Question about Belkin (F5D9230-4) Wireless Router (F5D92304)
Belkin router problem
I have connected up a belkin G+ router,i have secured it using wap.when i try to connect my wireless laptop to it, it says cannot be used with these settings.im using vista,i think i need to configure my client laptop but do not know how to do it. any help? .thanks
    Guru:
  • 1,049 Answers
VISTA and wireless don't go well together. First, I would disable your firewall, you can turn it on later when everything works and play with the settings, second use the hex value instead of the password key when logging into the wireless device, third try it both with windows managing the connection and with the vendor software. Some wireless prefer one or the other depending on their compatibility with the Vista virus.
Posted on Dec 09, 2008
My belkin router F5D8636-4v2(01) will only connect to the internet when the yellow cable is used the wireless light is off as is the security light also how do I put a security password onto the system...
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Jun 01, 2010 | Belkin F5D8631-4 Router (F5D8631au4A)
How to secure my wireless router?
http://192.168.0.1
or
http://192.168.1.1
or
http://192.168.2.1
May 31, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless G Plus MIMO (F5D9230-4) Router (1010835): can I set up WAp or Wap2 securety on win 7....
You can set up wireless security on the router.
If you have Windows 7 computer, you can use WPA or WPA2 security on the router.
It is better if you set up WPA. that will work with windows Vista anbd windows XP also.
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
Do not change any wireless settings on the router with the wireless computer.
you will need to connect the computer to the router with the Ethernet cable.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Now once you change the network anme and security on the router, you will need to connect to the wireless network on your wireless computers.
Click Here for step by step instructions
Apr 28, 2010 | Belkin Computers & Internet
I have a new laptop and lost my password to wireless router
http://192.168.0.1
or
http://192.168.1.1
or
http://192.168.2.1
Jan 07, 2010 | Linksys Wireless-G WRT54G Router
Router is in secure status so cannot be used by anybody. Friend sorted it out for my laptop to be able to use it but i cant figure out how to be able to allow my Wii and PSP to use it. Both occur errors...
For that you need to access your router configuration page.
Connect your router to computer then access it with following link.
For belkin router
http://192.168.15.1
for other routers
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then you can see configuration of router.
Click on wireless then check WEP or WAP key it is your password to connect internet.
Let me know if you need further assistance.
Thanks.
Nov 03, 2009 | Belkin (F5D7633UK4A) Wireless Router
I have a belkin pre-n 144880. I have WAP secured
It is because DHCP is not enable in belkin.
For that connect router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.15.1
type user as "admin" and password as "admin" or blank or "password".
Then go to advanced and enable dhcp .
Then save and restart router.
Thanks.
Oct 29, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Belkin Nimo wireless router internet drop outs
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? Ie. change the default password, setup encryption use WAP2 or WAP, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, ard welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply) .
4. Check the channels of the wireless routers and access points in your area and and change the broadcast channel on your wireless router to an unused channel or one that has the weakest signal strength. This will minimize the interference with your wireless router from the wireless routers and access points in your area.
Sep 29, 2009 | Belkin (F5D5231-4) Router
Wireless
Have you configured the Belkin wireless router?
You need to configure the Belkin using a 10baseT network cable first before you configure the wireless card.
To make your wireless router secure you need to use your browser and type in the Belkin IP configuration address.
Then you need to change the Admin password, change SSID and turn off SSID broadcast, setup the encryption (use WAP or WAP2 if your wireless card supports WAP) and for added protection use MAC address filtering.
Apr 12, 2009 | Acer Computers & Internet
Belkin wireless security
plug a laptop straight into the router with a cable. then open an internet browser and type in 192.168.0.1
type in the username and password. the default will be admin for username and password for password. then close the browser and unplug the cable. it might detect wireless internet after a few seconds. if it doesn't, it is possible that you have a PC set up as the internet gateway for the laptops or something, so when you introduce encryption the laptops can't get access. in which case you should go to your wireless icon on the laptop and click that and open the connection list. double click on the wap secured connection and try to connect. it should ask for a username and password, which you have secured the wireless encryption with. enter that and it should connect to the gateway.
dunno if this helps, good luck
chris
ziraffa@hotmail.com
Dec 10, 2008 | Belkin (F5D9230-4) Wireless Router...
Wireless connection
Try setting up initially WITHOUT any WAP key, IE: UN-secured etc... when ya connected THEN add a key etc..
au.playstation.com/support/ps2/wizards/ps2_wizard_ng_routerconn.jhtml
Try this troubleshooting link above.. Remember Google is your friend ... :)
Jul 28, 2008 | Toshiba Satellite A205-S4617 Notebook
Belkin (F5D9230-4) Wireless Router (F5D92304) Logo
79 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
