Question about Ahead Software Nero 6 Ultra Edition (2434nl20) for PC
Recording on nero 9
I am having a hard time track split mode, once I enter it it will not move
Wowwwwwwwwwwwwwwwwwwwwwww
Posted on Dec 10, 2008
How can i recall multiple laps during a run?
The Timex Ironman 30 Lap also has a stopwatch that can be used to keep track of split times for racing sports like running or cycling. Press the "Mode" button until the display shows "Chrono," then press and hold the "Set/Recall" button. To start the timer, press the "Start/Split" button. It will continue to run even if you exit to another mode. Pressing the "Stop/Reset" button will stop the chronograph. To record a split time, press the "Start/Split" button again while the timer is running. To see your split times, press the "Set/Recall" button while the watch is in Chrono mode. You can then scroll through the various splits with the plus and minus keys. Press "Set/Recall" again to exit display mode and return to the timer.
Sep 17, 2009 | Timex Ironman 30 Lap 53952 Wrist Watch
Im trying to records mix cd but isnt changing
• To switch off the Auto Track function you have to enter
Menu mode.
If you wish to increase track numbers manually, press
TRACK INCR(ement) on the remote control. For further
instructions see Menu mode.
ON (AUTO): The track increments are automatically taken over
from the digital source material or after 2.7
seconds silence during analog recording.
OFF (MANUAL): While recording track numbers can be
incremented manually by pressing TRACK
(Minimum track length is 4 sec.) (This can
also be done in Auto track ON mode.)
May 01, 2009 | Philips CDR770 CD Recorder
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
Recording midi player
Yes. You can record the midi output to a track using bounce mode.
With you midi (or smf) file loaded into the midi tone generator,
press shift-bounce to enter bounce mode. Then arm a track for recording. Turn the fader up for that track, the master fader and the fader for the midi tone generator. Make sure than all other track faders are down or the tracks are muted (or empty) and press play and record. The midi song will be recorded to the track in real time. Just press 'stop' when done and exit bounce mode (by pressing the bounce button again).
bd.
Jan 12, 2009 | Tascam 2488 Portastudio Multitrack...
How to activate my licence for nero 9
Is the Nero 9 your using been purchased legally?
Generally, once you hit the activate button it will activate. When I bought my Nero 9 it asked me activate several times on different Nero programs i was using. But, once you hit activate you wont need to hit it again for that particular tool.
Make sure your firewall isn't blocking the connection, 'ADD' Nero as a trusted program if your using a external firewall other than the windows basic.
Oct 31, 2008 | Computers & Internet
Can't Get My Music Off My Tascam. I have a DP-01 portastudio and it has a usb connection but it's not being recognized by my computer. At first it just wasn't compatible with Vista now I have windows xp...
How to export your recorded tracks to WAV:
- Activate the Menu
- Scroll down to WAVE
- Press the right cursor key
- Go to Export Track
- Select the tracks using the Insert and cursor up and/or down keys
- Press Yes/Enter
- When the DP-01 is done repeat pressing Exit until the menu is closed.
Tascam USB mode:
- Press Menu
- Go to Disk
- Scroll down to USB OPN/CLS
- Press Yes/Enter
- Press Enter again to execute
- Press Yes/Enter again for the "Are you sure?" message
Now you will be in USB mode and you will be able to access the DP-01's hard drive and download the exported WAVE file(s).
Remember: the DP-01 will stay in USB mode until you remove the deviceusing the Safely Remove Hardware option in Vista and then press Exit onthe Tascam!
Oct 18, 2008 | Tascam DP01 All-In-One Recording Package...
The one for all remote control model urc-7562 funtion on the menu doesnt work what could be the problem?
Hello Stephendo394:
Here are some advanced codes that were found on Remote Central.com web site.
003 Menu
004 Timer Recording
010 Timer Recording
024 Shutdown
026 Shutdown
036 Skip 30 sec
039 Next Page in Menu/Next Track in Play mode
041 Previous Page in Menu/Previous Track in Play mode
043 Time Slip
053 Record
055 Play
061 Right
065 AV
070 NTSC/PAL
076 Language Right
080 Language Left
084 Source
091 Source = SD
100 Playlist View
101 AV
105 Tape Speed
106 Advanced
116 5
117 1
118 7
119 3
120 6
121 2
122 8
123 4
124 Setup
127 Picture Info
140 ?
146 Record
148 Channel Down
152 Channel Up
162 HDD Management
164 Delete
178 Record Flexi-Mode
179 Source = DVD
180 Rewind
181 Returns to Menu
182 Pause/Play
183 Rewind
184 Forward
185 DVD In/Out
187 Forward
189 Context Menu
191 Enter
192 Up
193 Return
194 Left
197 Guide
198 Info
215 ?
219 ?
229 Create Chapter
230 ?
234 Display
245 9
249 0
Aug 20, 2008 | Televison & Video
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Ahead Software Nero 6 Ultra Edition (2434nl20) for PC Logo
18 people viewed this question
Top Ahead Software Computers & Internet Experts
Martin Murray
Tony
Are you an Ahead Software Computer and Internet Expert? Answer questions, earn points and help others
