COLOR SMUDGES line (3mm) from top to bottom (intermittent) then color smudges (green) appears on large spaces of the picture. There is color detorioration when this occurs. My unit is only 3 mos. into occasional use.
  • aembautista Dec 11, 2008
    To Guru Gink?,
    My Konka is 32" LCD. Addendum:there is a line in the middle that divides the color intensity into two..Sometimes the trouble disappears after turning off and on, of the main cut-off switch.
    Thanks
    Master:
  • 416 Answers
I am not so sure but it might be a static charge
due to a static build-up on the screen (dust or something). Rubbing a wool cloth on the carpet and then across the screen will remove the charge and allow the panel to return to normal. Good Luck
Posted on Dec 11, 2008
    Genius:
  • 1,199 Answers
Have flyback replaced ! but by a pro because it holds very high voltage! this model is known for this problem!
  • 19,396 Answers
Let me know if this is a crt tv or a rear projection tv.
  • 1 more comment
  • Ginko
    Ginko Dec 11, 2008
    I think the Konka Standard is a CRT TV, in this case the problem can be some bad solder joint on the flyback transformer, or a defective CRT. It is also possible a problem on one of the boards IC, I don't think convergence, unless instead of smudge you have bands at the side of the picture.
    The first two options are more likely.
    If the TV is not a CRT, things are different, but this tv should have CRT tube.
    You will need a technician to repair this.
  • Ginko
    Ginko Dec 11, 2008
    If the unit is only three months , see if there is a number on the user manual , and if there is a phone service number call it, and complain about the fault. TV sets are normally covered vs factory falts like this, considering that the tv is 3 months old.
    See here:
    Konka provides a one-year
    warranty for all electronic products (two-year warranty for EU). For
    any product problem, we provide spare parts and technical support. "
    Contact them here and have the repair covered by Konka.
    Don't forget to leave me feedback on this.
  • Ginko
    Ginko Dec 11, 2008
    Just one more thing, Konka number is in China, better to send them an email and ask the modalities to validate the warranty in Canada.
    Give also a call to the retailer and ask, your TV has one year factory cover, and this must cover the repair expenses.
Should the T-CON board be replaced on a Samsung LN40C650 LCD TV to fix the vertical lines problem?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 08, 2015 | Samsung LN40C560 LCD TV
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Screen faults with Sony KDL46W5500
Aug 19, 2014 | Televison & Video
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Color distortion for Sony KPR-46cx35
there maybe cold solder around the chroma section, or in the CRT board....
Aug 11, 2008 | Televison & Video
Smudges on right ride of paper
want the answer to this we have a hp 2600n laser printer and its leaving smug of color on the paper the big wide roller where the page gets printed is smear with all the colors. Is there a way to clean this and what to use so we can fix the problem.
connie petrik mu email address is connie.petrik@att.net please give me a answer to this problem.
Jul 11, 2008 | HP Color LaserJet 2600n Printer
Samsung TV Model HL-R5067W
go here they are adjusting speed of the color wheel
Feb 12, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
