Question about Memorex MX4100 CD Shelf System
CD won't work, says "Test"
Daughter's C/D Player won't work and says "test" in the display for about 10 sec and shuts off main power automatically. If you put the disk in ten or twenty times, it might work once. Not the disk, they all do it...
  • 2 more comments
  • tkelly2 Dec 08, 2007
    How do i get it to stop saying test and shut off?
  • Anonymous Mar 25, 2008
    My mx4100 CD shelf system has only been used maybe a dozen times. Was working fine then 1 day I went to use it and it flickers and says test on the screen and won't play radio or CD's!!!!!
  • DCizzle Apr 15, 2008
    I am having this issue as well the cd player was working fine until yesterday and now everytime I put a cd in it just says test and shuts the whole system down
  • chickdoll3 May 22, 2008
    when i try to put a cd into the stereo it says test then shuts off. how can i fix this problem?
  • 6,784 Answers
HI. this is a failing optical assembly. it must be replaced. Contact Memorex for the appropriate replacement optics assembly asap, if possible.
Posted on Aug 03, 2009
How do I run diagnostics on a Frigidaire Gallery Refrigerator
Ice Maker (Flex Tray Fresh Food Compartment)
The Ice Maker must be turned on before entering the
Service Mode. Check the 'ice off' indicator on the User
Interface to verify that the ice maker is in on.
Diagnostic Service Mode Activation
Express-Select ™
To activate the Ice Maker Service Diagnostic Mode,
press and hold fresh food and freezer up (?)
simultaneously for up to ten (10) seconds.
Pro-Select ™
To activate the Ice Maker Service Diagnostic Mode, press
and hold 'options' and 'power on-off' simultaneously for
Activation of Ice Maker Service Diagnostic Mode
automatically turns off all Ice Maker Control PCBA
outputs. The compressor runs at fixed speed of 4500
rpm and the condenser fan turns on until Service Mode
is deactivated. The damper is closed and the fresh food
and freezer lights are enabled as well as the alarm audio.
Defrost of the main system is not allowed.
Deactivation
Express-Select ™
To exit service mode, press and hold fresh food (?) for
up to 10 seconds.
Pro-Select ™
To exit service mode, press and hold the (+) key for up
to 10 seconds.
Service mode is also automatically deactivated after 5
minutes of no key entries (that includes Communication
Lost). All outputs are turned Off. Previously selected
main system and ice maker operational modes are
restored.
Testing
To actuate an ice maker load of the selected test step
(turn on or off), use 'power on-off' on the user interface.
To step to the next ice maker sequential test, press fresh
food (?) or '+' on the LCD screen. To step back to the
previous ice maker sequential test, press fresh food (?)
or '-' on the LCD screen. The selected test number will
be displayed on the fresh food display.
After pushing 'power on-off' to start automatic test
or turn on the load, the ice maker control will display
the test result on the freezer two digit display. When
waiting for the test to be automatically performed and
the result displayed, the test number (test ID) will flash
on/off. After the automatic test is completed the test
result will be displayed as "P" - pass, or "F" - Fail.
For an interactive test, the technician manually activates
the load using 'power on-off' and physically verifies the
system response. Pressing 'power on-off' again turns
the load off. The freezer display shows the current or
expected state of the load. During the load transition
the fresh food display flashes the test ID. After the last
test step in the ice maker test sequence is completed,
the next advancing action will scroll back around to the
first ice maker test. Stepping back from the first test, will
scroll the test sequence backwards to the last test in the
sequence.
Note: The only test that the test number will flash during
the test is the bail arm test.
Note: If you advance to another test before the present
test is completed the ice maker will continue to run until
the tray reaches the home position before the next test
will start.
Service Diagnostic Mode Test
Sequence
Test 52C: Ice maker Thermistor Test.
The current Thermistor temperature is displayed on
Freezer display when the test is started. It will show the
temperature at the ice maker if the thermistor is good.
A "OP" will be displayed for open and "SH" for in short
circuit condition of the ice maker thermistor.
Test 55C: Water Valve Test
NOTE: Prior to initiating this test, verify that the ice tray
is empty. If not, empty the ice tray to prevent water
from overflowing into the ice bucket. To empty the ice
tray, remove the ice bin, place catch pan under the ice
tray and initiate test 63C. The tray will twist and empty.
