Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
DVI/HDMI Cable lost my pic and sound
I plugged in a DVI/HDMI cable on my 57" Ultravision Hitachi. I now have no picture or sound but it still displays all the digital information and when I check the AV's and get to VGA I have a correct VGA screen.
  • mbrown7532 Dec 10, 2008
    Unfortunately this won't help. I have already disconnected the PC and it is still the same. I know it's something simple. That's what's making me crazy.
Try disconnecting the hdmI cable and the dvr box.
Connect the cable directly to the cable input.
Sometimes the dvr boxes will cause this problem
after you connect the hdmi cable.
Posted on Dec 10, 2008
I plugged my xbox one to my Hitachi 57F500 hdtv using a dvi/hdmi cable but there is no audio. How can i get audio?
On some tvs the hdmi port are weak maybe its starting to come away from the motherboard , I had this happen with ps4, do you have another port to try ? The only way I could sort mine without hefty repair bill was to use the hdmi port that I was using for Sky and then connect Sky through scart lead.
Oct 30, 2016 | Hitachi 57F500 57" Rear Projection...
HOW DO I PLAY A DVD USING Hitachi Flat Panel Television 32HDL51 (ITS CONNECTED THROUGH HDMI CABLE)
Page 18 of the manual, you shouldn't need to do steps 2 or 3.
CONNECTING A COMPONENT SOURCE WITH HDMI or DVI CAPABILITY TO INPUT 1 or INPUT 2
1.Connect the HDMI or DVI to HDMI connection cable from the output of the HDTV set top box or DVD player to the HDMI input as shown on the AVC Center below.
2.With DVI output, connect the cable from the AUDIO OUT R of the HDTV set top box or DVD player to the INPUT (AUDIO/R) jack.
3.With DVI output, connect the cable from the AUDIO OUT L of the HDTV set top box or DVD player to the INPUT (AUDIO/L) jack.
4.Press the INPUTS button, then select INPUTS 1 or 2 to view the program from the HDTV set top box or DVD player. The VIDEO OSD label disappears automatically after approximately four seconds.
5.Select ANT A or B from the INPUTS menu to return to the previous channel.
NOTES:1. Completely insert the connection cord plugs when connecting to rear panel jacks. The picture and sound that is played back will be abnormal if the connection is loose.
2. The HDMI input on INPUT 1 or 2 contains the copy protection system called High-bandwidth Digital Content Protection (HDCP). HDCP is a cryptographic system that encrypts video signals when using HDMI connections to prevent ******* copying of video contents.
3.HDMI is not a "NETWORK" technology. It establishes a one-way point-to-point connection for delivery of uncompressed video to a display.
4.The connected digital output device controls the HDMI interface so proper set-up of device user settings determines final video appearance.
http://tv.manualsonline.com/manuals/mfg/hitachi/lcd_television_lcd_display_monitor_32hdl51.html?p=18
Jun 14, 2016 | Hitachi Televison & Video
Hitachi 51f510 sound no picture
select hdmi on menu or dvi/component on tv
Jul 05, 2013 | Hitachi 51F510 51" Rear Projection...
What kind of connector do I use to connect a dell laptop to a Hitachi 42'' plasma display? HDMI to DVI or HDMI to VGA?
If the TV has a VGA connector then use a VGA to VGA cable from your laptop as most laptops have a VGA output. Otherwise use one of the other combinations that work HDMI to DVI or HDMI to HDMI..
Nov 11, 2009 | Televison & Video
57 hitachi ultravsion rear proj hdtv :ps3 hdmi issues
TRY ON THE DISPLAY PS3 SETINGS TO NOT LET THE HDMI DO AUTOMATIC,,CHECK OFF A FEW ,,LIKE TRY JUST DION IT CUSTOM,,CHECK 480P,,AND 1080I,,,NOT 720P OR 1080P,,TRY THAT AND IF YOUR TV IS A 1080P,,JUST CHECK THAT,,OR IF ITS A 1080I,,JUST THAT
May 15, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Hooked up a hdmi/dvi cable
try using the red- blue- green high def connections
Dec 08, 2008 | Hitachi 57F500 57" Rear Projection...
No sound
A DVI cable does not have an audio connection, along with the DVI you still have to run an audio line from the device (DVD player, cable box, satellite receiver) to the TV. HDMI contains both audio and video.
Sep 30, 2008 | Hitachi 57F500 57" Rear Projection...
HDMI to DVI cable connection picture problem
You are Just trusting on Monster Cable, thats what your doing wrong. HDMI and DVI are not same formates.
Jul 29, 2008 | Hitachi 51F500 51" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
368 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
