I received a message to remove the tape. The camcorder will close without a tape but will not close with a tape. It beeps but will not close with a tape.
I charged batteries, changed batteries, changed tapes - nothing works.
Please adv. If you suggest a reset button - where is it located on the camcorder?
-   lacer, which screw are you talking about? their are a how bunch of screws where the tape pops out. I will like to try doing this without having to take the camera to a repair shop. Do you have any pics that you can share on how to fix this?
Thanks
-   ili4103
Dec 01, 2008
-   @lacer: can you upload a pic or diagram of the location of the switch? I've just about given up on this camera, it's been busted for almost a year now.
-   Guest
Nov 19, 2007
-   This exact thing happened to my Canon Elura 100. It wasn't even a year old! Help!!-   jaxdeke
Nov 19, 2007
-   I have the same problem too... it was working and all of sudden it beeped and gave an error message to remove the tape.. once removed, it wouldnt take any tape-   G0tcha
I took mine apart and there's a little switch on the backside of the camera that controls the opening of the cassette mechanism. It is meant to be tripped by the opening of the side of the cassette case and then triggers the ejection of the tape. The switch is probably just stuck. Taking this apart isn't too difficult - I think about 4 screws.
I called the factory and they said to send it in for evaluation. While packing it up, I dropped it
and lo and behold it started working. Even though it started working, I decided to send it in to the factory and they found something "loose" inside and repaired it at no charge.
I have a canon elura 100. Haven't used it in a long time because I had to buy a replacement power...
(More)
I have a canon elura 100. Haven't used it in a long time because I had to buy a replacement power cord. I charged it the other day and when I turn the camera on, a large vertical white line appears on the LCD or in the viewfinder. There is no picture. I tried to reset by taking out back up battery and battery pack but still there when I turned the camera back on.
I just like everyone else am having the error message with the canon elura 100 to eject the tape......
(More)
I just like everyone else am having the error message with the canon elura 100 to eject the tape... but the part that is supposed to eject will not open. It makes the sound like it is opening but does absolutely nothing!
I have a Elura 100 Camcorder and have upgraded the 256MB sd card to a 2GB sd card , however, I can...
(More)
I have a Elura 100 Camcorder and have upgraded the 256MB sd card to a 2GB sd card , however, I can copy from cassete to card and play on the camcorder, however when the card is placed in a pc it will not play and shows nothing
