UNLOCK RESTRICTION CODE FOR AUSTRALIA VODAFONE
Hi, You can get the restriction code for a Nokia 7230 from www.Superunlockcodes.com at low cost. Before that you can visit www.Mobileunlockguide.com this site provides free unlocking instruction guide. this would help you understand unlocking process better.
SOURCE: Nokia 6300 Australia Vodafone requesting restriction code
Handset Unlock - Instructions
Please find below the instructions to unlock your handset.
Handset Unlock Procedure for IMEI:
353508029865248
Your unlock code is:
426850229882845
Manufacturer/Model:
Nokia_6300
Nokia 6300
PHONE UNLOCK PROCEDURE
PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY
UNLOCK PROCESS
This procedure unlocks the handset from being network restricted from only
using SIM cards from Vodafone Australia. In
case of difficulties, please refer to the FAQ listed below
1.
Take note of the unlocking code shown above
2.
Insert a Non-Vodafone Australia working
SIM card.
3.
Ensure the phone is charged and then switch the phone
on.
4.
Optional
Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below)
5.
The phone will then display a message. The most common
is “Phone
Restricted”. Select
“undo” by pressing the middle
soft-key button. (Different message? See FAQ below)
6.
Carefully read step 6 before
attempting to enter the unlock code. This step has the potential to PERMANENTLY
BLOCK YOUR PHONE!
Enter into the phone #pw+ followed
by the 15-digit unlocking code then +1#
(Unlocking code is shown above). Do not
enter the 15-digit IMEI number by
mistake
To enter +
press the * (star) key two times
To enter p
press the * (star) key three times
To enter w
press the * (star) key four times
For Example: If your 15-digit unlocking code is 123456789012345, enter the following in
sequence: #pw+12456789012345+1#
(When entering the unlocking sequence it
disappears? See the FAQ below)
7.
Then press “OK”
8.
The handset will display “Phone
restriction off”
unlocked after successful entry of the unlocking code. This will be confirmed if
you can make and receive calls with the Non-Vodafone Australia
SIM card. (You will need reception and phone
credit with the different network provider)
SOURCE: unlock code for Nokia 2310 Vodafone Australia
hie frnd ur unlock code fo ur phone is 0270661772
njoy..
n dont 4get to rate this..
SOURCE: unlock code for Nokia 2730 Classic from vodafone
To unlock the mobile phone to use it with a different phone service provider you need a security code. Please click on this link and follow my instructions :-
http://www.fixya.com/support/r4049238-unlock_cell_phone
SOURCE: Unlock Restriction Code Nokia 6300 with Vodafone Australia
Find your solution from the list,
Nokia 6300
Codes:
Software & Hardware Problems
Find Your Solutions for other Nokia Phones:
Nokia N95
Nokia N73
Nokia N70
Nokia 6600
All the other Nokia Phones.
SOURCE: unlock nokia e63 vodafone australia
http://www.unlock-nokia.com/
Please find your unlocking link above.
http://cgi.ebay.com.sg/Unlock-Code-Vodafone-Australia-Nokia-E63-E71-E72-/170459562506
http://www.unlockallcellular.com/nokia-unlock-code-np-4714.html#instructions
These two links above show you how to do it, the last one is frree
