Question about Dell 926 All-In-One InkJet Printer
Dell 926 all in one will not print in color
Some time ago I remember using a setting that related to how the two ink cartridges can print for each other if one is out of ink. I think I reset something. Now it will not print in color. I simply cannot find where the adjustment is
  • 837 Answers
You have to modify your print settings in the dell utility
Posted on Dec 09, 2008
    Sergeant:
  • 399 Answers
Remove the cartridges and off the printer.then remove the power cord for a minute.then again insert the cord.then just on the printer.then insert the cartridges.and select the cartridgres as new.
  • Dell Master
  • 13,433 Answers
open the page you want to print then
File -> print -> click on print preferences make sure settings are are not set to black and white.
How do I trouble shoot problems with color prinouts?
Inside printer when open righthand side You'll see a pad and set of brushes clean with clean rag, and run clean in printer options. Then run align cartridges. should solve problem. make sure when putting in ink you just snap in and not mess with after that.
Jul 08, 2014 | Dell 926 All-In-One InkJet Printer
Dell 926 printer only prints in black and white. I recieved a message a week ago stating that my Color cartridge was empty and I needed to replace it in order to work. SINCE WHEN? never had that problem...
Make sure the cartridge is fully seated and the lock is engaged, then go to printer tools, maintenance run the head cleaner 10 times see if that resolves
Aug 20, 2011 | Dell 926 All-In-One InkJet Printer
It keeps printing alignment over and over
Sounds like a bad sensor in the Dell Series 9 ink cartridge.
You are using Dell Series 9 ink cartridges, correct?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Plug everything back in. This will reset any error messages the printer has.
Power on the printer. Open the printer and take out the Dell Series 9 Black cartridge. make sure all the tape is off the cartridge and put the cartridge back in. Now do the same for the Dell Series 9 color cartridge.
Dell Series 9 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 9 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
Black cartridge = black side(left side) Color cartridge = color side(right side)
Photo cartridge = black side(left side) Color cartridge = color side(right side)
It is possible to get a Dell Series 9 cartridge with a bad sensor. Contact the place of purchase for a replacement.
Rick
Jun 11, 2011 | Dell 926 All-In-One InkJet Printer
My Dad bought new ink cartridges ( black and color) and installed them in the printer and it is not registering that they are installed. What are some things I should check for and how can I fix this????
After installing new ink cartridges in your Dell all-in-one 926 printer, you may receive an error message telling you the print does not recognize the new cartridges. Refilled or third-party cartridges, which Dell does not recommend using with the 926, often trigger the error message. You may also receive this error after you have been using the same ink cartridges for some time. Whether the cartridges are new or not, the error can be caused by a number of sources. Following the steps below should clear up print cartridge problem.
  • 1
    Open the Dell 926's front cover with the power on and wait for the cartridge carriage to come to a stop. Remove the ink cartridges by pressing on the tabs at the top of each cartridge. Check the cartridges to make sure you have removed all of the blue protective plastic film. Look for the "Dell" logo stamped into the cartridges' lids to ensure they are genuine cartridges.
  • 2
    Clean the shiny metal portions of the ink cartridges with a damp microfiber cloth. Allow each cartridge to dry completely.
  • 3
    Clean out any paper, staples or other debris that you may be able to see, then reinsert the cartridges into their appropriate slots. Put the black ink cartridge into the left slot and the color cartridge into the right slot. Make sure both click back into place.
  • 4
    Close the Dell 926's front cover and turn off the printer. Unplug the power cord and USB cable from the printer for five seconds, then reconnect them.
  • If your Dell 926 fails to recognize the print cartridges after following the above instructions,
    take it to a repair shop for servicing.
    Good Luck and Happy Printing
    Jan 26, 2011 | Dell 926 All-In-One InkJet Printer
    I have a Dell 926 All-In-One InkJet Printer, I put a new black ink cartridge in the printer; still have plenty of color ink. When I have a document that I want to print from Word, it will sound like its...
    Make sure you've removed the shipping tape from the cartridge's print head. More than likely the black cartridge is not disbursing ink - clean the print head carefully with "Q" tip and alcohol and see if black ink comes out slightly. Re-insert cartridge and try again. Perform "clean cartridge" in printer properties window.
    Nov 03, 2010 | Dell 926 All-In-One InkJet Printer
    Can't get printer to print in black
    unfortunately some printers will not allow such and needs to have all the cartridges working for it to print. this is regardless if the black is still okay. i suggest to go to your nearest store and purchase one.
    Jun 19, 2010 | Dell 926 All-In-One InkJet Printer
    The printer keeps doing the alignment and saying that there is a problem. My color ink cartridge is low but I would still like to print with black ink. I don't know if the color cartridge being low affects...
    Replace your color cartridge and power printer on. The color cartridge is probably empty (even though there might be a little ink left in it). Many inkjet printers require the color cartridge for composite black even if you are not printing in color.
    Jun 16, 2010 | Dell 926 All-In-One InkJet Printer
    Dell Photo 926 ink cartridges holsters won't show up
    Contact the dell chat suport line on the dell.com website they are good at fixing probles even if they have to seend someone out or have you seend it in.
    May 03, 2009 | Dell 926 All-In-One InkJet Printer
    926 how to print black ink with economical settings
    this machine worked fine until today.there is plenty of ink in the cartridges,just replaced the black one a week ago ,worked fine till today when i tried to use it .p.c. works fine,im pi----.
    Oct 23, 2008 | Dell 926 All-In-One InkJet Printer
    Dell 926 All-In-One InkJet Printer Logo
    22 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
