Question about Whirlpool LHW0050PQ Front Load Washer
Standing water in washing machine
My duet machine keeps filling up with water when the machine is not turned on. This has happened 3 times in the last 2 days. I have to put it on drain and spin to get rid of it. What causes this?
  • 1,543 Answers
The inlet water valve is not shutting off completely. Replace the valve, which is the part the inlet hoses screw onto.
Posted on Dec 09, 2008
My whirlpool front load keeps cycling without the water filling.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 30, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool duet washing machine is collecting water in the tub after laundry is long done
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Kind of the opposite of these tips... your fill solenoid has dirt in it and it won't shut off...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Standing water in the tub
bad inlet water valve --turn water supply off and watch to see if machine continues to fill with water --suggest removing inlet water lines from machine and inspect the strain screens on the machine for sediment build up if so clean
Aug 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
When my Duet washer is not running, it slowly fills with water. This has happened about 3 times.
the most common problem with a slow filling washing machine is a blocked filter
this is located inside the hose usually near the machine.
it this is not blocked
it may be a stuck valve, to test if this is the case connect the hot water and see if that fills quicker.
a short term fix would be to connect both hoses to cold if you can.
If your machine requires hot water to function it may not fill all the way because it will switch off if there is no hot water.
hope this helps.
Apr 21, 2009 | Whirlpool GHW9400 Duet Washer
Water level problem with duet GHW9300WHP
The best way to check this problem is to run with no clothes in it the water fill and stop three time after the third time the water level should be high in the back tapering off to not much in the front this unit wash as a chemical wash not with a lot of water
Mar 28, 2009 | Whirlpool GHW9300 Duet Washer
My Whirlpool Duet Washer fills up 1/4 of the tub on its own.
Sounds like a defective fill valve leaking water in although the machine is off.
First turn off your water and remove the hoses. Clean the screens in the hoses and the fill valve.
If that does not correct the problem replace the fill valve.
Feb 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Fills on its own door open or closed
I would bet the water inlet valve is weeping. It may not seal shut every time. It could have a piece of rest stuck in it also. It's cheap and easy to replace. The part # AP3128776.
Feb 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a DUET HT . I have been having "H" & "F" problems for the last 2 months and been turning off and unpluging to reset. This time i pushed Control On but when I hold to starty nothing happens.
"H" & "F" means no water is coming into the washer, check that your faucets are on, hoses & screens on hoses,if all this is working properly, it could be your water valve or if the washer has water inside and the pump is not pumping it out, for safety reasons the washer will not fill and you will get the codes f h or l d.
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F20 keeps appearing on our Whirlpool Duet Steam Washing machine. We cannot finish a load of laundry.
ck to see if fill hoses are connected correctly and you have good water flow through BOTH hoses to washer connection..if control senses slow fill it will f20..do not try to use cold water onlyauto temp will try to use hot to adj prest temps and will fault if no water flow detected if ok ckd screens in washer end to be sure they are clean ..also ck to see if drain hose is proper height and not in stand pipe too tight ..water may be siphoning out and washer will not fill in allowed time
Sep 17, 2008 | Whirlpool Washing Machines
Water filling while door is open
if water is constanty dribbling into the machine then there is a leaking water valve on the machine, if not leaking in all the time then exessive water pressure at some time, dont thing it is the control
Apr 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
660 people viewed this question
Dan Webster
Dan Webster
Sal De
