Question about Xerox Phaser 7750DN Laser Printer
Minha maquina apresenta o erro 9-913
Portugues:
Minha maquina esta apresentando o erro 9-913, ela é uma phaser 7750 mas alem disso ela não esta fazendo a calibração da belt devido ao motor que não esta girando ela, por conta disso o fusor não aquece, ai ela fica com a mensagem no display " aquecendo aguarde" depois apresenta o erro (9-913). Como faço pra solucionar esse erro. Estou com esse problemão na mão.Por favor me ajude, obrigado.
English:
My machine is showing the error 9-913, it is a Phaser 7750 but in addition she is not doing the calibration of the belt due to the engine that is not turning it for the fuser not handle it heats up, there she is with the message in display "warming wait" then displays the error (9-913). What should I do to resolve this error. I'm having this big problem in hand. Please help me, thank you
  • 208 Answers
SOURCE: Xerox Phaser 6100 Fuser Error
Try this,
Reset Fuser Life
  1. Using the control panel buttons scroll to Maintenance, press OK.
  2. Scroll to Check Others, press OK.
  3. Scroll to Fuser, press Reset
Posted on Dec 03, 2007
  • 2072 Answers
SOURCE: Phaser 6250 "Ram error" (?)
TRY FIRST (Solutions without parts):
For a continuous RAM Error message, try cleaning RAM contacts and reseating RAM.
NOTE: Third-party or generic RAM is not covered by warranty or service contract and should be removed for troubleshooting purposes.
TROUBLESHOOTING TIPS AND HINTS:
Replace RAM. If problem is not resolved, replace the Image Processor board. Please Note:
Intermittent 6250 RAM Errors can be resolved by replacing the Print Engine Board and EEPROM, remembering to Save/ Restore in Diagnostics.
Posted on Apr 15, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 7750DN FUSER JAM
Are you getting a specific code? 10-XXX ?? That would help narrow it down.
Posted on May 06, 2008
Dadofmykids
  • 25 Answers
SOURCE: Laser Error Error message 061-370 for Xerox Phaser 6125
From the service manual:
Troubleshooting Procedure Table
Step Actions and Questions Yes No
1 Check the Laser Unit for correct
installation.
Is the Laser Unit correctly installed?
Go to step 3. Reinstall the
Laser Unit. Go
to step 2.
2 Cycle the power.
Does the error still occur?
Go to step 3. Complete.
3 Check the wiring harness connectors
P/J40, P/J41, P/J411, and P/J412
between the MCU Board and the Laser
Unit.
Are the connectors securely
connected?
Go to step 5 Reconnect the
connectors. Go
to step 4.
4 Cycle the power.
Go to step 5. Complete.
5 Replace the Laser Unit (page 8-31).
Replace the
MCU Board
(page 8-59).
Complete.
Posted on Apr 07, 2009
  • 2072 Answers
SOURCE: Fuser error code u4
You would have to replace the fuser to resolve that code.
Posted on Jan 06, 2010
Quando ligo a maquina dsm715 ela informa logo o codigo sc322. como faco para resolver?
Independente do modelo ser Dsm715 ou Dsm745 esse codigo corresponde a um erro na Unidade de Laser, mais precisamente com o sincronismo.
A primeira coisa a verificar nestes casos é se a Unidade de Laser está suja. Por vezes cai toner para o Laser e provoca estes codigos.
Se tiveres conhecimento tecnico saberás chegar á unidade de Laser. Se não tens esse conhecimento aconcelho a não mexeres (chama alguem que o saiba fazer).
Na minha opinião este deve ser o primeiro passo a dar. Deves fazer uma limpeza na Unidade de Laser.
Se não resultar replica para mim ou volta a colocar a questão no Fixya. Existem otros factores que podem provocar este codigo.
Fica bem!
Apr 25, 2011 | Gestetner DSm745 Black and White Copier
Minha cam digital Kodak aparece com código de
O problema ? que a lente se tornou presa no cano. Existem algumas solu??es DIY, voc? pode tentar, mas a probabilidade ? que voc? ter? de obt?-lo fixo por um profissional. Use estas por conta e risco, pois pode prejudicar ainda mais a c?mera:
Em primeiro lugar, tente conectar o adaptador de corrente alternada ou cabo USB.
