Question about Acer Aspire 3000 Notebook
Screen is very dim
I have tried to adjust using Fn and left arrow key and tried using another monitor to see what's going on but no luck.
  • Jay Glendenning
    Jay Glendenning May 11, 2010
    So when you hookup an external monitor it is also "dim"?
  • 408 Answers
Sound like a bad inverter or the screen.The video card itself sounds like its ok.
Posted on Jul 28, 2009
Very dim screen image, have to see using flashlight ?
Have you tried holding the "fn" key and the F key that has an arrow up or light symbol on it?
Nov 17, 2014 | Compaq Presario CQ56-204LA Laptop Screen...
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Regards,
Rahul
Jul 15, 2013 | Computers & Internet
How to brighten screen on acer computer
Press and hold the blue 'fn' key and press and release the left/right arrow keys to dim/brighten the screen. It it the arrow keys on most Acer laptops that control this. If it's not the arrow keys, then look for keys with a picture of the sun on them. Press and hold the 'fn' key and then tap the 'sun' keys to adjust brightness. Please let me know if this helps or not.
Joe
Apr 09, 2012 | Computers & Internet
How do i adjust the contrast on my acer aspire 5738z laptop
@tonymclau330
Try the following:
For Windows Vista / 7
1. Press the Fn+Left Arrow Key for brightness down and Fn+Right Arrow Key for brightness up (the Fn key is located at the left side of the space bar)
2. If that won't work, go to Start > type Power Options and click on the Power options icon.
3. Adjust the screen brightness bar below.
Good luck.
Sep 07, 2011 | Acer Aspire 5630 Notebook
MY Laptop Screen Is Dim It Will Not Show Bright
When you say that your laptop "screen is dim", do you mean that there is no light coming from your screen, but you can see images on it? or do you mean that there is light coming from the screen, just a very little amount?
If you can images, but NO light is coming from the screen, then the LCD backlight is dead, and it needs to be replaced.
If there is light coming from the screen, but it's very dim, then you'll need to find the screen brightness adjustment keys on your laptop. This is usually two keys. The first one is normally in the lower left corner of your laptop and should be a different color - like blue or purple, and will be labeled something like "Fn". The second key is normally in the function key row (F1, F2, F3, etc...) and has a symbol on it that looks like a sun or burst of light with an arrow. There's usually one for "brightness UP" and one for "brightness DOWN". Hold down the Fn key, and then press the "Brightness UP" key a few times to see if the screen brightens up. Good luck.
Jan 14, 2010 | HP Pavilion dv1000 Notebook
Cant turn the brightness down on my asus netbook
You should be able to use the "FN" key and "F5" key, press and hold the "Fn" key then while holding that key, press the "F5" key to decrease the brightness. Use the same(Fn) key and "F6" to increase the brightness.
Jan 02, 2010 | ASUS Eee 4G Notebook
I need to lighten my screen
this is not a computer problem you have to press the buttons on your monitor that is a menu when the menu comes up change the brightness
Nov 14, 2009 | Averatec 7171000100 Keyboard
Dim monitor
I am assuming this is on your laptop display and not a monitor connected. If this is the case, you most likely pressed FN + the DOWN ARROW. You can use the FN key (usually on the left side near CTRL and/or ALT) in combination with the UP and DOWN arrows to increase/decrease the brightness. This is real handy when you want to have longer battery life as the lower the display brightness is the less power it uses.
Hope this helps,
Chris
Mar 23, 2009 | Dell Latitude D600 Notebook
Screen on Aspire 3000 is very very dim
Backlight or inverter failure sorry to say. No telling which without substitution. Backlights are mostly built into the top of the screen and are tricky to replace. Inverters are generally sited at the bottom of the screen under the facia panel. Look around ebay for replacements
Dec 09, 2008 | Acer Aspire 3000 Notebook
Acer aspire 5043wlmi laptop starts but know function of lcd but works on desktop monitor
The computer's power management system automatically dims the screen when using battery power, which is one of the power-saving features.
To adjust the brightness:
  • Hold down the Fn Key located at bottom left of your keyboard next to the Ctrl key, and adjust the screen brightness using the left/right arrow keys located at the bottom right of the keyboard.
If that's not it then
A dim or dark screen does not necessarily mean a bad inverter! It could be a faulty lcd backlight bulb, inverter cable, inverter, or in some cases a motherboard failure. If your still under warranty then I would get Acer support on the phone and see what they can do.
An Inverter converts direct current (DC) to alternating current (AC).
Jul 01, 2008 | Acer Computers & Internet
Acer Aspire 3000 Notebook Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
