follow this steps and fix it. God bless you
· Connect your Cell phone to a computer using
a USB cable. Drivers for the phone will be automatically installed when the
phone is connected. A notification message should appear in the lower-right
corner of your computer screen when the installation is completed.
· 2
Click "Start" and select "My Computer" from the menu.
Double-click the Cell icon to open its folder on the computer.
· 3
Select and open a folder on your computer in which to save the picture.
· 4
Select a picture from your phone's open folder to transfer to your computer.
Drag the picture to the folder where it is going to be saved. Continue to drag
and drop pictures in the folder until the last picture is transferred.
· 5
Exit the phone's folder on the computer and disconnect the Cell phone
from the computer.
Connect your Motorola phone to a computer using a USB cable.
Drivers for the phone will be automatically installed when the phone is
Click "Start" and select "My Computer" from the menu. Double-click the Samsung's icon to open its folder on the computer.
to your computer. Drag the picture to the folder where it is going to be
saved. Continue to drag and drop pictures in the folder until the last
5
Exit the phone's folder on the computer and disconnect the Motorola phone from the computer.
Insert the card into the card slot, go into your pictures menu and then options there should be a selection to manage my pictures (it may be different with different model phones) however it will then give you the option to save/transfer pictures to phone/card, select photos you want to save to card, then select transfer or whatever term is used and send. That should have your pictures on the card.
1.Plug one end of the USB adapter into the phone, and the other
end into an available USB port of your computer. Look to the bottom
right of the screen and you should see an "Installing Driver..." window
pop up. Wait a few minutes to allow the computer to look for a driver
for your phone 2.Look for a window to pop up that tells you "Driver
was successfully installed." If it never comes up, or instead a window
pops up that says "Driver was not successfully installed," it means your
computer did not recognize your cell phone. In this case, you'll need
to look for the driver. If it did install, skip ahead to Step 5. 3.Install the driver by double-clicking on it. Before
you do this, make sure your cell phone is unplugged. After you've
installed the driver, plug in the cell phone, and it should be
recognized 4.Go to "My
Computer." Look for a new drive that has either the brand/model of the
cell phone in the name, or simply a picture of the cell phone on the
drive. It will probably have the drive name F:, I: or G:. Double-click
on it.
5.Go to Start > File > Settings >
Folder Options and select to enable hidden files and folders to be
shown. Then go back to your cell phone's folder and look around. You
should see a folder with the name "Pictures," "Photos," "images" or a
similar name. Double-click on it, and you should see all your cell phone
images.
6.Select images and right-click "Copy."
Then go to your desktop and create a new folder by right-clicking and
selecting "New Folder." Open up this new folder, right-click and select
"Paste." Your images will then be copied from the cell phone to your
computer where you'll be able to access them any time. Take care.
Install on your computer the software that came with your digital camera.
Step 2
Connect your camera to your computer using the USB cable that came with your camera. You must have a USB port to download pictures to your computer.
Step 3
Choose the folder where you want your pictures downloaded. The computer will choose the "My Pictures" folder by default unless you want them in a different folder.
Step 4
Preview the pictures. You can delete any you don't like or want. Make sure to delete them off your camera as well or the next time you download that picture will downloaded again.
Step 5
Select a picture and print. Some software will let you put borders and cute sayings on your pictures. Have fun with it.
The LG Shine allows you to do a multiple picture DELETE - but not a multiple pic transfer to memory card, at least that I've found. You have to transfer your pics one at a time from phone memory to the SD card as follows:
Select Menu --> 8 My Stuff --> 4 Pictures Highlight the pic you want to transfer using the center toggle button, then select Options --> 5 Move (or 4 Copy) --> 2 Memory Card --> Paste
Once your pics are on the memory card then put the phone into USB mode by selecting Menu --> 9 Settings --> 7 Connection --> 2 USB Connection Mode --> 2 Mass Storage
Then attach a suitable USB cable to the phone at the charging jack and open Explorer (Windows) or Finder(Mac) and navigate to the phone. Your pictures will appear and you can copy them to your computer as needed.
NOTE: be sure to return the phone from Mass Storage mode to Data Service or your phone will not work.
Also - set your phone to highest resolution for best quality pics. Menu --> 8 My Stuff --> 7 Camera and Recordings --> 1 Take Photo --> Options --> 4 Resolution --> 1 1600x1200
you need a MMS configuratior sent to your phone so that you can enjoy picture messeges, either that or just power the phone off and back on and try it again, somethimes it's usually a bad connection only. Also in some cases when you never did a picture message before, you would have to send yourself 2 pic messages first that that would register your phone in the picture message service from your serv provider.
For your MMS configurator go to your Serv. providor web site
you can try that link. If that doesn't work here is the backdoor.
Log in to t-mobile.com Go to support. Go to services and data Go to device setup tools Go to Begin to use the T-mobile wireless configurator
send yourself the settings for the Nokia 2610. Use the settings for T-zones and MMS. When it comes in it will read "New sim 1 settings recieved" The pin is the last 4 digits of your phone number Click install Click install again Choose a profile other than a t-mobile profile Click install Click install Test
