Question about DXG Technology DXG-506V DV Digital Camcorder
Flash wont work
When I turn the camera to photo mode, the flash will not work. When I press the button to change the flash settings, it will go to flash for a moment then go right back to the no flash setting, and will not change off of that. then the unsteady indicator comes up and will not go away. Any ideas?
  • joyk Mar 27, 2008
    I have the same problem with mine. I am very frustrated.
wtf
Posted on Jan 23, 2008
This is probably because you either have it on close up reang (the button on the top/side or your out of battery
Posted on Sep 08, 2007
My flash stopped working on my nikon coolpix L110..
The Nikon Coolpix is a compact digital camera that is well-suited for amateur to semi-professional photographers. Occasionally, some issues with the built-in flash can occur. If the hardware is damaged, the camera must be taken in for repairs. More often, problems occur because of obstructions or issues with the camera's settings and are easily repairable. Follow the troubleshooting guide to fix the built-in flash.
Instructions:
1.Ensure the Nikon Coolpix digital camera battery is fully charged.
2.Wait several seconds before pressing the shutter-release button if the "Flash Ready" indicator light is flashing red. Press the "Flash Mode" button once or twice to change the flash settings from "Off" to "On" or "Auto" if the "Flash Ready" indicator light is off.
3.Ensure there are no obstructions, like your finger or the camera strap, that are preventing the flash from firing if an error message appears on the display screen and the flash is not firing when the flash mode is set to automatic.
4.Press the flash back into the camera after every photo to ensure the flash always fires in "Auto" mode instead of just in low illumination settings. Press the flash back into the camera to turn off the flash in "Manual" mode; otherwise the flash will continually fire.
5.Change the auto focus setting from "Infinity" to "Auto," "Macro Closeup" or "Self-Timer" by pressing the "Focus Mode" button once, twice or three times to automatically turn the flash back on.
6.Use only Nikon external flash accessories to avoid damage to the built-in flash and camera circuits.
I hope you find it very helpful. Thanks.
Aug 25, 2011 | Nikon COOLPIX L4 Digital Camera
I have an auto flash, but it's not flashing. Do I need to somehow turn this function on? If so, where is it?
Follow below mentioned steps to turn flash on:-
  • Rotate MODE DIAL to any one of them Auto, program, portrait, landscape, sport or night mode.
  • Press POWER button to turn power ON.
  • Press Navigation button (left arrow button), Flash mode change each time button is pressed. you can use UP and Down Arrow button to change settings. Set it to FLASH ON.
  • Press OK to confirm settings.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Feb 13, 2011 | Polaroid i936 Digital Camera
My daughter can't take pictures outside as the flash goes off and it just gives a white picture as it's too bright, what can I do?
1. You could try pressing the reset button. 2. You could press the "delete" button to change the flash mode when you first turn the camera on. 3.=Please check your flash setting to make sure that you don’t have the camera on forced flash mode (indicated by the lightning bolt with the plus sign in the upper right corner).
Using this setting in strong lighting conditions would result in a picture with too much
light.
4. If all else fails, you can call 1-800-521-2010
Aug 17, 2010 | Vtech Kidizoom Digital Camera
Samsung S730 camera wont take photos with flash
�� When the menu is displayed on the LCD monitor,
pressing the LEFT button makes the cursor shift to
the left tab.
�� When the menu is not displayed on the LCD
monitor, the LEFT button operates as the FLASH
( ) button.
�� Selecting the flash mode
1. Rotate the MODE DIAL to select a RECORDING mode with the exception of
Movie clip mode.
2. Press the Flash button until the desired flash mode indicator displays on the
LCD monitor.
3. A flash mode indicator will be displayed on the LCD monitor.
Use the correct flash to suit the environment.
Jul 23, 2010 | Samsung Digimax S730 Digital Camera
How do I turn the flash off?
  1. Press 'down' key (which is located below SET button) once.
  2. Use 'left' or 'right' key to select mode with crossed flash symbol in a circle ('flash off' mode).
  3. Press SET button to submit selected mode
  4. Make photos
Jun 19, 2010 | Casio EXILIM EX-Z1000 Digital Camera
My flash on the kidizoom camera won't work
To Change your flash settings, press the Delete Button while in Photo mode until desire setting. I had the same problem!
http://www.vtechkids.com/_f/_pw/_manual/80-077300%20Kidizoom%20Camera.pdf (Page 9)
Jan 15, 2009 | Vtech Kidizoom Digital Camera
Nikon S210 flash not working
The flash has been working fine until last night when I tried to take a picture and the flash was set to auto. When I press the button the little red light beside the flash sign lights up, but the camera does not take the photo. When I set it to flash mode, it still won't take a photo. When I turn off the flash, then it does. What could be the problem? Is it in the settings?
Dec 12, 2008 | Nikon Coolpix S210 Digital Camera
How to turn on/off the flash onthe samsung d900i phone
Using camera options in Capture mode
In Capture mode, press < ebdd9ac.gif > to access the following
options:
Record video: switch to Record mode.
Shooting mode: take a photo in the following
modes:
Single shot: take a photo in Normal mode. You
can select whether or not the camera automatically
saves a photo.
Multi shot: take a series of action stills. You can
select the number of photos the camera will take
and the shooting speed.
Mosaic shot: take several stills and save them in
one frame. You can select the layout.
Effects: change the colour tone or apply a special
effect.
Frames: apply a decorative frame.
Flash: determine the use of the flash.
Timer: set a time delay before the camera takes a
photo.
Go to My photos: access the My photos folder.
Camera settings: change the default settings for
taking a photo.
Apr 01, 2008 | Cell Phones
Sony Cybershot DSC-H7 - can not change flash settings
for anyone who wants to know how i solved my problem with the flash saying it cannot be changed...
If you go into the camera settings; look under rec mode. It might be in "burst" mode. Flash will only work while in "normal" mode.
Mar 16, 2008 | Sony Cyber-Shot DSC-H1 Digital Camera
DMC-FX01 Flash Does Not Work
In what mode are you trying to take photos? The flash will not work in certain modes (see the manual), for example the night mode. Or you accidentialy turned on sequential/burst mode (this is mode where camera takes more pictures on one shutter button press). Flash cannot be used in this mode also. I don't have FX01, but on FZ8 the camera will show flash icon in red, but will take the picture anyway without flash being triggered. The second problems seems like enabled power-saving mode, but those 5 seconds are too short for this. But anyway you can check in SETUP menu the settings for power-save. Also maybe the flash is broken and camera noticed it... I don't think this could be a software problem. Either problem with the flash, but more probably just setting of wrong mode.
Jul 24, 2007 | Panasonic Lumix DMC-FX01 Digital Camera
DXG Technology DXG-506V DV Digital Camcorder Logo
227 people viewed this question
Top DXG Technology Video Cameras Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jose Ma DM.
Jose Ma DM.
Tony Parsons
Tony Parsons
Are you a DXG Technology Video Camera Expert? Answer questions, earn points and help others
