I broke the USB connector on my flash drive and I need to recover the data.
    Scholar:
  • 86 Answers
The only answer here would be to carefully break open the device and attempt to repair the connections. Either with the original end or by pirating the end of a usb lead (leave enough fly lead to make connections to the device) Carefully note the wire connection order of the device in relation to the replacement part
Posted on Dec 09, 2008
How to restore delected files from my usb flash drive
Hi, Even I faced the same problem. I have deleted some of the PDF file from my pen drive and luckily I could get all the files from it. I used Yodot File Recovery software and with the assistance of this software I was able to get all the PDF files. Download free trial version of the software if you want to know how to recover a PDF file. It recovers not only PDF file but also all the files present in the drive.
Nov 23, 2012 | Computers & Internet
I need to recover my files from my USB manually without downloading software!
yes, you can recover files from usb with some good usb recovery software, recommended asoftech data recovery can recover files from usb. here's a good tutorial you can follow
undelete files from usb drive
Oct 23, 2012 | PNY Electronics - Others
Lost files in USB memory flash
Asoftech data recovery program can recover data from formatted, lost or damaged hard drive or partition, Ghost hard drive .
# Recover lost, formatted or deleted ( word ,excel ,ppt, office document, video zip, photo files etc ) from hard drive, Support USB recovery and other disk recovery .
http://www.asoftech.com/adr/
Jun 11, 2012 | SanDisk 16Gb USB Flash Drive
I used my sandisk cruzer 8g as a first boot device to load a certain application, then suddenly hangs and power off, after i restart the pc my usb device reads as 0 data, when try to open it asking to...
Hi Amir,not 'Safely remove the hardware' will result in data loss on USB flash drive.However,you can recover your data on it with third party data recovery software.I have succeed to recover data from pen drive with Tenorshare data recovery.It can recover data after deeply scanning your USB flash drive to look for lost data. By the way,you can download a trial version and scan your flash drive for free to preview whether your data can be recovered. http://www.any-data-recovery.com/index.htm
Jun 17, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I am having one 4gb pendrive its not opening. now im inserting my pc please recover it.
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/adr/index.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the pen drive (use quick format), and then use above mentioned software to scan again the pen drive and recover your files.
Apr 05, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My 10 pin data connector broke off inside the case--can I take this somewhere for assistance with repair and data recovery off of my device? it is a maxtor one touch III mini
The answer is Yes.
You can recover lost data from USB with data recovery program.
CardData Recovery can recover data from all camera flash memory cards includingCompact Flash Card (CF), Smart Media Card, Secure Digital Card (SD),Multi-Media Card (MMC), XD Picture Card (XD), Micro Drive, Sony Memory Stick(Duo, Pro), as well as removable storage including Zip disk, USB drives andHard drives. Recovery of files is also possible even when drive has beenformatted.
Oct 25, 2010 | Maxtor OneTouch III Mini Edition 120GB...
My usb stick needs to be formatted for pc but i cant
you can try format recovery software like asoftech data recovery. You can see
Recover formatted files
It tells the steps how to perform format recovery.
If above does not work, you may have to format the usb drive (use quick format), and then use above mentioned software to scan again the usb drive and recover your files.
Apr 04, 2010 | Computers & Internet
Usb connector broke off can the data be recovered?
Yes, but it has to be taken to someone who can do soddering.. make sure you keep both pieces and check local shops for someone who can soder the connectors back together. the data is stored on the main chip, its just the connector that gone now.
Jul 07, 2009 | Electronics - Others
Verbatim 1GB flash drive data recovery
Sounds like you broke something ;)
If your computer does not recognize anything when you plug it into the computer, your problem is most likely a broken contact inside the usb drive.
You should attempt to open the drive, and see if one of the four contacts on the inside of hte usb key are no longer making their way to the circuit board, and try to reconnect it.
IF you can push the connectors down with your fingers and make contact temporarily, and the computer recognizes it, try to just hold it there while you copy all your data off. Then throw away the flash drive.
Jan 22, 2008 | Electronics - Others
Computers & Internet Logo
David Payne
David Payne
