Question about Epson Stylus CX4200 All-In-One InkJet Printer
Can't get my Epson CX4200 to print
As above the icon shows a red dot with and exclamation point in it....when I try to print nothing happens and flashes printing stopped ????
  • dlorahj Dec 09, 2008
    Will wait the 1/2 hour and let you know if it solves the problem....Thanks
    Sergeant:
  • 399 Answers
Either the paper is missing on not inserted properly or the cartridges are not installed properly or the cartridges r near to empty please replace the cartridges to avoid this red dot error.
Posted on Dec 09, 2008
    Genius:
  • 1,550 Answers
Try hard reset .
Unplug your printer from power chord for 30 minutes and plug back the power chord to the printer .
This will reset your printer .
I have windows vista. epson stylus cx4200 will print but does not scan. installed windows 7 64 bit drivers but not successful. need help. thanks
Download & install the "Epson Stylus CX4200 All-in-One Printer" @ Drivers and Utilities Combo Package
Windows 7 64-bit compatible, Windows Vista 64-bit
epson13071.exe - 20.9MB
- posted on 07/07/09
This file contains everything you need to use your Epson Stylus CX4200 with Windows Vista 64-bit.
This package consists of the following items:
•Printer Driver v6.5
•Scanner Driver v3.04
•Epson Status Monitor 3
•Epson EasyPrint v3.10
Uninstall your previously installed AIO drivers before installing the downloaded installer.
Hope it helps.
Jun 02, 2011 | Epson Stylus CX4200 All-In-One InkJet...
MY EPSOM CX 5500 WILL NOT PRINT. i HAVE A RED LIGHT PERM ON BY THE INK ICON. i HAVE TAKEN OUT THE CARTRIDGES SEVERAL TIMES AND RESTARTED BUT NOTHING HAPPENS. tHE CARTRIDGES HAVE INK AS FAR AS i...
Hello, This happens with epson as it has a chip on the cartridge, which sometimes shows the cartridge empty even if there is some ink left on it. You can try this steps:- 1. With the printer turned on press the ink replace button, which will bring the print head to ink replacement position, pull out the cartridges one by one and cover the tip of the cartridge with some tape and shake the cartridges and reinsert it on the printer and press the ink replacement button once again, the printer will check the inks cartridges, if the inks is empty it will show the red light again, pressing the button once will bring the printer to ink replacement position with the cartridge to be replaced on the replacement position. you can also check on the printer software on the pc that which ink cartridge is emptied.
Hope this helps.
May 14, 2011 | Epson CX4400/CX5600
My Epson CX4200 is printing pink pictures - help!
try printing the nozzle check page.. you will be able to see which color that is missing... it should have Yellow , Megenta, Cyan and Black... if any one of the color is missing.. try performing head cleaning and after twice cleaning and still no improvement, very high possibility your print head is clogged..
May 20, 2010 | Office Equipment & Supplies
Prints nothing but ink still gets lower
You cartridge might be leaking somewhere from any point, please check for this.
Regards,
KK
Oct 30, 2009 | Epson CX4200 All-In-One PSC Printer
Problem printing from my acer aspire one
Can you provide a little more information. Is the printer green power light on but neither of the red lights. Does the printer just sit there doing nothing, or does it go through the motions of printing and produce a blank sheet. If it does nothing, can you check the print queue (double click the printer icon). If there are a mass of jobs waiting (all the times you've attempted to print something), right click and select cancel all jobs. When the print list is clear, right click the printer icon and select properties. Now click on test print. If nothing happens as before, cancel this job also. Then go to control panel and uninstall the Epson printer software (the "driver"). Reboot and reinstall the printer driver. Report back if it's still not behaving.
Jan 21, 2009 | Epson Stylus C66 Inkjet Printer
Epson stylus cx4200
sMErk sMErk sMErk SMerk SMerk SMerk...510 bay area bizznezz.
Aug 07, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Color printing problem for Epson CX4200
try this :
Please confirm that the head cleanings were done using the most effective method listed below.
1) Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
Dec 29, 2007 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus CX4200 All-In-One InkJet Printer Logo
81 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
