Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Intuitive eco washing Machine says power cut and lights continually flash
The lights are flashing, it says power cut on the machine. After pressing the start button it says restating in 10 secs. It doesnt I turned it off at the wall it made no difference
  • pat the brat May 15, 2013
    Totally right. I blew on the clear tube and it's working fine!
    New Friend:
Here is how I fixed mine using the knowledge of years of fixing things.
I grabbed the machine from the top with both hands and shook it off the floor very hard with a good thump X 2
I went to university for longtime to know this is how to fix it;
The circuit boards and sensors are not bad. It just after years of bumpy spin cycles there is a loose connection. This will shake the troublesome connection into a new position where it makes better contact.
It's temporary.
One day you'll have to open it and check all the connections are tight and clean.
Posted on Aug 14, 2016
I went one step further than Simon Dyer and took the back off controller and unplugged and plugged in the connector to the display. Works every time for me. This has been an ongoing issue for mine for years. Tech fixed it this way first time and worked for years after. Now it's a semi yearly occurrence.
Posted on Oct 12, 2016
  • Fisher and P... Expert
  • 555 Answers
Both control boards need to be repaired.
As motor control board has power supply problems,
The display board has bad capacitors.
Posted on Jan 02, 2014
4 Suggested Answers
SOURCE:
caroldon
  • 17130 Answers
SOURCE: my washing machine Fisher&pykel/ intuitive eco
It is possible that the machine does not start off the cycle because there are errors or feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven from the flow into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Posted on Aug 09, 2011
  • 251 Answers
SOURCE: My Fisher & Paykel intuitive
Hi - this is a strange one - I could be wrong here but I think that theres two likely possibilities for you - first is the motor controller board could be faulty - it may have a short on the switch ic for the drain pump - the other is there maybe an air lock or blockage to the pressure tube - remove the display panel to access the clear tube - unclip it & blow into towards the bowl to see if theres a blockage.
You say as soon as the start switch is pushed the pump runs continously? or does it come on as soon as the power button is pushed? either way I think the controller maybe faulty - haven't come across aything like this one before...
Cheers
Posted on Aug 25, 2011
  • 72 Answers
SOURCE: washing machine keeps beeping then all lights and screen start flashing.
i would guess that you have a faulty main board, the quickest and surest way to determine the problem and that is to replace it with a second hand board out of an known old machine which has faulty seals.
Posted on Dec 12, 2011
I have a Fisher and Paykel IW811 Intuitive Eco washing machine on which I have recently replaced the pump motor and motor control board. I have reset the size for 650mm.
Switch power off at wall & unplug machine for a couple of minutes. Plug it back in and power on. See if it resets it, If not then you may have a faulty main board or it has been damaged somehow during fitting.
Jan 09, 2017 | Fisher and Paykel Washing Machines
Model gw 712. Why are lights 3, 5, 7, and 8 flashing?
Hotpoint, GE, RCA Washer Repair - Does not spin or drain ...
? 6:13
https://www.youtube.com/watch?v=69az-ZA3eSQ
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Hotpoint, GE, RCA Washer Repair - Does not spin or drain - VWSR4150DAWW ... Fisher & Paykel ... my washer won't drainnor spin. what is the problem? .... But in the end, this video helped me fix our washing machine.
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesHow do I remove the lid on a F&P intuitive eco washing machine to get to the motor panel?? IMadeIt ... It runs until the spin cycle and it drains but won't spin.
Dec 18, 2015 | Fisher and Paykel Washing Machines
The descaling light and water drop is constant flashing preventing machine from working, what to do?
Did you check if your hot water know was fully closed
Try turn off the machine, press the water drop button and turn on the machine . Keep pressing for 20 sec.
You may attached a recording video if problem not resolved
Good luck
Nov 12, 2014 | Saeco Odea Giro Plus Coffee Maker
Eco intuitive error 40
Your machine cannot detect correct water level
The clear pressure tube has come off or got a hole in it somewhere.
Mar 21, 2014 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive Iw509nw fault code 9 what's it mean
the size of the machine needs to be set. if you recently replaced a board the first thing you need to do is 'size set' the machine and instructions should come with the board. holding wash temp up/down and pressing power should get you into the menu, though it's too much to explain here.
Aug 16, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel Intuitive Eco led lights are flashing by chance the start screen might come up when i start the cycle the water runs into machine for about 3 seconds then it shuts of and the bowl st
The display screen clicks in.
Use a flat blade screwdriver to unclip the display.
Two low profile electrolytic capacitors need to be replaced,
Is a common problem in IW LCD display boards.
Mar 13, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
I did try: change fuse as first it was without any lights. Then checked sockets. It started again by itself. Then I reprogram it-switch off-turn on 90'C-press start button- switch on- keep pressing f
Try this reset, it may work:
-Turn Off power switch
-Select 90 degree washing
-Press and hold Start
-Turn ON power switch and keep pressed Start button 10 sec
-Depress Start button
-Turn Off power switch and turn On again and thats it...
Credit to original poster :)
Oct 19, 2012 | Washing Machines
Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Aug 06, 2012 | Fisher and Paykel Washing Machines
When I first started using this modem, it worked great and easily worked well with my Belkin router. One day when I came home, the modem was only flashing the "power" light was flashing and I had...
Flashing power light on Router is sign of hardware failure As mentioned, you have already reset the router
You can try to hard reset the router one more time
Follow this procedure
1. Press the reset button with some paper clip 2. Wait for 10 Secs 3. Turn of Power to the router (While Reset button is still pressed) 4. Wait for 10 secs 5. Power on router 6. Wait for 10 secs and then release the Reset button
While doing this make sure reset button is pressed continuously start from Step 1 - 6
Check if Power light still blinks
If No - you can setup router like before and it will work If yes - Buy a new router or get it replaced if under warranty
Jun 29, 2011 | Arris SURFboard SB5101 Cable Modem
Washing Machines Logo
1,955 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
