Question about Yahoo Messenger
Incorrect line parameters winos installer v 2.00.26.00.0
K heres the problem. i download messenger when it starts to install the installer this message pops up saying this exactly. incorrect line parameters winos installer v 2.00.26.00.0 portions of software is part of the original jpeg corparation. what ever right. i click ok cuz its the only option it gives, in continues to install the actual messenger bout half way through it adds the shortcut to the desktop. bam nother message. application has failed to start because the application configuration is incorrect reinstalling might fix this problem. i have reinstalled like 20 times no joke. still same messages. i have uninstalled everything pertaining to the program and then reinstalled. still bein anoying. can any one help me please.
  • crimson_tear Dec 12, 2008
    im not running on vista im using windows xp sorry i should have put that in there
    Problem Solver:
  • 16 Answers
You may need to use the Windows installer cleanup utility to remove it completely if it has already been uninstalled.
http://support.microsoft.com/kb/555175
Then upgrade to most recent version of the Windows Installer http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&DisplayLang=en
Posted on Dec 12, 2008
    Problem Solver:
  • 16 Answers
Use info below to delete present version completely then if you want to try 9 again and are using Vista go here for help.
http://www.ymessengerblog.com/blog/2008/10/27/installing-90-on-windows-vista/
Messenger 9 for Vista users and XP users with 9, Mess 9 has many unsolved problems and missing features that messenger 8.1 or 8.0 has. Plus now the updated Windows Firewall will not let Messenger download correctly.And is causing 9 users to have problems now.. The only option that might help is going to the control panel and turning off the firewall to download and install then turning it back on.Then click on windows fire wall, Exceptions tab. make sure messenger is checked,if not listed then add it to the list.then click save.
.If the fire wall still causes problems,then revert back to 8.1 or 8.0 these and all versions of messenger can be found here; http://www.freecreed.com/ymsgr-archive.html
You need to remove version 9,or present version, 1st to get another version to work. To remove Messenger version Use Unwise located middle of page of Messenger Folder.Make sure Automatic is checked! then continue to uninstall..Or use control panel ,Vista-program features or XP-add/remove this is the 2nd best way. If you just delete the Yahoo file to remove messenger,you will also lose the shared file that contains things needed on other Yahoo sites. Your contacts are stored online But if you want to save your old messages archives,they are saved on your PC in the messenger file you are about to delete.Go here and copy them to a new folder
Start>my computer>c:drive>program files>yahoo>messenger>profiles>(your ID)>archive>messages
The latest update for Flash Player to #10 Is causing things to not load,Can not log in,or Messenger just crashes upon opening..Use the link below for a download of Flash player # 9.0.124.0 . You have to remove the present flash player,add/remove programs in control panel,Reboot then download from here. http://www.adobe.com/support/flashplayer/downloads.html
Here is the best help/fix it sites I have found so far for Messenger,chat,and Yahoo in general. http://www.helpbytes.co.uk/ This one for Vista http://www.vista4beginners.com/tips-and-tricks
many problems solved using this link http://www.freecreed.com/
  • star_r Dec 15, 2008
    Answer works for Both XP users or Vista users. Version 9 is the problem not your Operating System.
Ahoo install problem, error message, incorrect command line parameters and application configuration is incorrect
Download messanger again and try installing again. It may have gotten corrupted in the download. If it still doesn't work then you have a problem with your operating system and may have to re-install it.
Nov 18, 2010 | Yahoo Messenger
When i try to install yahoo messenger an error "incorrect command line parameters" keeps showing..i uninstall and try again but no luck
Download Java update and as well as adove flash player...try install yahoo messenger 8.1 , it works fine....you can find it in www.filehippo.com ... Best of luck.
Oct 23, 2009 | Yahoo Messenger
Incorrect command line parameter?
i had the problem in installation of yahoo messenger it gives the messege that in correct command linepatametrer problem. just go to start control panet addremove programme and uninstall the yahoo with his all features. then go to yahoo and find the 7 or 7.5 version and download and install it. it will work BUT it will gives you the messege that u r using the older version go to this webside and down the latest version of yahoo messenger. go and find the 8.1.0.421 and download it.
alter that when u installing it it will computer will gives you the messege that u allresdy install the latest version if u r installing this one go and unistall the other. go to add remove programme and uninstall that version and reinstall the latest 8.1.0.421. when it done. give it ur id and password and make fun......
Oct 12, 2009 | Yahoo Messenger
Trying to install yahoo messenger 9.0. I get 2 errors then unsucessfull intstall. 1. Incorrect command line parameters. Windows installed V2.002600.0 Portions of the software are based in part in the...
DO you have administrative privileges on your account? If not get them. You also might have installed a conflicting software that is conflicting with yahho messenger.
Oct 10, 2009 | Yahoo Messenger
Installation of yahoo messenger error
I think you will need to upgrade your windows installer version.....download it from Here run it and now try ...hope it will work...Good Luck
Sep 25, 2009 | Yahoo Messenger
Installing yahoo messenger incorrect command line parameters
why cant i send a message to all my friends on yahoo messenger?how can i solve this?
Jul 02, 2009 | Yahoo Messenger
I can't install yahoo messenger 9 version. i get an error message when trying to install yahoo messenger 9. incorrect command line parameters.
We need to uninstoll it then reinstall it.
1.- clck START
2.- click SETTINGS
3.- click CONTROL PANEL
4.- select ADD IREMOVE
5.- LOOK FOR MESSENGER 9
6.- SELECT REMOVE
it may ask you if you sure say YES
when is all gone.
RESTART your computer and go to msn.com try to install it again be patient don't open any windows or games it will take few min but will be better.
Your rating is very important to me...
Was this helpful?
May 28, 2009 | Yahoo Messenger
Installing Yahoo Messenger
download yahoo messenger stand alone version from here
select your country then download
http://www.mydigitallife.info/2009/11/16/yahoo-messenger-10-final-full-version-offline-standalone-setup-installer-download/
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Apr 09, 2009 | Yahoo Messenger
Try to update windowsinstaller. Search for WindowsInstaller-KB893803-v2-x86 at www.microsoft.com site. Install it before installing YM 9.
Dec 13, 2008 | Yahoo Messenger
Yahoo Messenger Logo
384 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