Tente segurar o bot?o do obturador quando ligar a c?mera.
Olhe para a lente, e se alguns dos "c?rculos" a lente est? desalinhada ou n?o conc?ntrica e tente mexer-lo (mantendo lente da c?mera para baixo).
Tente gentilmente empurrando ou puxando a lente quando ela se estende, mas isso ? arriscado, pois pode causar a lente para escapar de seu sistema de orienta??o.
Outra maneira de fazer isso ? colocar a lente da c?mera sobre uma superf?cie dura e, em seguida, poder-se. Tenha certeza de usar um pano macio ou algo similar para n?o arranhar sua lente ou inv?lucro. Vamos empurrar a lente da c?mera para cima e para baixo algumas vezes e ?s vezes a resist?ncia do pequeno fornecida pela c?mera ? suficiente para fazer as coisas andarem novamente.
Tente acertar a c?mera perto da lente no corpo com o tecido mole na palma da sua m?o.
Fora isso, eu tomaria a c?mara a um centro de repara??o de uma avalia??o para ver se ele custaria mais do que a repara??o para substituir a c?mera.
Visite aqui: LENSS ERROR
Boa suerte.
Dec 31, 2010 | Kodak EasyShare V610 Digital Camera
MODELO KF 390 esta aparecendo uma tela azul escrito error fatal file: dog:UI line: 0
eu coloquei algumas musicas no meu celular e agora ele nem quer ligar.desde ontem eu nao consigo abrir a minha pasta de musicas
eu acho que ele ta com virus mas eu nao tem como scanear ele porque nao tem jeito de ligar
so aparece uma tela azul
Sep 12, 2010 | Cell Phones
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
Jul 29, 2010 | HP Designjet T610 InkJet Printer
Hp designjet 8000s 1290 error
ESSE ERRO DE SISTEMA 1290 ACONTECE QUANDO O TEMPO DE TROCA DE ALGUMAS PEçAS ESTá PERTO, GERALMENTE é A TROCA DO KIT DE LIMPEZA.
QUANDO ACONTECER ISSO BASTA FAZER O SEGUINTE:
- DESLIGUE A IMPRESSORA;
- PRESSIONE DE UMA Só VEZ O SHIFT+CANCEL E DEPOIS LIGUE;
- SETA PRA ESQUERDA+SETA PRA DIREITA+SHIFT+OK;
- Vá ATé O íTEM COUT DEPOIS OK
- OK.
- DESLIGUE.
- AO LIGAR ELA VOLTA A FUNCIONAR.
Apr 05, 2010 | HP DesignJet 9000 InkJet Printer
Have replaced the drum and toner cartridge and am getting an error message "Toner Life End". We think it may be a problem with a sensor and want to try to reset the machine. Can you tell me how to reset...
Vamos abra a maquina, retira o cartucho, do lado esquerdo tem uma alavanca preta (do lado de dentro da maquina), empurra ela e segura, vai com uma chave de fenda e fecha o sensor de tampa aberta q se localiza do lado esquerdo da parte da frente da maquina, apos vc fechar o sensor a maquina ira fazer o auto teste, e vai mostra Toner erro, coloque o cartucho novamente, delique a maquina fecha a tampa e liga novamente.
Feb 11, 2010 | Brother DCP-8065DN Black and White Copier
WHEN I TURN THE CAMERA ON, IT IS STUCK ON A BLUE SCREEN
a minha maquina não esta ligando, quando vou ligar ela aparece um codigo 5f08 e embaixo 5e02
Mar 28, 2009 | Olympus Stylus 710 Digital Camera
I need help
a minha canera quando liga fica
com a tela azul e esta escrito q
lens erro oq eu fasso
a lente nao entra mas
mas ela caiu no chao.
me ajude
Nov 04, 2007 | HP PhotoSmart M627 Digital Camera
Xerox Phaser 7750DN Laser Printer Logo
66 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
