Sanyo DP42647 Shutting off by itself.
This television is 15 months old. It is shutting off with no rhyme or reason. Sometimes it's been on for a while, sometimes not. Sometimes you can turn it back on right away, sometimes it takes 5 - 10 minutes. On some days it may happen 10 times, on other days not at all. I guess you can see what makes this problem a noodle scratcher...subwayjones
  • Bill Dec 21, 2008
    I am working on the same model- this one has no picture- green light is on- sound there, but just static- I've discovered a melting pin on a power supply connector. connector CN2 -ribbon cable power to main board. one of the 12v pins has overheated & is turning brown. this points toward the main board or an inadequate wire size. -- this is only a starting point- it has not fixed this one yet. good luck
savenabuck
SOURCE: Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Posted on Dec 27, 2007
  • 1153 Answers
SOURCE: Mitsubishi VS-50707 shuts down sporadically
you can do a self-diagnosis test by pressing the menu and input/device button on set for 5 sec and see what error code it gives you. Count the blinks followed by a short pause then more blinks. This is the error code.
Posted on Mar 10, 2008
SOURCE: television shuts itself off
i had the same problem with my set shutting off and was told it may be the ballast so i changed that but it still would start up and shut down after a few mins, then i was asked if the bulb had been changed and i had not, so i did change the bulb and have not had it shut down yet. :) (so try a new bulb)
Posted on Jul 17, 2009
SOURCE: LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Posted on Aug 15, 2009
Ecollier2012
  • 3459 Answers
SOURCE: Our Phillips 50P8341 50 in. Rear Projections
Any chirping sounds from the TV?
Posted on Dec 25, 2009
What is the part # for the power supply for sanyo model# dp42647?
There are 2 different Supplies
1 is 1AV4U20C17400
and the other is
1AV4U20C10000
They are relatively cheap
see: http://www.shopjimmy.com/catalogsearch/result/?q=dp42647
for better details
Jan 09, 2011 | Sanyo Televison & Video
Sanyo dp42647 picture is black but has good sound worked great yesturday
sanyo lcd dp42647 turns on and has sound no picture black screen
Dec 27, 2009 | Sanyo 42 in. LCD TV
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
Tv shuts itself off
pls check the a.c. cord is good,then check fuse of the unit if deffective need to replace it and check the horizontal output if is good or not.
Jan 11, 2009 | Sanyo DS27510 27" TV
Viore DLP TV keeps shutting itself off
contact lg at 800-423-000. they may cover the repair. They might charge you a small trip fee and cover the part. sounds like the pwr supply is shutting down.
Dec 06, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
