
Regards.
Ginko
Sep 18, 2011 | Electrolux Ovens
Baking element broken after replacing not getting any heat from baking or broiling element, getting power cook top working, what else could be problem,
did you check the fuse
and if you know how to use multimeter then at least check voltage across the element
thanks
please rate my work
Aug 27, 2011 | Ovens
The heating element becomes red hot,but the food doesn't appear to cook in an appropriate time os fashion. Any answers or suggestions
The top of whatever food you're cooking should be in the center of the oven for the most effective cooking. Do you have the oven set on bake or broil? Broil is a direct heat method and if the food is on the lower shelf and the oven is set on broil, the food is not getting enough heat to cook it properly. Baking heats the lower element and the heat rises to surround the food. Broiling heats the top element and since heat rises, it is not getting down to the food to surround it and cook it.
Nov 04, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Oven has stopped heating up
Hi.
This oven should have two elements.
On most ovens there is only one temperature sensor, connected in line on the circuit from electroning oven control to baking and broiling element.
If only one element is failing, then the fault is probably the element. In that case you can test the element removing it from the cavity, and testing Ohms on the element. If circuit is open , then the element must be replaced.
Regards.
Mar 03, 2010 | Baumatic B180 Electric Single Oven
I have Whirlpool oven Model # RB220PXK (almost 30 years old) and the lower element sparked and stopped working. I measured the resistance of the element and it showed 1.6M ohms. Is my element bad or is...
HI. You can Expect resistance in the range of 20 to 40 ohms. Infinite or kilo-ohm resistance usually indicates a bad element and it should be replaced.
This easiest test you can do is to turn on the oven and observe the heating element. If it glows red, the element is working. When baking, the broiling element may come on to assist with preheating or to maintain the oven temperature. When set to bake, if the broiler comes on, but the baking element does not, the likely cause is a burned out baking element.
NOTE- The element may have small holes and bubbles on the coils as well. This is a sign of a burned out element. Test the element connectors as well.
Oct 12, 2009 | Ovens
My oven won't work, neither the broiling element nor the baking element. everything else works fine.
if they when bad at the same time is the thermostat, if they when bad weeks or months apart, then your elements need replacing. test the wires going to the elements first.
Dec 06, 2008 | Kitchen Ranges
Frigidaire PLES389D Electric Kitchen Range Logo
595 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
