Question about IBM ThinkPad 600E 2645 Notebook
Ibm thinkpad 2645 600e
Oh hi sorry yeah i just wanted to know how to reformat the hardrive on the laptop and reinstall the software back it is running on windows xp prof and i have my own software. and it still has the owner informations stuff on it too thanx.
  • 395 Answers
If you got a windows xp cd then boot from it and format the drive then reinstall xp
Posted on Dec 09, 2008
Had to reformat my windows xp professional on my thinkpad 40 2722. Works beautifully- a clean restart but lost my drivers and cannot get to internet. How do I get the needed drivers back?
If your laptop comes with a driver CD, you can use that to install the needed drivers. If not, you might need to use another computer and go to IBM Thinkpad support website and download the drivers from there. Save it on a USB thumb drive and use that to install the drivers to your Thinkpad.
Go here for the IBM Support Website
Hope this helps.
Sep 08, 2011 | IBM ThinkPad R40 2722 Notebook
My laptop had been working fine, then the last
Hi yes try this, if no joy come back to me.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To install new version of XP. Insert XP CD into drive, reboot pc pressing ESC button, or delete in some machines. This takes you into BIOS, change your primary boot device to CDrom, save changes and reboot. Select boot from CD once this appears and wait for files to be installed. Select the part of the hard drive you wish to use for your operating system (usually the largest) and select partition this drive. Delete any previous os, and reformat hard drive. (Be aware this removes everything saved on your hard drive, so always back up first) Re boot afterwards and reinstall operating system.
Jul 10, 2010 | IBM ThinkPad A30 Notebook
Have reformatted the thinkpad t43 with windows xp. wireless adapter not visible in hardware devices. Help!
have you installed all the device driver for the hardware of the notebook? if not run all the device software including the driver for the wireless adapter, it will not appear if it is not windows compliant you have to provide the drivers
Nov 24, 2009 | IBM ThinkPad T43 Notebook
Dos mode
to reformat, you have to boot from another source like a CD. you can't reformat a drive while it's being used, so get yourself an operating system disc and you can reformat/reinstall.
Jan 17, 2009 | IBM ThinkPad T21 Notebook
Hard drive for ibm t23 /t30 are they interchangable?
Yes you can, the manual says they borh using 2,5 inch ide HDD'
Here is the manual to t23
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/62p9631.pdf
And here is the manual for t30
ftp://ftp.software.ibm.com/pc/pccbbs/mobiles_pdf/92p1840.pdf
Good luck to you
If you find my answer helpfull, dont forget to vote!
Dec 18, 2008 | IBM ThinkPad T23 2647 Notebook
Ibm restore to factory setting
You have not explained what is wrong with your computer.
Is the laptop working, does it boot up into Windows?
What are you trying to restore?
Are you trying to get into a previous Restore Point?
The Access button takes you into the BIOS, you can change the BIOS settings back to the Default settings (ie the factory default settings).
It is difficult to offer a solution without knowing the exact nature of the problem.
Nov 23, 2008 | IBM ThinkPad R50e Notebook
Ethernet driver does not work for IBM Thinkpad A20m
hi good day to you I have problem in my laptop thinkpad A20m PIII 700mhz 256 ram running in widows XP,, and everytime I install the driver of Lan the massage appear error in code 10, and the lan is not working,,can you help me in this problem?
Jan 12, 2008 | IBM ThinkPad A20M Notebook
T41 IBM thinkpad monitor goes off
Saw exactly the same think on another t41 i was trying to fix. If it was moved at all screen went off.
Turned out it was corrosion on the motherboard that was causing the problem.
Has it been liquid damaged or got damp in the past?
Jan 07, 2008 | IBM ThinkPad T41 Notebook
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
128 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
