Question about Ovens
Nut is not tightening on the fan hotpoint oven
Took fan off to clean but the nut is not tightening up when put back on, it is a hotpoint single oven. the fan inside oven at the back.
  • Ovens Master
  • 3,463 Answers
It is a left hand thread, so you fasten it as though you were normally unscrewing it.
If it still does not tighten then you have a stripped thread on the nut or the fan spindle.
Plz leave feedback.
Posted on Dec 09, 2008
The main oven fan in Hotpoint BD32B is sticking (tries to rotate but goes slow and stops). I need to either re-lubricate the existing fan or replace it. How do I remove the fan?
Remove the cover at the rear of the oven compartment, then holding the fan blade with one hand, undo the nut holding the fan on, it is a left hand thread, so turn the nut clockwise as though you were tightening it.
To remove the motor itself you will have to undo 3 screws securing the fan motor from inside the oven compartment, then remove the outer rear cover of oven to remove the motor.
May 10, 2011 | Ovens
How hard is it to change the fan? thanks
reasonablly easy allow yourself some time remove oven from housing remove back panel to expose fan motor remove internal back panel to gain access to fan blade undo nut,{it will be tight and is left hand thread e,g tighten to undo} pull of blade turn to back of oven undo three fixing screws that hold motor to back panel detach 2 wires pull off motor reverse to refit.
May 17, 2010 | Neff B1421 Electric Single Oven
Hotpoint sy36x grill element works fine but when switched on to oven it doesnt heat up, fan working.
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
richard saupe
appliance repairman
Mar 14, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Replace fan motor in an electric fan oven
For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 13, 2010 | Neff B1421 Electric Single Oven
Bosch oven loud fan noise
Nov 26, 2009 | Bosch HBL 445 Stainless Steel Electric...
Kitchenaid convection oven fan rattles/noisey
Sometimes the fan blade mounting nut gets loose. Remove the cover from the fan and see if the blade wobbles. If so,tighten the nut on the fan motor.
Jul 27, 2009 | Moffat Half Size Electric Convection Oven...
Fan not working
Hi, its likely that the fan motor isn't working. (most times is just build up of grease) If you're good with DIY, remove the inside panel that covers the element and the fan, undo he nut CLOCKWISE, pull the oven out, remove the the back cover, remove wiring from fan motor, clean the motor with WD40, and give it a few turns to see if turns freely. Reserve the process.
Feb 07, 2009 | Zanussi ZBF360 Electric Single Oven
How to remove a fan/motor from a Zanussi oven
You are probably trying to undo the nut the wrong way.
It is a left hand thread, so to undo it, you go clockwise, as though you were trying to tighten it, and vice versa to tighten it up again. If you can't unscrew the nut, you will have to grip the fan spindle with something whilst you undo the nut.
Plz rate my solution.
Jan 22, 2009 | Zanussi ZHQ575 Electric Double Oven
Changing Smeg SA280X/1 fan motor, shaft nut stuck?
Most fan blades are held on by a single nut, which is usualy a left hand thread, so to unscrew it you turn it clockwise as though you are tightening it up.and to tighten it,anticlockwise..
If the spindle turns, then you will have to hold it with a pair of grips or similar.
Jan 10, 2009 | Smeg SE280X Stainless Steel Electric...
Ovens Logo
59 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
