Question about Cambridge Soundworks P200 Subwoofer
I have a cambridge soundworks sub and all was well until I moved it and thinking if I had the correct output from my marantz recer to the sub. Before I used two coax with rca phono jacks. Now it has blown 6 fuses, 3.5 amps, 250 volts. Does the sub have to be up right to keep the fuses from blowing.
  • mlp51 Apr 23, 2009
    my cambridge soundworks subwoofer 12 is in protection mode. how do i get it out of protection mode?
5 Suggested Answers
  • 7 Answers
SOURCE: Cambridge Soundworks Basscube 12S only makes pulsing buzz noise
Hey! So i fixed my problem! This is for the BassCube 10
Like i said before i saw that the circut board was burnt near the diodes ZD3 & ZD4, and the resistor R63. Thanks to Deadly1 and BillRad62, i figured it out. The R63 is a 1200 resistor, and the diodes are 15v zeners. I went with 3x 5.1v zeners to replace ZD3, unfortunately Rip-Off-Shack (Radioshack) didnt have 3 packs of these so for the ZD4 i put a 12v and 5.1v. Which exceeds 15, but seems to work without a problem. Hope it helps!
Posted on May 26, 2009
  • 127 Answers
SOURCE: cant connect jamo sub 250 to marantz SR4001
Use the PRE-OUT SW (subwoofer) output and connect it to the left RCA socket of your subwoofer.
Posted on Mar 03, 2010
mc1bean
  • 3053 Answers
SOURCE: How can I replace a
Its pretty simple actually.
If you already have the same size new tweeter. You take off of course the large felt cover so speakers are exposed on front. Just like your picture is in this post. Then you should see some screws, most likely it is going to be Phillips. Then unscrew all the screws, the whole front should slide out with of course speakers still attached, don't pull out to fast or far, to make sure the internal wires are long enough to take whole front out and set aside speaker box, the on back of speaker should be two wires going to it, maybe three if is tapped in conjunction with a ground. Anyway on back of speaker unplug the wire from speaker and then, take out screws which is normally on back of speaker, pull speaker out, put new one in and repeat steps in reverse order. Hope this helps. Mike
Posted on Jul 07, 2011
idrvnsx2
  • 60 Answers
SOURCE: I believe that the amplifier
Edwards Electronics on ebay repairs these amps - contact them for pricing ;)
Posted on Aug 27, 2012
I need circuit diagram for Cambridge Soundwork Slim 500 model. Where I can find it?
    Cambridge Soundworks circuit diagram cambridge audio a1 ...
    www.fixya.com > ... > Tags > circuit diagram cambridge audio a1 mk3
    Ask your Cambridge Soundworks circuit diagram cambridge audio a1 mk3 questions. Get free help, advice & support from top Cambridge Soundworks experts. images for circuit diagram for Cambridge Soundwork
Jan 05, 2016 | Audio Players & Recorders
Owners manual for a ensemble 3 sub woffer
Try http://www.manualslib.com/manual/220406/Cambridge-Soundworks-Ensemble-Iii.html
Feb 04, 2015 | Audio Players & Recorders
I have used the sound test to check my CS 5.1 system. When I test the subwoofers, there is no sound. I have played CDs with deep bass, no sound is emitted from the subwoofers. I have T-500...
One step at a time. Get the subwoofer to work, THEN play music through it.
You don't describe the electronics, IF you have a sub defined, whatever other steps it probably needs to pass LFE to the sub.
Register and download the manual for free at retrevo.com
Page 7
http://www.retrevo.com/support/Cambridge-Soundworks-T500-Speakers-manual/id/522bh631/t/2/
Apr 29, 2011 | Cambridge Soundworks Newton Series T500...
Lost Speaker Sound
It does sound like a connector issue, don't you think?
What happens if you DON"T touch the connector but move the volume control on the controller?
Have you tried looking outward toward the source?
Mar 30, 2010 | Cambridge Soundworks P200 Subwoofer
Subwoofer does not kick in during stereo mode with front speakers
There should be an adjustment in setup that for 2 channel sources, you may have to enable the subwoofer output. Or alternatively, if the subwoofer output for 2 channel sources is in fact enabled, then increase the crossover frequency for the sub.
May 07, 2009 | Audio Players & Recorders
CD won't eject from our Cambridge Soundworks 740 system. Help.
Unplug the unit for 10 mins. Plug back in then hold the CD In button until it reads "RESET".
Mar 28, 2009 | Cambridge Soundworks CD-740 In Stock Shelf...
No volume
do they plug in with a 3.5mm audio jack?
if so, i think you need to check your drivers for laptop output socket.
have you tried output with any headphones etc? do they work on laptop?
Feb 25, 2009 | Cambridge Soundworks SWBL SoundWorks PC...
Fluctuation in sound output on Cambridge Soundworks 5.1 speakers
Hi Paulus
A lot brand of speakers, like Sound Blasters, Logitech, Cambridge, has this (strange) kind of volume problem, sometimes, is the resistor, in the volume control, sometimes in the modulator for the board on the sound speakers, Subwofer.
I use a general tip is let the volume in one setting and don't move in the intermediate low volume say....9 .
from other thing, be change the speakers.
Nov 25, 2007 | Cambridge Soundworks Movie Works 108...
Home theatre sub
Sounds like a ground loop issue. Try plugging your sub, and the rest of your entertainment equipment into the same outlet with an extension strip (4 plug adaptor). If there is too much stuff to plug into one strip, experiment with combinations and hopefully you will find which piece of gear is the culprit.
Aug 28, 2007 | Cambridge Soundworks BassCube 12 Speaker
Cambridge Soundworks P200 Subwoofer Logo
88 people viewed this question
Top Cambridge Soundworks Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
 Grubhead
Grubhead
Are you a Cambridge Soundworks Audio Player and Recorder Expert? Answer questions, earn points and help others
