Question about Delfield 60 Refrigerated Work Top Model 4460N
Delfield model st4660n 2door cooler no cold air
Fan on condenser is not running, circulating fans on inside operating temp turned all the way up compressor is not hot or cold does not seem to be operating
  • Delfield Master
  • 1,218 Answers
Sounds like the temperature control is not calling for the cooling unit to energize. I would start there. first.
Let me know if I can be of any further help
Posted on Jun 07, 2010
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Tip
Why your unit is freezing up.
To understand why your AC or heat pump is freezing up, it helps to know how your system works.
There are 7 major parts to an AC system, 9 with a heat pump.
1 - Condenser/heat pump (The outdoor unit)
2 - Air Handler (the indoor unit unless the system is a package unit, then all is outside in one system. The air handler is usually found under the home, in an attic, or in a closet.)
In the condenser are the following major parts.
3 - Compressor
4 - Condenser coil
5 - Condenser fan
6 - (HPs only) reversing valve
In the air handler are the following major parts.
7 - Blower motor
8 - Evaporator coil
9 - (HPs only) electric heat strips
Some systems known as "dual fuel systems" use another heat source in place of the heat strips, usually a gas furnace. I will address gas furnaces in another post.
When an air conditioner is operating properly several things are taking place.
1 - The compressor is compressing or "pumping" refrigerant through the system.
2 - through changes in pressure, the refrigerant makes the evaporator coil get very cold, and the condenser coil gets very hot.
3 - The blower motor/fan circulates air across the evaporator coils, as the room temperature air (Also known as "indoor ambient") goes through the cold coil, it exits, cooled approximately 15 to 20 degrees cooler than when it entered. (In a ducted system, the blower is also the fan that circulates the air throughout the home.)
4 - The condenser fan circulates air across the condenser coils. As the outdoor air goes through the condenser coil, it removes heat from the coils that are very hot. This in turn removes heat from the refrigerant so it can run its cycle again, and through pressure changes, cool the evap coil.
5 - With a heat pump, the reversing valve reverses the flow of refrigerant in the condenser and evaporator coils.
In AC mode, the evaporator coils get cold, and the condenser coils get hot. But in heat mode, the evaporator gets very hot, and the condenser very cold.
Now, whichever coil is getting cold will freeze up if there is inadequate air flow across the coil, as the refrigerant in it is far below freezing, and there is not enough airflow to keep the humidity in the air from freezing on the coil.
Things that can cause poor airflow are,
1 - Dirty/clogged coils
2 - dirty/clogged filter (will only effect evaporator coil)
3 - Closed/blocked vents (will only effect evaporator coil)
4 - Malfunctioning or dirty fan
Low refrigerant will also cause a coil to freeze up, reduce efficiency and cause the system to run for long periods of time. Not to mention, shortening the life of the unit.
With a heat pump, in heat mode only, the condenser (outdoor) coil will routinely begin to freeze up in cold temperatures. This is due to the fact that the refrigerant is below freezing, and the cold outdoor ambient temp is not warm enough to keep the condensation in the air from freezing on the coil.
Note, a properly working AC should never freeze up.
A heat pump is equipped with defrost controls to prevent ice buildup.
Some are controlled by timers, some by temp.
When a HP is going into defrost mode, the condenser fan shuts down, the reversing valve reverses the flow of refrigerant and the once cold condenser coil now gets very hot, defrosting the coil. (Many people have said this process sounds like the unit is coming apart, or about to explode and are frightened by the "smoke" which is really just steam from melting ice that comes off the unit.)
During defrost mode, the secondary or "auxiliary" heat comes on to ensure that you are still getting warm air from the vents. (Again, this can be electric heat strips or a dual fuel system)
If you are experiencing cold air from the vents during defrost, that means your auxiliary heat is malfunctioning.
The auxiliary heat is used for three purposes.
1 - during defrost mode to maintain warm airflow (automatic)
2 - when the HP cannot maintain the set temp due to extreme outdoor temps. It comes on when the indoor temp drops several degrees below the set temp on the thermostat (automatic)
3 - For emergency heat source when the HP is not working. (Manual)
To recap....
Iced up coils?
