Question about Video Game Consoles & Games
Scrambled,multicoloured screen on startup with no menu or anything visible
Hi ,the problem was the HD lead,replaced and problem sorted,Thanks
Posted on Dec 11, 2008
Wii black screen
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
jeonatumi6
Jan 02, 2010 | Nintendo Wii Console
N70 display white please solution mee
Dear friend:
First get the lcd checked
Second connector of lcd
Third display driver crystal IC
Fourth get the smps ic power controller checked
Fifth get the line checked (lcd ic to lcd connector)
and last get the omap (cpu) checked
Nov 25, 2009 | Nokia N70 Cellular Phone
Didivox in cork area
If you box is on MMDS/Teresterial:
You should download the firmware "digivox_ter_v3300.bin" and put this on your box using downloaded10.exe (This will automatically fix your problem)
(You should be able to find the file by using Google.)
1. Connect to Internet.
2. Search for the files named above
3. Save / Download the files
4. Get the cable to connect your box to the PC.
5. Connect PC to Digivox via the serial port using an RS232
cable.
6. Turn on Digivox & then turn on PC.
7. Open loader software “DOWNLOADER 10”
8. Check settings and parameters. Defaults are usually correct.
9. Browse for bin file (digivox_ter_v3300.bin )
For all files and the downloader 10 click this link http://eko.4shared.com/ and hit digivox
and select.
10. Check “app file” (default).
11. Click “download”
12. A progress bar will appear. Wait for “download complete “ window to pop-up
13. Turn off Digivox and PC then disconnect.
Enabling Key Emulator
1. Connect Digivox to TV (usually scart), cable feed and power on.
2. Perform full auto-scan.
3. Go to “main menu”
4. Scroll down to “System Information”, press “OK” to enter System Information menu.
5. On your remote control press “ 1 0 0 4 ” (ignore what happens on the screen)
6. “Key Emu” will now be visible on the screen.
7. Change “Key Emu” to ON
8. Exit menus and return to TV mode.
9. Go to a scrambled / encrypted channel and wait for update process to complete.
10. Scrambled channels should now be unlocked.
Problems with no sound
To get back sound on e4 sky1 ect just select the channel in question press menu, select installation, select manual scan, click ok on down frequency. It'll now scan for channels when its finished exit back to normal tv viewing screen go to the end of your channel listing and the desired channel will be there with sound. This can be done on any channel with no sound by just selecting that channel following the instructions above
May 28, 2009 | Digi Televison & Video
PS3 Startup Menu Not Visible
When the ps3 is on standby, press and hold the power button for about 5 seconds. This runs the optimal screen settings page and should auto select the best setting for the cables fitted. hope this helps
Jan 29, 2009 | Sony Playstation 3 (PS3) Console
Scrambled screen
well it is a hardware problem, you might change your lcd, or the flex or the display ic
Apr 21, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Scrambled screen
Well, whatever the cause, it would seem to be software related. If you cannot boot into an earlier restore point, try booting from an XP disk. May have to do a repair on the O.S.
Also, just for fun, connect an external monitor and see if it has a screen.
Good luck
Dec 14, 2007 | Dell Inspiron 6400 Notebook
Samsung HD 32" lcd tv
Sadly there is no repair for the damaged screen and trying to replace it may be as much as buying a new one this is because the screen is one of the main components but I recommend you check with your local TV repair man some one should give you a good price keep in mind that this repair should not exceed 65% of the current value of the TV, that is already to much.
Aug 27, 2007 | Sharp Aquos LC-15B4U-s 15 in. EDTV-Ready...
Video Game Consoles & Games Logo
112 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
