Question about RCA RS2600 CD Shelf System
ERROR, NO DISK
I have experienced this both with my citizen dvd player and my RCA RS2600 5-disc changer. I turn on the unit, insert the cd/dvds and then close the tray. The unit appears to work, says reading, then stops working and says error - no disc. Then, when i try to open the tray, the tray won't open and my cds/dvds are stuck inside until someone takes it apart to get them out. I would just go buy a new one of each since they were relatively cheap but i really like both of them and would much rather fix them instead. I don't want to pay to fix them though, it would make more sense to buy a new one. Any suggestions? I just read another problem similar to mine in which the solution was to take it apart and clean the lens. I will try this, but in the meantime if anyone has any better ideas/ solutions, please respond! thank you :)
  • 1 more comment
  • mykeylykey May 18, 2008
    I seem to have the same problem when putting 3 disks in the changer it reconizes no disks. But it now has happened to 2 shelf units and they are pretty much new units. Is this a common problem with shelf units that the changers go out this fast.
  • Anonymous May 17, 2009
    I just bought mine yesterday and it had never been used but it was old, yet sill in its original package. I hooked it up when i got home and put 5 NEW CD's on the turntable and I pressed closed and all it kept doing was reading the CD's but not playing then and as soon as it was done with one it would go to the next, then i took it apart and cleaned the laser and it worked, but when i tryed to change the CD it would do the same thing it did before i cleaned it..and now I just caint get it to work no matter how much i clean it.
  • Anonymous May 24, 2009
    Me, I don't want to read the tune 14 and over on a compact disc
    President:
  • 3,130 Answers
No if the cleaning does not work, you will need to have the unit hooked up to test equipment to check if the laser is bad. It could also be a bad spindle motor if the unit will not spin. good Luck
Posted on Mar 16, 2007
05 Chrysler DVD lights flash sequentsially,unit whirs, stuck disc(s)? Won't eject whatever.
IF YOU HANDY IT IS AN EASY FIX, I DID FIX MY. LOOKS LIKE YOU OR SOME FORCED A DISK IN TO THE CD HOLDERS.
1- I DID TAKE OUT THE CD CHANGER FROM THE CAR,
2-OPEN THE TOP CASING OF THE CD CHANGER,NOW YOU CAN SEE THE CDS AND THE HOLDERS WHICH SAPARATES THE CDS,IT IS VERY LIGHT TIN OR ALLUMINIUM PLATES, USSUALLY ONE OF THEM IS BENT THAT IS THE PROBLEM STRAITEN AND PUT IT BACK. FIX YA AND SAVE 500 BUCKS.
Jun 01, 2014 | 2005 Chrysler Pacifica
Hi I have put a cd into the changer but now cannot eject the cd, the stereo reads error 99 please advise
The CD, when inserted, became either wedged or not seated properly and the sensors dont know how to respond. Here are the codes for Kenwood.
Changer Error Codes
• E-00: Poor Cable connection.
• E-01: Magazine not properly set in changer.
• E-02: No Disc in magazine.
• E-03: CD does not have selected track number.
• E-04: Disc is dirty, upside down or unreadable.
• E-10: No data is recorded on the MD. The player plays the next disc automatically.
• E-99: Changer malfunction, disc may be caught in machine or changer requires service.
If you have a steady hand... carfully unscrew and open up the unit just far enough so you can either pull, or nudge the CD tray enough for the CD to be seated in the tray properly...
Good luck...
Nov 20, 2012 | Televison & Video
Technics 60 cd changer cannot see disk in changer
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The most common reason for the CD Changer not reading discs is a bad drive. The following website sells the drives and does installs:
http://store.richspsxparts.com/wiiredvddr.html
This drive should fix any reading issues you are having with your disc, or issues inserting your disc or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your CD Changer.
Hope this will help...
May 26, 2010 | Technics SL-MC70 60-Disc CD Changer
I bought a RCA 5 DVD Disk Changer last Christmas.
my suggestion (not necessarily solution) is cleaning.
Although it can take multiple DVD's there is only one reader inside of it.
Do you have small children?? :-)
May 13, 2010 | RCA RP8065 5-Disc CD Changer
Clean the inside of a 5 disk dvd/cd changer
If you go to your local electronics store or even Walmart LOL.. you can get a CD/DVD lens cleaner. it looks like a CD with a little brush attached to it. EASY AS PIE..
that is IF it is the lens.
BTW.. I am a DJ so I have had my share of drama with CD players
Hope this helps you.. I am new to this site
Happy Fixing =)
Jul 12, 2009 | Panasonic SCAK410 5-Disc CD Changer
I have a 2004 ext cadi and bought a 6 changer cd player. when I place a cd in it shows no disk what gives? radio works, changer light up
hi, hate to be the bringer of bad news but, it seems to be a dead lens you are experiencing. The no disk error basically means that the lens sensor isn't active and it responds as if the disk was not inserted even if it is. replacing the lens will fix this issue.
Mar 07, 2009 | HP LightScribe dvd640i (DVD640I)...
Magnavox DVD Video Player DVD609AT
DVD609AT:
The manual is available at Philips website, the number for more info in manual is out-of-date; the new number is 1-800-605-8610
This unit has a problem when playing dual-layer discs of some kinds - read the warnings on the Magnavox website - playing the wrong kind of disc will cause an error that will require svc/repalcement to fix
Playable Discs
This DVD Player will play Digital Video Discs (DVDs) and Audio CDs. In order to play a
DVD or Audio CD on this DVD Player, make sure the Disc meets the requirements for
Region Codes and Color Systems as described on this page. Also, the Discs should have
the following logos and should meet these standards.
• CD-ROM
• Compact Disc-Interactive
(CD-I)
• Compact Disc-Recordable
(CD-R)
• Digital Video Disc-Video
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Super Audio CD (SACD)
• Photo CD
• Video CD
• Video Single Disc (VSD)
Digital
Video
Disc
12 cm
12 cm
Approx. 4 hours
(single-sided)
Approx. 8 hours
(double-sided)
Approx. 80 minutes
(single-sided)
Approx. 160 minutes
(double-sided)
20 minutes
8 cm
8 cm
(singles)
Logo
Maximum
Disc Type Contents Playback Time
Sound
and
Pictures
Audio
CD
Disc Size
Sound
74 minutes
Disc
Segments
DVDs are
divided into Titles,
which are divided
into Chapters.
Titles and Chapters
are numbered.
Audio CDs are divided
into numbered Tracks, i.e.,
a track may be one song.
Unacceptable Discs
If you insert an unacceptable type of disc, “Please insert a playable disc” will appear on
the TV screen. Also, “- - - - - “ will appear on the DVD Player display panel. Insert a
DVD or Audio CD. The following Discs will not play on this DVD Player.
• CD-ROM
(CD-I)
(CD-R)
Recordable (DVD-VR)
• DVD-RAM
• DVD-ROM
• Photo CD
• Video CD
May 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Cd player on RCA R52653
overheating or lens dirty in unit buy lens cleaner cd to clean it
Jan 27, 2008 | RCA 100-Watt Stereo System With 5-CD...
DVD not playing
here is the link to the user manual, troubleshooting and venturer support contact details; http://www.1800customersupport.com/products.aspx?view=93&p=43&sc=5&sn=Portable%20DVD%20Players&pn=DVD%20Players%20and%20Recorders Hope this helps, please post again if not :)
Jan 30, 2007 | Venturer PVS177W Portable DVD Player
RCA RS2600 CD Shelf System Logo
384 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
