Question about HP Wireless Optical Mouse
I have a 5187URF2+ wireless HP keyboard that stops working
The keyboard stops working after the computer is idle for awhile. I try the reset option on the bottom of the keyboard but it does not work, I have put new batteries in and that does not work. I can get it up and running if I turn the computer off for a good 5 or so hours. I have a wirelss HP mouse and have no problems with it.
5 Suggested Answers
  • 71 Answers
SOURCE: wireless mouse won't work on hp multimedia cordless keyboard and mouse
Try changing the batteries in the mouse and then press the little sync button of both the mouse and the wireless receiver.
Posted on Nov 10, 2007
  • 102 Answers
SOURCE: Logitech wireless desktop model NoY-raj56a
jhammons:
In your case seems like the usb ports needs to be reconfigured, which OS are you on. I assume you have windows. Right click on my computer, properties, hardware tab, Device manager, Check for Universal Serial bus controllers, is there any sign of exclamation or cross sign over it Or any problem on them?
If yes, you need to install the USB drivers only from the CD that came with your computer's motherboard.
OR
Check system BIOS and see if USB ports are enabled, make sure you press F10 to save and exit once you check and reconfigure in BIOS.
OR
Install the drivers that came with the keyboard and mouse.
Or
visit:
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en
and download the right drivers for your mouse and keyboard and restart your machine.
Hope that helped!
Posted on Dec 09, 2007
SOURCE: Constant reseting of HP Wireless (P2360AA) USB Keyboard and Mouse Kit
check some Option Driver's control Panel system - Hardware - Device Manager - go to Keyboard's Up Date Drivers your Problem Solove ok
Posted on Apr 17, 2008
SOURCE: How do you open the mouse to replace the battery
quite easy look on the bottom holding the mouse as you would in use . at the end nearest to you , you will see a arrow pointing to the left under is the battery release slider move it to the left then slide the top cover backwards and reveil the batteries, observe polarity when changing batteries
yours
Reg Taylor
Posted on May 07, 2008
yooperbud
  • 8637 Answers
SOURCE: Trust keyboard and wireless mouse
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try typing to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Hope this helps. Bud
Posted on Jan 19, 2009
Wireless not working
I'd replace the batteries first, even if you've done so recently. If that doesn't fix the problem, try it on a different computer. My six year old HP computer came with a very similar setup. Look for a reset button on all three of the components and press them.
Feb 28, 2014 | HP P2360AA Keyboard/Mouse
After ge mouse is left idle for awhile, it wont work. I have tried to press connect on receiver then press connect on bottom of mouse but it stll wont work. what now?
I would try replacing the batteries first of all. If this doesn't fix the problem then uninstall the software and reinstall it. Hope this helps!
Feb 28, 2011 | GE Wireless Optical Mouse
Where is the "fn" key located on my hp keyboard model # 5187URF2 ?
I have a Logitech and the Fn key is on the right side in between the Alt. key and the Ctrl key. to the right of the space bar.
Jun 10, 2010 | HP Wireless Optical Mouse
My keyboard for my hp stopped working. it would
Check the connection to the back of your computer.
Mar 24, 2010 | Computers & Internet
Dell wireless keyboard stopped working. Changed
I make oresumption that you have depressed the connection button under the keyboard to reset it?
If still a problem go to device manager and delete the wireeless keyboard so it can be discovered again.
Please rate my help++++Thanks for using FIXYA
Nov 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Stuttering Graphics
check for the mouse pointer movement speed.... this can be located in control panel --> Mouse Options.... there check for the mouse wheel speed and decrease it ..this may help.... sometimes wireless devices doesnt have compatibilty will vista OS , this may also cause an issue..if any vista drivers exist for ur mouse install them and check ...hope this helps...
Aug 18, 2009 | Computers & Internet
Wireless mouse will not work
Sure you can use the computer w/o a mouse. You can use the Alt key, Tab key, arrow keys, and the Enter key to move and make selections.
About the cordless mouse...I assume you have good batteries installed and in the proper position? Is this a new mouse? If you think it is bad, return it.
You can always buy a cheap USB mouse to get you going. Even though you can use a keyboard to navigate, it gets a little tedious after awhile.
Jan 08, 2009 | HP Multimedia Cordless Keyboard/Mouse...
Wireless keyboard locks up ... have contacted HP support (service ticket number 801952055 ... talked to A.Schwerin ... problem not resolved. Have done everything recommended by HP under 'Keyboard...
My HP wireless Keyboard can be reset by momentarily disrupting its power, e.g., removing the battery cover and lifting one of the batteries. It's not much of a fix but seems preferable to restarting.
Dec 21, 2008 | Computers & Internet
yours
Reg Taylor
Mar 17, 2008 | HP Wireless Optical Mouse
HP Wireless Optical Mouse Logo
507 people viewed this question
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