Poor airflow
low refrigerant
Malfunctioning fan
failing defrost system
There are two things that can be done in a pinch to help de-ice frozen coils. This may get you by until the repairman can get there, or you can fix the system if you are a do-it-yourselfer.
HPs frozen outdoor coil in heat mode, not going into defrost?
Cover most of the vents, and turn the system onto cooling mode until the outdoor coil is thawed. then uncover vents and return to heat, or emergency heat. (this usually takes 15 min or less)
Frozen coils in AC mode with a heat pump?
Turn the system to heat with the thermostat on just high enough to get the system to come on. (again, usually takes 15 min or less to thaw.)
AC only, with frozen evap coils? (this can sometimes be seen frozen all the way outside to the compressor on the copper lines.)
Turn the system off, and the fan switch from "auto" to on".
This will usually defrost the coils within 1 to 2 hours.
(If your system has the furnace in line before the evap coil, turn the system to heat, and the furnace will defrost the coil within minutes.)
on Dec 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Refrigerators
Overheating
Usually that is a sign that there is a blockage to the condenser fan below the cooler. See if the condenser is dirty, or something blocking the flow of hot air from the condenser fan area. Check
the condenser fan motor to insure it is healthy and running strong. Recommend cleaning condenser to allow air to circulate the area freely. If fan is slow, stopping or not running I recommend replacing the fan motor. Sea Breeze
Jul 03, 2013 | Weber Chill 05-161 Beverage Cooler
Inside fan runs but freezer is hot
On this video, Delfield refrigerator with freon issue (restricted system)
May 06, 2011 | Delfield Upright Freezer 403
Air conditioning not too cold ??
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Let me explain in layman's terms how the air conditioning (AC) system works and what could be happening to your car.
Like your body, the air conditioning compressor is the heart of the AC system, and Freon is the blood. The compressor pumps Freon throughout the AC system, either the older type R12 which costs as much as gold it seems these days, or the new environmentally-friendly R134A Freon. This Freon is a gas and liquid combination that is compressed and circulated throughout the air conditioning system. The compressed Freon is pushed through the system under pressure and is passed through different sized metal and rubber hoses and a special valve called an expansion valve that cause the gas to expand and contract.
This expansion and contraction makes the Freon gas very cold. This cold gas makes its way via metal lines into the dash area of your vehicle to the evaporator core. This evaporator core is like a small radiator, except it has cold Freon circulating inside and not hot antifreeze. A small fan (the AC blower fan which you control from the control panel on the dash) sits in front of the evaporator core and blows air across this cold evaporator and then through the vents inside your vehicle.
The other objective of the air conditioning system is to remove the heat from inside the cab of the vehicle. This heat is removed by the Freon with the help of the AC condenser located at the front of the car (usually in front of the radiator). The Freon coming back from the evaporator carries the heat from the cab to the condenser via rubber and metal hoses. Just like your radiator, the condenser is lightweight aluminum with many internal winding coils.
The Freon travels through these coils, and in between these coils are small slits or fins that the Freon is forced through. The condenser will have an electric cooling fan mounted in front or behind it to push or pull air through these fins to remove the heat from the Freon. Some vehicles still use the old fashioned fan blade driven by the engine to pull air across the radiator and the condenser.
Now I know that is just a tidbit of information on how the air conditioning system works, and it is very general, but I wanted you to know what to look for to give you insight as to what might be happening with your vehicle.
A few causes of low cooling efficiency or no cooling at all at idle are:
Lack of air flow across the condenser. Make sure the electric cooling fan motor near the condenser is coming on, or in models that are equipped with a fan blade make sure this fan is turning and is turning very fast.
Low Freon levels. Freon level and pressure should be checked by your certified air conditioning mechanic.
Overheating. If the engine is running hot or overheating, it can have a noticeable negative affect on the air conditioning system. Some cars have two electric cooling fans, one for the air conditioning condenser and the other for the radiator. Make sure they are both working properly. Usually at idle on a hot day with the AC on both fans will be on.
When the vehicle is traveling at freeway speeds, the compressor is pumping the Freon throughout the system much faster and harder than at idle. There is a dramatic increase in air flow across the condenser due to 55 mph winds, and the engine is usually operating at a cooler, more efficient temperature as well, thus allowing the air conditioning system to operate efficiently.
