Are you saying that you do not know where on your computer to put the photos from your G1 or are you saying that you do not know where to find the photos that are on your G1? The G1 keeps it's photos in the \dcim folder.
Same Problem
Apr 03, 2009
-   i had pictures on my old phone and i put them on my sd card but the g1 says no pictures found. -   Guest
Mar 27, 2009
-   mine does the same thing what the heck?-   Guest
Feb 19, 2009
-   do you need a memory card to store pictures off the computer on the g1? if not how do you put them on?-   Beks09
This is how I did it. I am using Windows Vista so it maybe different for other OSs.
Find and select the picture(s) on your pc, copy them using CTRL-c.
Plugin your g1, and if you have installed the drivers, you need to goto your g1 and hold the USB icon on the top of the screen for a couple seconds. It should expand downwards, then pull it down. open the USB connected by toucing it. Touch the "Mount" button on the screen.
Autoplay dialog box should open on your pc, select "open folder to view files". open "dcim" folder. Paste the pictures in that folder.
NOTE: You will not be able to access the sdcard from the g1 until you unplug the USB after you're done.
Once all the pictures are uploaded into the sdcard, goto "My Computer" on your pc, rightclick the sdcard drive(it should be named like "Removable Drive" or something, and select "eject".
Now remove the USB cable, Select "Pictures" icon in you apps, if needed select "dcim" folder, and touch the pictures.
Siimilar can be done with music, just changing the instruction to "My Music" on your pc and also opening "Music" icon on your g1.
my g1 phone screen cracked a while ago...it worked ok for a while then the screen got kinda fuzzy...
(More)
my g1 phone screen cracked a while ago...it worked ok for a while then the screen got kinda fuzzy and went out i really need the answer because this is my only source of communication
