Question about HP iPAQ H2210 Pocket PC
The Screen is back and it won't charge
I charged my pc pocket yesterday and when I tried to power it on it didn't. I'm trying to charge it but its not working. I tried to reset it but it shows the HP logo with the white background like for 2 seconds and it turns off again. Please someone help me!
  • 1 more comment
  • brenda tumaster
    brenda tumaster Feb 28, 2007
    That's what I did. when I'm in the last step, I hit the reset button and the screen with the HP logo and the white background appears and after 1 second it turns off. I have tried repeating the same process once and again.
  • brenda tumaster
    I'm using a wall adaptor but when I connect it it's not lighting or showing any change. My Ipaq is a 2200.
  • brenda tumaster
    brenda tumaster Mar 01, 2007
    Thank You. the only problem is that I don't have a USB cable. I left my PDA charging all night, even when the light wasnt on, and it didn't wotk either
    Novelist:
  • 198 Answers
Hello, it isn't that simple as a broken charger. Try the following thing. Connect battery to the PDA, check that the battery LID is connected FIRMLY to the body (there is a contact there that woun't allow the PDA to start if the lid isn't connected properly, you may want to check it too, look carefully for a small black thing and check that it can be pressed). Then connect the pda for half hour to the charger, even if no light or amber led is flashing. Then make a master reset as showed here and connect the PDA to a usb sync cable with your computer. Press simultaneous the soft reset and the power button, then press only the soft reset button. The PDA should start. If not, there is a problem with a DC converter component on the mainboard or the connector I was talking about before. Even if the charger is broken, your PDA should power on from USB cable. Good luck, feel free to ask further questions and always remember to rate replies received from this site :)
Posted on Mar 01, 2007
  • 624 Answers
Hi LaSuperChica, Have you tried a full (hard) reset? -Press and hold Application Buttons 1 (Calendar) and 4 (iTask) on the front of the unit and, at the same time, use the stylus to press the Reset button on the back of the HP iPAQ Pocket PC. -Hold all buttons until the displayed image begins to fade (approximately four seconds). -Release the Application buttons and stylus. Verify the full reset occurred by pressing the power button, it the full rest was done correctly the unit should not turn on. -Reactivate the batter by pressing the reset button with stylus. Let us know if this works and please don't forget to rate this post.
Posted on Feb 27, 2007
  • 1 more comment
  • tomj23 Feb 28, 2007
    I?m thinking that your battery isn?t charging, either it has a problem or your charger isn?t working right which is pretty much what you thought from the beginning. What are you using to charge it a sync cable (or cradle) connected to your computer USB or a wall socket adaptor?
    I?ve had issues with my cradle not powering my iPAQ from time to time. Usually its because the iPAQ isn?t connected just right. The thing to watch is the charging LED should light. If its lighting but you still don?t have any change then the battery itself might be defective.
    I?m not sure about your specific model but most others will run if plugged into a properly functioning cradle or a wall adaptor you should be able to power up the iPAQ. Even with a low charge battery.
  • tomj23 Mar 01, 2007
    The second LED from the left of your iPAQ on the top is the charge indicator. When charging it should be flashing amber, solid amber when its fully charged. If its not doing any one of those your charger is shot or the connection is faulty. Inspect the charger iPAQ plug and the iPAQ socket for damage or contamination. If you don?t turn up anything there then it may be as simple as getting a new charger.
    Again your AC power converter is looking more like the primary candidate. Unfortunately I think the only way you are going to resolve this is to either take your iPAQ and charger to the local tech shop (that will work on an iPAQ) where they can quickly test it OR spend $25 on a new charger and actually test it. Even if they aren?t setup to test the iPAQ they might be able to test the charger itself to see if its still putting out the right voltage and amperage. Depending on the shop I wouldn?t imaging they would charge more than $35 to identify the problem. As far as the USB chargers go I would recommend you stay away from them unless you are plugging it directly into a USB port on your PC.
Sony pocket ereader frozen on "are you sure you .....delete items. tried reset many times ...won't work. it is fully charged. plugged in to computer & no lights come on ... computer does not...
Hi shianto,
Because of e-ink screen technology the reader will display last page even if the unit is not charges it may display "full". Try this:
1. Connect the reader to the PC and check if a redlight comes up
2. If there is no light, hit the reset at the bottom for 3 seconds, the light should come on now.
3. Leave the unit charging for about 15-30 minutes
4. Unplug the unit and see if its operational now, if not you can try the reset again and the slide the power switch
eBookBoy
May 14, 2011 | Sony E-reader Portable E-book MP3 Player
I was trying to update the Bios when my pocket pc went to a screen that has the word "Serial" at the top, a hp blue logo in the center with the word invent underneath it and at the bottom it has a v1.08. I...
Not a problem it happens just go to hp.com download the bios driver and use it on windows xp it will not work with anyother windows and run it with your ipaq connected to the pc. This will reinstall the complete bios software and bring it back to factory.
Aug 10, 2010 | HP iPAQ H2200 Pocket PC
Screen stuck on "Serial (Top)-HP blue logo Invent (Center)-v1.08"
have you tried starting the ROM update over. if it recognizes part of the update it may give you an out back to your previous version. good luck.
Jan 19, 2010 | HP iPAQ H2200 Pocket PC
IPAQ hp Pocket PC wont turn on!?!!
Same Problem Here I In The Dark Here I've Treid All The Other Formus I Might End Up Getting A New Charger.
Sep 23, 2009 | Compaq iPAQ H3630 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
I have a pocket pc axim x3 ,i charge the battery but no turn on . how torn on the pc
Does the light come on while charging in the cradle? if so there is a power button where the light is. also try taking the battery out and putting it back in to see if that works
Jul 12, 2009 | Dell Axim X3 Pocket PC
Can't charge My dell Pocket Pc axim v5!
Make sure that battery is properly in place. Somertimes it will charge in the cradle but not actually charge if the battery is loose or not seated properly.
OR
Time for a new battery
Oct 25, 2008 | Dell Axim X5 Pocket PC
H6315
I got the same problem. I even tried to plug the battery to the second battery charging slot, still couldn't get it back to life. But the Ipaq screen lights on with progress bar progress for about 5 seconds, then dead again. I even doubted the battery was toasted.
I gave it a final shot:
1. Remove the battery, and then put it back.
2. While the screen lights on, within 2 seconds, cold reset the unit by press the hole with stylus and push the power button at top in the same time.
In my case, the progress bar will keep going until I see the tap screen instruction and everything back to normal. But it reminds me that the removable battery is totally discharged. So I put it in cradle and I am able to synch it with my PC. Everything seems o.k. while it sits in the cradle, except the charging light won't turn red.
When I remove it from the cradle, it still lights on, battery shows 99% which is healthy. but when I turned it off, it won't start anymore. I have to repeat the above steps to revive it. Sometimes I have to remove the battery and wait for a while and then put it back, so that the screen can light on to give me chance to cold reset.
Conclusion: Maybe need a new battery. I will check Ebay to get one.
Please post if you have other solutions.
Dec 22, 2007 | HP iPAQ h6315/h6365 Pocket PC
Garmin wont stay on
How did you charge the unit? If you have not done so, try charging in on the computer for a few hours. Sometimes this can help.
Nov 24, 2007 | Garmin StreetPilot C330 GPS Receiver
HP iPAQ H2210 Pocket PC Logo
236 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