Note: An air conditioning system that is somewhat low on Freon can still feel comfortable at freeway speeds due to the added air flow across the condenser which can overcome the ill effects of slightly low Freon. Periodic air conditioning performance checks by your mechanic are the best way to keep the system in great shape.
Hope this helps.
Goodluck
Oct 08, 2010 | 1998 Cadillac DeVille
My Delfield Freezer (f2fh) does not keep cold. I've cleaned the coil and completely defrosted the freezer, but it won't maintain freezing temps. It drops to about 12 deg then will go to between 45-60, then...
Possible solution to original question at top of page: Recently worked on a Delfield F2FH with the exact same problem. Would get to 12 degrees and then go up and down either to -10 degrees or up to 12 to 55 degrees. Although I cleaned the condenser coil of some dust it was not the problem. There was no icing of the evaporator either. The defrost timer was also working. There was icing of the lines coming off the compressor but this was simply a symptom of the real problem. After checking everything out carefully and talking more with the customer about how the unit was fluctuating in temperture I noticed something that I had not paid much attention to as a possible factor in the problem. It seems a previous technician had worked on the unit and was very sloppy in his work as he did not put many of the screws back in place after taking the unit apart. Two screws that he did not put back were the ones that secure the overhead outside front panel where the door switches are located. As a result the switches were only making a hap hazard connection with the striker pads on the top of the doors. Whenever the owner moved the unit or, wiped the panel or, even opened the door the top service panel would move slightly out of allignment causing one or both door switches not to contact the striker plates. This in turn shut down the evaporator fans inside the freezer compartment which then only allowed cold air to drift to the bottom of the inside of the unit. The temp control sensor, mounted inside at the top near the evaporator fans, was reading tempertures inside the freezer compartment warmer at the top as all the colder air was at the bottom. On this unit there was only about a half inch of tolerance on the door striker plates so if they were not alligned properly the fans did not come on. So, check your door switches and see if they are engaging. One or both of your doors may have dropped to low to fully engage your door switches due to worn bushing or hinges (each door will only turn half the fans on inside); your striker plates may be worn cracked or out of allignment; your top panel is loose and moving the strikers out of allignment. Don't forget to manually test the evaportor fans to see if they are all working. Do this by opening both doors and pressing both door switches. If the fans do not come on suspect a bad switch which controls the fans which failed. If all the fans come on the problem is in the contact of door to striker plate. If one or even two fans do not come on test the fan itself. The air must circulate insde to keep a proper temperture. I hope this was helpful.
hweyer@bellsouth.net Appliance Technician
Aug 13, 2010 | Delfield 032-F2FH ColdPro Solid Door Reach...
Delfield model #mrr2n-s ser. 0403036101321-t ice
can not immediately locate manual.
If this unit is a cooler, check this:
Anything that can effect air flow. Fans not running or running in wrong direction.
Too much product in unit.
Thermostat set too low or stickes and unit does not shut off unit.
Possibly has a defrost timer. Most coolers do not but some do. Look for one and see if it is working. Make a mark on the face and wait 15 minutes to see if it moves.
Drain pan clogged.
Doors not closing or seals not sealing.
these are the things to check out.
Aug 03, 2009 | Delfield (F18WC60) Commercial Refrigerator
Fan underneath frig is running but no cold air is coming into the frig or freezer
The fan that is under the frig is the condensor fan(the fan the cools the condenser coils and the compressor. It does not have a direct effect on the chilled air circulation inside of the frig. The evaporator fan is the unit that circulates the chilled air thru your freezer and frig. I am not sure what make model unit you have, but I have found that this fan motor is 90% of the circulation problems i have seen.
Jul 31, 2009 | Refrigerators
Freezer on bottom is working normally, but refrigerator on top is warm. The condensor fan is working, condensor is clean, compressor runs.
The condenser fan only circulates air around the condenser and compressor. There should be another fan that circulates the air around the refrigerator, it should be located inside of the freezer section at the rear. I would look for this fan and see if it is operating first.
Jul 19, 2009 | Refrigerators
Delfield 60 Refrigerated Work Top Model 4460N Logo
138 people viewed this question
Top Delfield Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Delfield Refrigerator Expert? Answer questions, earn points and help others