Touch 'power on-off' to start the test. The lower control
board will turn on the green and brown water solenoid
valves for a duration of 4.6 seconds if set for small cubes,
5.8 seconds if set for medium cubes or 7.0 seconds if set
for large cubes. Additional 'power on-off' activations are
ignored. If you want to re-run the test you will need to
advance to another test and then go back after you drain
the water out of th
Jan 16, 2017 | Refrigerators
When I turn on the mp3 it says every moment has its music and then shuts off. It won't do anything else
Welcome to Fixya
Try to drain the electrostatic charge of the board. Take out the battery then pres and hold down the power button for 15 secs. Put the battery back then test the issue.
Please click here if you need further assistance.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Oct 10, 2011 | Sony NWZ-E436F MP3 Player
I found a small part (looks like the top part of a pen) in my washer, now when i turn on the washer the goes in but does not stop, does not start the wash cycle. Also door keeps locking and unlocking.
How to run a diagnostic test:
  1. Unplug power cord, then wait 30 seconds.
  2. After plugging in, follow these instructions...
To Enter SERVICE MODE: Press Signal-Delay-5ignal-Delay (within 30 seconds of plugging in washer).
To Exit SERVICE MODE: Repeat Signal-Delay-Signal-Delay.
Here are the possible tests to run (TEST LIST). The error codes from t02 will probably be the best indicator of your problem. (scroll down to bottom to see what each command button does once you are in test mode)
  • "t01"
    Model ID
    Verifies (or sets on new board) the proper Model id
  • "t02"
    Error Codes
    Lists up to 10 control-detected problems
  • "t03"
    Software ID
    Verifies using latest Control-eePROM-lnverter software
  • "t04"
    Exercise lCD/lEDs
    Verifies that all the displays and buttons work
  • "tOS"
    Pump Test
    Tests drain-out pump
  • "t06"
    Pressure Switch Test
    Fills to all 3 levels, then pumps out water
  • "tOT'
    ThermistorlHeater Test
    Verifies that both the Thermistor and Heater work
  • "t10"
    Tumble Test
    Verifies Washer Tumbles (I.e. Wash cycle)
  • "t11"
    Spin Test
    Verifies Washer spins
  • "t12"
    Dispenser Test
    Verifies Dispenser fill works-for all four fill modes
  • "t13"
    EOl Test
    Performs End-of-Line test sequence
Button Commands (based upon test mode)
t01 prerequisites: none
Start Displays defined Model id (01-04); displays "---" if new board (to set Model id, rotate knob unlil desired id [01-04] displayed, press and hold "START' key to program desired model)
Power Returns to "t01"
t02 prerequisites: none
Start Displays most recent error code (EOO=none)
Start Displays previous error code (up to previous 10)
Hold start Clear all error codes (and then displays EOO)
Power Returns to "102"
t03 prerequisites: none
Start Alternate "cod" and Control Software version
Start Alternate "EE" and eePROM version
Start Alternale "Inv" and Inverter Software version
Power Returns to "103"
t04 prerequisites: none
Start loops on lighting lED's, LCD and cycle ids
Any button Beeps when depressed
Power Returns to "t04"
tOS prerequisites: none
Start Displays "P" and pump for 60 seconds
Power Returns to "t05"
t06 prerequisites: none
Start Displays "E" (for Empty) and starts filling when reaches Foam level-displays "F"
Start Fill, when reaches Main level-displays "nl"
Start Fill, when reaches overflow leve~ displays "OF," pumps out, displays "E" when tub empty
Power Returns to "t06"
t07 prerequisites: Main level pressure switch must work
Start Displays temperature in OF, fills to main level, turns on heater up to 5 minutes, displaying rising temperature
Power Pumps out water and returns to ''t07''
t10 prerequisites: none
Start Displays "It" and tumbles tub alternating the direction every 5 seconds
Power Stops tumbling and returns to "t10"
t11 prerequisites: none
Start Spins to 400 RPM displaying increasing RPM
Start Spins to 1100 RPM [Greater than or equal to 1000, displays "Axx"; Greater than or equal to 1100, displays "bxx" (xx, 0 to 99)] [currently error-automatically goes to 0 RPM]
Power Stops spinning and returns to "t11" when stops
t12 prerequisites: none
Start Displays "pdt" and fills via pre-wash chamber
Start Displays "ddt" and fills via main wash chamber
Start Displays "bdl" and fills via bleach chamber
Start Displays "Fdt" and fills via fabric softener chamber (stops if reaches Main level during any fill)
Power Pumps out water and returns to "t12"
t13 prerequisites: none
Start Starts EOl test sequence (NOT used in Repair)
Power Returns to ''t13''
Once you have the diagnostic codes, check this post for the meaning of the codes:
http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
Jun 25, 2011 | General Electric WCVH6800J Front Load...
