Question about Dell AS500 Sound Bar Computer Speakers
My speakers are broken and im not sure why?
On the side of my speakers there is a knob to turn it on and of and to adjust the loundness. well when u turn them on a blue light usally come on in the center of the speakers. well its not turning on and no sound will come out of them. I checked all conections and its all pulged in right. Plz help?
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 163 Answers
U have to go to the control panel there u find the audio settings and give necessary adjustments there .
Posted on Dec 10, 2008
    Problem Solver:
  • 14 Answers
Your Motherboard has been dismantled inside your TV, most likely from being bumped, shaken, carried, or maybe just from being old and dirty. There is no possible way to fix it without the help of mechanics. If the picture does not work also, then your TV is busted. To get the speakers' motherboard repaired, I suggest you go to a proffesional Technology Shop (such as The Source) and get it repaired for around $50 - $85.
Posted on May 03, 2009
NSM Digital Thunder CD Jukebox speakers on right side do not have sound
make sure speaker wires are all pluged in. if that dont wort check the speaker wire it my be broke in between speaker and player, try new wire
Jul 16, 2012 | Audio Players & Recorders
I can't hear sound from my laptop even with the builtin speakers. It's a Toshiba Satellite A105-S4064.
On the front of the laptop there is a circular knob, play a music cd and then turn the knob from left to right and see if the sound comes back, if that doesn't work then make sure where the speaker is in the bottom right hand side of the screen click on it and make sure the volume is turned up.
If it still doesn't work then reload the sound drivers. At this point if the sound still won't work then that means that either the speakers or the motherboard is bad and you won't know for sure unless you replace the speakers first.
Nov 28, 2009 | Toshiba Satellite A105 Notebook
How do adjust the idle on 1990 gsxr 750
the idle adjustment on the oil cooled motor is in between carb 2 and 3. you have to take the right side fairing off to do so
Oct 18, 2009 | 1990 Suzuki GSX-R 750 L
Water level knob is broken
write down the brand & model of washing machine , and go to an APPLIANCE PARTS SHOP , Im sure you ll find the replacements. thanks AJ
May 08, 2009 | Washing Machines
Very LOUD 'banging' noise.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 20, 2009 | Kenmore 41042
Screen is all Shades of Red....
You need to remove the front tv panel, search for the screws right behind the screen and speaker area on the sides of tv. Should be four of them, carefully remove the lower have/quarter and you will find a control box, 6 knobs. Try adjusting them to clear the problem, each color has its own knob, be sure to mark their original position befor adjusting. When you find the red adjustment knob, you should be able to turn it down enough so that it doesnt overpower the rest of the colors. Good luck.
Jan 28, 2009 | Televison & Video
No sound
This issue could be caused by any of the below reasons.
  1. Sound card does not work
  2. Speakers are not connected properly
  3. No power to the speakers
  4. Volume on speakers turned down
  5. Volume on sound card turned down
  6. Bad hardware
  • make sure the speaker setup is correct. It is possible that during an installation of another program that the speakers software setup was changed causing issues with your sound. To do this follow the below steps.
  1. OpenControl Panel
  2. Open "Sounds and Multimedia Properties" or "Sounds and Audio Devices" in Control Panel.
  3. Click the "Audio" tab
  4. In the Audio tab click the "Advanced" button under "Sound Playback."
  5. In the Advanced Audio Properties window make sure your speaker setup is correct. If you're not sure what to set this setting as, set it to the default "Desktop Stereo Speakers" option.
  6. If you changed this setting click "Apply" and close out of all windows.
  • Ensure that the sound card works properly by connecting either another pair of speakers to the computer, or a pair of headphones.
  • the left speaker will generally have a cable that cannot be removed from it. This cable should be connected to the other speaker (generally this cable has no color or is white / gray). The next cable is the line out cable, it is generally green in color and should go from the right speaker to the line out hole in the back of your sound card.
  • Finally, the power cable generally should be connected to the back of the right speaker, or in some cases, the sub woofer. The power cable can vary; while most speakers are in the above configuration, some speakers may also not utilize a power cable connection but instead have batteries, while other speakers that connect to the side of your monitor may use a portion of the power from the monitor itself (via another type of cable).
  • Most speakers will have a small LED (light) indicating if the speaker is on. Verify that if this light is present that it is illuminated.
If no LED is seen or the speakers don't appear to be getting power, verify the power cable is properly connected to a working outlet or if your speakers use batteries that the batteries are good. Finally, most speakers can be turned on either by using a button or by moving the volume knob from left to right.
  • Verify that the volume knob on the speakers is properly turned up. If you are un-certain what direction to turn the knob, play a long sound file or CD and while the sound is being played, adjust the knob left to right or up to down.
  • The sound is also able to be turned up and down through the software installed on the computer. Verify the sound settings in the software are properly turned up.
  • Finally, if all of the above recommendations do not resolve your issue and connecting another pair of speakers or headphones to the computer does work, it is likely that the speakers are bad. It is recommended that you contact the manufacturer of the speakers or computer for a new replacement.
Jul 16, 2008 | Audio Players & Recorders
Overtightened lpf knob
it seems like the POT is going to have to be replaced if it is broken, if the LPF won't adjust when you turn the knob eighter side then it is broken.
Dec 25, 2007 | Pyle PLA4240 Car Audio Amplifier
When truning up t3h volume...
volume control knob is damaged inside ,try to put 3drops of kerosine mixed with edible oil in equal amount.care should be taken not to get it on the electronic board and adjust the knob continuously ,if this doent work u must replce the volume controll
Dec 18, 2006 | Altec Lansing VS2221 Computer Speakers
Dell AS500 Sound Bar Computer Speakers Logo
552 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
