Question about Husqvarna Rose
All of the design stitching in half the space
AFTER pushing the 4 corners button ( to see where the borders are) the design only stitches out in less than half the space. Yes, it had stitched out correctly previously, and yes, when the 4 corners button was pressed it looked like it was only going to go in half the space.
    Novelist:
  • Husqvarna Expert
  • 371 Answers
Service time by an authorized Husqvarna Viking service technician. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Posted on Feb 13, 2010
How do I do a basic satin stitch ? My machine only has patterned satin stitches
A satin stitch is a combination of a wide zig-zag and a short stitch length. Set the stitch width to the maximum. Then while stitching, shorten the stitch length until the threads lay next to each other so no fabric shows between the threads but the threads do not overlap. It would help if you have a satin stitch foot so there is space under the presser foot for the extra threads.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Satin Stitch or Zig Zag Machine Applique stitch
Machine Appliqu Basics 1 Turning right angle corners with satin stitch
Mar 23, 2018 | Sewing Machines
The User Manual does not have a complete stitch guide. Does my Huskystar 207 have a stretch stich?
FWIW, a stretch stitch is simply a stitch that stitches forward a few stitches and then reverses for a couple and then stitches forward again. Having had a machine with a stretch stitch, I found that using a zig-zag is just as effective and uses much less thread as well as less time at the machine. If the fabric is very stretchy, you can merely decrease the stitch length and increase the stitch width to give the stitch enough space to expand with the fabric without popping.
Viking Huskystar 207 Manuals
Jun 22, 2017 | Sewing Machines
How do I fix loose stitches without having to start over?Loose on the left hand border. I now how 6 by 4 foot . Just learned how to crochet 3 weeks ago by watching a video. Help !!
There is no way to change the stitches without starting over, but depending on what it is you are making, you could incorporate the loose stitches as a design feature, for example by adding crochet over top of stitches like is shown in the video below.
https://www.youtube.com/watch?v=SFJ8-r7C2e8
Feb 20, 2017 | Sewing Machines
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Feb 19, 2017 | Sewing Machines
I want to sew reverse for a few stitches to do a miter corner. how do I reverse stitching.
Usually there's a button in the center of the stitch dial you can push in to reverse it. Hold in to reverse, let go to keep going froward.
Mar 12, 2015 | Sewing Machines
Easiest way to make a buttonhole...manual does not tell much info
Easiest way is to create a bar tack at one end of the buttonhole (widest stitch width and stitch length set to 0). Stitch maybe 4 or 5 stitches.
Then move needle all the way to the left, set stitch length to very short (maybe somewhere between 0 & 1), width to slightly less than half, stitch forward to the end of the buttonhole.
Then make another bar tack (as above). Move needle all the way to the right, set to less than half width, short stitch length, and stitch in REVERSE to first bar tack. To tie off, set width to 0 and length to 0 and stitch 2-3 times in place. Raise presser foot, pull gently on fabric and clip threads.
Set zig zag stitch on Elna Elina 40
I have looked but can't see a manual, but looks like push button stitch selection on front of machine, often it will be same as straight stitch, but need to take stitch width from 0 to 4
Feb 27, 2015 | Elna Sewing Machines
My machine will not zigzag. Width setting on on1 length setting on widest
You need to take the width setting up to 4 and length down to 2 or less if you want a close zig zag. You may not want it that wide but usually 4 is the maximum width.
There is probably also a stitch selector if your machine has several stitch patterns it can do. I've looked at an image at http://www.stevekraftrepair.com/uploads/resized-P9200750.JPG and it looks to me like the left hand knob on the front of the machine is the stitch selector and is colour coded in with the images on the front panel. I just can't make out which number is the zig zag, it could be the red number 4??? So you would put this dial onto the zig zag, then turn the other dial up to a wider stitch width and I am guessing that the little blue box lower down the case has the reversing button and the stitch length setting.
Usually it pays to turn the width to zero BEFORE you make changes to the stitch selector, most machines seem to like being treated this way, ie engaging cams inside the works.
Also, it is always a good idea to check what foot you have on before you start sewing a swing needle stitch just to make sure that you don't hit the foot with the needle. Some feet are designed for straight stitch only and have a little hole but obviously this is not going to work for a zigzag stitch.
I hope this is of help and that I have understood your problem.
Jun 11, 2011 | Necchi 3537 Mechanical Sewing Machine
Viking Designer 1 won't stitch correctly
Check that twin stitch width safety is not turned on in the SET menu (use More button at bottom of first screen to access third screen).
Jun 19, 2008 | Husqvarna Designer I
How do i make a buttonhole on this machine?
I do not have a buttonhole foot, but I can tell you how I do it with the zig zag foot on the Singer 132Q machine.
1. Mark the spacing and size for the buttonholes with chalk or marking paper. This consists of a straight line with a perpendicular line at the top and bottom that lets you know how big to make the hole. There is probably a pattern piece to let you know what the spacing should be, and you can get the size of the hole for the top and bottom line by laying the button you are going to use on top of the line you draw with the pattern.
2. Make sure the bobbin has plenty of thread.
3. Put the zig zag foot on the machine.
4. Set the stitch size to 1 or maybe a little less. You want a tight stitch to hold the hole together.
5. Start at the top of the buttonhole with the perpendicular line barely visible in the zig zag foot. Think of it as placing the "T" made by the mark in the "T" made by the opening in the zig zag foot.
6. Set the needle pattern to #1 of the buttonhole pattern (2nd from the top). Make sure it is toward the top of the number to insure you get a wide zig zag stitch. If you are getting a narrow stitch, you may have to fiddle with it, but it will work. Stitch 4-6 times making sure the stitch is wide, and end on the left side of the stitch.
7. Change the needle pattern to #2 of the buttonhole pattern and zig zag stitch down to the bottom mark. Do not pull the fabric or you will stretch the stitch. Make sure your last stitch is on the left hand side.
8. Change the needle pattern to #3 of the buttonhole pattern (same as #1), and zig zag stitch 4-6 times ending on the right side this time. Make sure the stitches are wide.
9. Change the needle pattern to #4 of the buttonhole pattern and straight stitch back to the top mark. Be prepared to hand roll the needle the last few stitches to make sure you do not pass the top stitches you have made.
10. Change the needle pattern to #5 of the buttonhole pattern and zig zag stitch back to the bottom mark. Hand roll the last few stitches and end on the left side.
11. Raise the foot and remove the fabric. You are now ready proceed to the next buttonhole or cut the buttonhole open with a small pair of scissors or a seam ripper. Make sure you do not cut any of your stitches.
Make sure you practice on some scrap fabric of the same thickness (2 layers of fabric plus pellon) to make sure you have the size right before you sew the buttonholes on the garment.
GOOD LUCK.
Aug 28, 2007 | Singer Featherweight 132Q Mechanical...
Sewing Machines Logo
46 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
