Question about Panasonic Lumix DMC-FZ5 Digital Camera
When powered up, "Remove lens cover, press button"
No lens cover is on, you can review some past photos, but can not do anything else. Prior to this when picture was taken usually two images always appeared? Thanks.
  • 1 more comment
  • Ralstj01 Nov 19, 2007
    1. When camera is powered on, with any of the "shooting" modes selected, and with the lense cover off, the message "lense cover on" appears.
    2. Unable to progress beyond this stage.
    3. Review of pictures already on memeory card still works well.
    4. Have taken to an accredited Panasonic Service Centre, who required a $55 deposit to tell me that the camera requires a new lense unit at a cost exceeding the value of the camera (in its working state).
  • korbenn Nov 27, 2007
    When powering on the lens is not able to extend. It tries to extend, fails, and says "Please remove cover". Prior to this the I dropped the camera. Instantly after the camera worked just fine. A week later and the lense seems to be jammed. Probably a small piece of plastic is stuck inside the camera.
    I'll just have to get it to a repair shop. Or does anyone recommend trying to repair it myself? Probably not.
  • Sunfishgrl Dec 12, 2007
    Camara was left in hot car. Now when powered up "Remove lens cover, press > button" always appears in spite of having removed lens cover prior to powering or following these instructions
Gfh
Posted on Dec 01, 2007
  • 3 more comments
  • surikat Dec 01, 2007
    open these screws and take out the lens
    the take the flat cabel out
    open screws and take out sensitive element
    glue back the broken pin (it stayed iside the lens) with super glue
    finally take all the parts back
    it's not difficult,but I don't recommend to do it to people who has no experience.
    good luck
    Novelist:
  • 107 Answers
The symptom of "remove lens cover" always showing can be caused by two different things. If the lens assembly has become jammed and will not move when the camera tries to extend it - this can cause the message. On some cameras a stuck-closed shutter can cause this message as well. The symptom you describe of seeing two images prior to the failure is strange. I cannot make any kind of conclusion from that information without further elaboration. Does the lens extend when you turn the power on? If not the lens is jammed. Do you see nothing but black all the time on the screen and the captured photos? If so the shutter is stuck closed. Either of these problems will require complete disassembly and re-setting of the lens elements. Check with your manufacturer and see if they will fix it under warranty. If not, there are service providers available on the internet who can service your camera. David Millier Advance Camera Repair
Posted on Feb 28, 2007
Lens error reestart camera displayed lens stuck out
Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to auto focus while the lens is extending, hopefully seating the lens barrel guide pins in their slots. Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Thank you!
Aug 12, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
Kodak EasyShare M863 Digital Camera -Blank screen
Hi Greg, Its not on the settings., Here the thing you need to Do
Turn Off the camera, remove the memory card then Turn On the camera and go to auto mode or smart scene., now if yu see black screen check the Lens is yur lens has cover or check if the Lens protracted. Now if the Lens has no cover and protracted thats good it means theres no problem on the lens., Now press Menu Button, If the options did not display it means LCD or screen is already defective. you can also press review button.,
Please call kodak Toll Free 1 800 235 6325 and have your camera repair., GudlucK!
Nov 05, 2009 | Cameras
Viewfinder and LED display both black.
Try pressing the power ON and when the lens has retracted, remove the batteries. Wait a few minutes. Press the power ON again. Now replace the batteries and try the camera again.
Aug 20, 2009 | Nikon COOLPIX P60 Digital Camera
Lens cover stuck open. Can't take photos but can review old ones.
I have the same problem. Have you come across a solution? It's definately my lens and not my battery. Where did you go to get the lens looked at and repaired?
Jul 07, 2009 | Olympus Stylus 770 SW Digital Camera
Error message- remove lens cap and press > button
Is your lens not retracting?
I've got the same problem and with the lens not retracting - this is why i get the message.
Jul 29, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Panasonic lumix 5.0
The TZ3 has a design problem with their new automatic lens cover, ie, manual lense cap on TZ1 was illiminated on TZ3.
Make sure your lense cover is completely retracted in front of the lense. If not, nudge it fully opened and see if this solves you problem. If it does, contact Panasonic with your problem. If not under warranty, tell them you want them to fix 'their' problem on your camers. Google it on the net and see how common this problem is.
Apr 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
How to view
There are two ways to view the photos, in the camera...
1) if the camera is OFF and the lens barrier is closed, just press the Play (>) button once to view the photos.
2) If the camera is in SHOOTING mode with the lens barrier open, press the Quick View button twice in rapid succession.
When you are done reviewing the pictures, press the Quick View button once to turn the monitor off, OR, to return to the shooting mode, press the shutter button halfway.
Then use the arrow pads to go forward and backward.
Hope this helps.
Nov 24, 2007 | Olympus Camedia Stylus 300 Digital Camera
Problem in lens opening
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 28, 2007 | Kodak EasyShare C533 Digital Camera
I don't see anything in the color LCD.
If the color LCD is not illuminated when the camera power is turned on, check the following: * The camera may be in the wrong mode. Run this check to test the LCD: 1. Make sure the camera power is on (the lens cover should be open). 2. Press the Review button (top left) on the back of the camera. The LCD will display the last photo taken. To exit the Play mode, turn the camera power off. * The camera may be connected to a TV. Disconnect the camera from the TV and try the LCD again. * The batteries may be weak. Replace the batteries or use the AC adapter. To save battery power, use the optical viewfinder when composing photos.
Sep 21, 2005 | Polaroid PhotoMax PDC 640 Digital Camera
Panasonic Lumix DMC-FZ5 Digital Camera Logo
214 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
