Question about Acer Aspire 3100-1405 Notebook
My keyboard doesnt work niether my usb drives
When i turn on my computer my computer screen will appear but the key board doesnt respond to the actions i provide i wipe the operating system thinking it was that but when i tried to install a new one the key board doesnt respond if any one can help mst appreciated.
  • 3 more comments
  • arthurvigil9 Dec 09, 2008
    i tried that the usb doesnt reconize it the it at my school said the bios might have been turned off but i cant find it
    i dont get it were would the ps2 keyboard go
  • Eric Mitchell
    Eric Mitchell May 11, 2010
    There should be a port on either the side or back of the laptop
  • Eric Mitchell
    Not a usb keyboard a ps2 keyboard
  • Eric Mitchell
    try connecting an external keyboard and tell us if you can type then
  • 837 Answers
Try plugging an external keyboard in and boot up with that
Posted on Dec 09, 2008
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
Hp wireless keyboard not working
exact key board driver install then try
what keyboard model?
download load driver for keyboard
update keyboard driver
May 16, 2012 | HP Computers & Internet
WHY MY BIOSTAR G31-M7 TE mother board key board NOT WORKING ANY KEY BOARD?
Lets trace the problem here before we get to the solution. Check the keyboard on another computer to see whether the problem still exists. If the keyboard does not respond then the problem is with the keyboard. But if the keyboard works fine on another computer then the problem might be with the keyboard port of your computer. Now lets get down to the solution. If the keyboard doesnt work on both computers, firstly check the keyboard connecting pin. The pins inside it might have been bent, broken, pushed in or the pins have remained to the keyboard port on your computer. In the case of broken, bent or pushed in pins, REPLACE THE KEYBOARD WITH A NEW ONE. In the case that the pins have remained in the port of your computer, get a Computer Technician to remove the pin. If it can not be removed, then replace the keyboard with the usb one.
Dec 11, 2011 | Computers & Internet
On my Toshiba Satellite Laptop I have opened and started the computer but can't get past the sign in window because my enter key and space bar won't respond. I can type letters but can not enter...
> hardware problem or software or keyboard?
Experiment #1: turn the computer off. Connect a USB keyboard. Turn the computer on. Use that keyboard to try the 'TAB' key (to move from field-to-field). If TAB works, then try using the SPACE or ENTER keys.
Experiment #2: turn the computer off. Turn the computer on, and look for the message:
PRESS <blah> to ENTER BIOS SETUP
When you see the message, press the <blah> key. On the BIOS SETUP menus, try the ENTER key to "select" a field, to prove that the ENTER key works fine.
Experiment #3: Turn the computer off. Disconnect the AC power. Remove the battery.
Remove the disk-drive. Take the original CD/DVD disk, and start to install Windows to the disk-drive. As you work through the installation screens, you'll need to press ENTER at least once,
if only to acknowledge that installation cannot proceed, because the disk-drive is not connected.
If the ENTER key works, it works.
Experiment #4: Like #3, but connect a different, empty, disk-drive, and reinstall Windows.
If it completes, then your "original" setup has a SOFTWARE problem.
Jul 14, 2011 | Computers & Internet
I bought an emachine computer in January. 2 weeks ago the keyboard quit working. I tried another keyboard and that does not work either, what do I do.
to find the problem with key board & mother boarb Slot....? if u r key board usb port than conect another port restart the pc. key board not responding and the problem with key board. replace it
Mar 18, 2010 | E-Machines eMachines Desktop PC
Hp pavilion dv 6000 keyboard not responding.Some of the keys will not respond at all. I checked the drivers and tried to update, but says most current installed. It has been doing this for about 6 months....
You need to check in the BIOS if the keys when typed does make beeping noise. Set BIOS defaults.
If the keys are still not working than boot the sys to the recovery manager and press ctrl+d to open the CMD box and test the key board there.
Boot the sys 3 times to BIOS and set BIOS defaults,
If it doesnt work try the latest update and drivers for the sys. If it doesnt work that means the keyboard needs to be repaired
Feb 08, 2010 | HP Pavilion dv6000z Notebook
Dell Dimension 3100 e10 ...usb won't work
Does the system respond to boot keys (F2, F12) when the DELL logo appears? If so the problem is with Windows drivers and probably can be resolved by reinstalling or rolling back the drivers, but how? Do you have access to another keyboard? Does the system have PS/2 ports? Do you have access to a PS/2 keyboard or adapter? If boot keys work, you could also choose F8 for Last Known Good Config (XP) or System Restore (Vista).
Have you tried different ports (front if using back or visa-versa)?
Try using just keyboard or mouse to see if one has somehow shorted. Also check the ports for any sign of damage.
Jan 10, 2009 | Dell Dimension 3100 PC Desktop
My HP pavillion laptops keyboard is non responsive. The computer works, mouse works, but the keys wont respond. It seems to be locked on numslock the liht stays on but it doesnt respond to any keys. I dont...
i had the same prob with my sony vaio..but soon found the way out all by myself. first, run a thorough antivirus check and then reboot your comp. then reinstall your keyboard drivers. reboot your comp your comp again. your keyboard will be working. trust me..
Dec 13, 2008 | HP Internet Keyboard
Keys doesnt work
ok..... firstly check to make sure the "NUM LOCK" is off!!! if no joy get a usb keyboard and restart the pc with keyboard plugged in, hopefully if the usb controllers are enabled in the bios you will be able use the usb keyboard and enter your password, use it until you resolve the issue
Nov 14, 2008 | Acer Aspire 4520-5582 Notebook
Key board not responding
Try attaching an external keyboard to a USB port on the computer. If it works.
The keyboard cable is probably loose.
Apr 07, 2008 | Computers & Internet
Acer Aspire 3100-1405 Notebook Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