No display on screen.
Hold the power switch up . . it will eventually shut down. 10 secs. works for minor hiccups, but some problems take up to 30-40 secs. to clear.
Dec 20, 2010 | SanDisk Sansa Fuze MP3 Player
Water is not pumped away, or stops in the middle of a cycle and displays one of a several error messages
Recall the error codes by activating the Automatic Diagnostic Test Mode to determine the cause of the problem. Select any one button, except Power, Start, and Stop, and follow this:
Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds>Release the button for 3 seconds>Press and hold the button for 3 seconds
All of the indicators on the console will light up for 5 seconds while 88 is displayed on the Estimated Time Remaining display. If not, repeat the step. Let us know if it cannot be activated.
The program then checks for any saved error codes after 5 seconds. List down the codes and post it back here. The console indicators will turn off then on with the 88 displayed if no error codes are recalled. After 5 seconds, the automatic test begins. The program performs a four-minute automatic test to check major washer functions. Press the same selected button in activating the automatic test above to advance through the automatic test steps.
  1. C0: The motor goes to a slow spin.
  2. C1: Warm water fills through the fresh dispenser and basket floats then disengage.
  3. C2: Cold water fills through the bleach valve for 10 seconds.
  4. C3: Hot water fills through the fabric softener valve for 10 seconds.
  5. C4: Warm water fills through the detergent valve for 10 seconds.
  6. C5: Agitates for 15 seconds.
  7. C6: Recirculates for 10 seconds.
  8. C7: Drains to engage basket and drain further for 10 seconds.
  9. C8: Drains and spins slowly.
  10. C9: Coasts to stop.
  11. Press the Stop or Power button to cancel/exit the test.
Inform us about the result of the test for the repair guide if necessary.
Feb 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
5 disc cd player does not work
Is the unit getting power? If not, remove cover and check to see if the glass bus fuse is still good. If it is good, check power from the power supply to where it connects at the main board. If no power, then the supply is bad, if there is a sufficient amount of power, then the main board or capacitor or chipset could be faulty. You can test these components with an ohmmeter
Nov 23, 2009 | Optics
Regional code for dvd player
Reagrding unlock of samsun ht-x715.
Found this
http://www.amazon.com/review/R2FMHKVOZYF6HX/ref=cm_cd_NOREF?%5Fencoding=UTF8&cdPage=&cdERR=noPurchase#CustomerDiscussionsPost
Worked for me with a small change
1. Remove disc from tray.
2. Switch off player and unplug from mains.
3. Wait 30 seconds, then reconnect mains.
4. Turn on player with remote. press the 'Repeat' on the remote for 10 sec'.
5. Press enter on remote. (There will be no on-screen response.)
6. Press 8, 4, 2, 6, 9 on the remote. (There will be no on-screen response.)
7. Press enter on the remote. Player will automatically shut off.
8. Turn player on.
9. Turn off.
10. Turn player on then off again.
11. Player is now region-free.
Dec 30, 2008 | Samsung HT-X715T Theater System
TEAC CD P1120 wont play
hi there krell
you definetly have a fault in your cd players main board best solution take to electrical shop and ask them to test all the circuits it wont cost much to get them checked out and see how you go
hope this helps and if you have the time please rate me if you dont mind
thank you
fixya
Jan 10, 2008 | Teac CD-P1120 CD Player
Memorex MX4100 CD Shelf System Logo
64 people viewed this question
Top Memorex Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Tbone41
Level 1 Expert
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
