Question about Sharp R-1481B Microwave Oven
Microwave oven inoperative
I have a Sharp R1481. Everything operates normally except the oven does not come on. The following do operate: lights, timer, clock, and hood exhaust system. This oven was experiencing problems intermittently until now. If the door was pushed in or "wiggled" the oven would operate. I checked the door switches and found one switch to be slightly melted. I have replaced all three door switches. However, the oven is still inoperative. Any suggestions are appreciated.
  • 1 more comment
  • craiton cooper Mar 04, 2007
    I want to thank MicrowaveSvc for the solution to my problem. The wiring diagram was exactly what I needed because I did miswire the interlock switch, oops! I appreciated the help.
  • Anonymous May 23, 2008
    I have replaced the secondary interlock switch on our Sharp convection microwave three times in seven years. The switches are poor quality and develop an overtravel condition in which they pass thru connect to disconnect which prevents the oven from turning and heating. The replacements are probably from the same lots as the original and don't last. One fix is to build up next to the switch button with layers of tape to limit the button travel and keep it in the connect position. The problem is finding a good quality replacement. So far no luck including Repair Clinic where I got the last two. Otherwise the Sharp has been excellent.
  • Anonymous Mar 18, 2014
    Timer runs but the oven only runs when you put a little pressure on the door button.
  • Sharp Master
  • 9,098 Answers
When you enter the time then hit START, does the turntable motor come on? If not, then I would suspect the secondary interlock switch, its mount, or its wiring. If so, then it's hard to say, unless there was some miswiring somewhere. The original problem sounded like just a classic bad door switch. At this point I suspect the wires on one of them may not have been reconnected exactly where they were. It does matter. I would suspect the secondary interlock switch, which MAY have white/white and grey/grey wires attached. Also, one of the switch mounts may have a broken tab that makes the switch move so it's not getting activated. At our site, we have the service manual for the R1830, which is similar to the R1480-series. We have that plus *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Feb 27, 2007
Sharp Carousel Microwave - R1481 keypad doesn't work
No! I'am afraid not, the problem is in the keypad control board, the whole assembly must be replaced, the part alone will cost around $100.00 or more depending on make and model.
Apr 16, 2012 | Sharp R410L Microwave Ovens
SHARP MODEL R895(SL)M TURNTABLE NOT TURNING
Check turn table motor operating voltage on the motor if the voltage is normal then check motor pulley(crack or broken) ,if o.k replace motor with the same type,if the voltage is missing go to the control panel and find out any wiring problem,if everything o.k replace control panel.
Jan 15, 2011 | Sharp R-303CW Convection / Microwave Oven
The light on the bottom of my r1481 microwave stays on constantly, how do i turn it off
The problem is a shorted relay no the control circuit board.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Oct 02, 2010 | Sharp R-1481B Microwave Oven
Our oven started coming on when the door was shut. It is not cooking but the light and the fan come on. Nothing makes it stop except opening the door. I unplugged it for awhile, but that didn't help...
I have the same problem.
I found that by removing the control panel, then moving the small red-buttoned switches around the door open switch seemed to solve the problem.
We felt the problem was a mechanical problem because closing the door very gently permitted normal operation.
Sep 24, 2009 | Sharp R-1460 Microwave Oven
Work light and night light do not work on Sharp Carosel R-1481
> Work light and night light do not work on Sharp...
Thanks for giving us the model number.
We regularly repair these R1481 control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 22, 2008 | Sharp R-510HW Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Turntable operation
I would suggest that you check the door switches and mounts. Here is a file to help: http://www.microwavedisplay.com/doorsw.txt
If those check out, I would suspect a shorted relay or shorted relay-driving transistor.
You may be able to find a schematic of the control unit at the Sears parts site. (They are closed during overnight hours CST)
The best place to order Sharp parts is Tritronics.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Sep 03, 2008 | Sharp Microwave Ovens
check high voltage section, check magneatron, diodes, etc.
Nov 02, 2007 | Sharp R-1480 Microwave Oven
Sharp R-1481B Microwave Oven Logo
136 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
