Question about EliteGroup P6IWP-Fe Motherboard
P6IWP-Fe power up problem
Hi
I'am in big trouble. Can anybody help me with my PC with P6IWP-Fe mainboard. When I turn on the power after about 3-4 sec machine turns itself off. There is no healthy "beep" signal on start up. HDD and power supply are changed. Any sugestions ?
Thank You!!!
Regards
Arthur
    President:
  • 2,110 Answers
Try to change RAM first..if not worked then the processor ...
Posted on Dec 09, 2008
#1. The heat bond between the processor and heat sink fails (Cracks) and the CPU overheats and powers down. Pop the CPU straps use a razor blade to scrap of the tin bond off put some heat sink grease on the CPU and reinstall.
#2. Check and replace the switching caps for the Core and 5 Vdc. Replace the caps left of L8, 1000 Mfd @ 6.3 VDC. EliteGroup used a low grade cap. The high ESR heats the caps and kills them. If you do not have a in curcit ESR meter, look for a rounded top on the cap and replace it.
This has fixed 9 out of 10 boards. Digikey has good low ESR caps you can order.
FredCollinsIII@EarthLink.net
Posted on Apr 21, 2009
Arthur,
If, buy chance, you still have the mainboard....I think I can help you out.
Let me know,
Jay
Posted on Mar 22, 2009
Email to: nisann@gmail.com or call: 973-625-4680
Thanks,
Nisan
Posted on Dec 20, 2008
Supports processors
go to this webpage
http://www.ecs.com.tw/ECSWebSite/Product/ProductArchive.aspx?CategoryID=1&MenuID=24&LanID=0
Identify your m/b - there is a ver 1 and a version 2 of the P6IWP-Fe. near the bottom of the linked page, which seem to blank, there some tabs; click the one labeled CPU. The list of supported CPUs will appear below (scroll down to see them) with the earliest BIOS version to support the CPU in the RH column.
May 30, 2014 | EliteGroup P6IWP-Fe Motherboard
P6IWP-Fe rev 2.0 the computer detects ports but when I connect any USB memory does not even recognize any connected device not I opened the cpu and some of the capacitors are split and I wonder how I can...
i dont know about fixing the capacitors
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=280406610810&ssPageName=STRK:MEWNX:IT$1+$2.46 postage worldwide
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
Aug 31, 2011 | EliteGroup P6IWP-Fe Motherboard
P6iwp-fe max processor support ram max support
Intel PentiumIII, 512mb RAM max. an old board!
Jan 11, 2011 | EliteGroup P6IWP-Fe Motherboard
Image for first 3 secs... light still on green
correodemie, Your ACER AL2016 will need to have it's "switch-mode-power-supply/CCFL inverter supply" trouble shooted and repaired. DIY repair cost less than $30. Out of warranty service $35 to $75, more if circuit board replaced. Read my and other techs FIXYA profiles to discover all the options you have for your BLACK screen symptom. Follow the links to other web sites for even more useful info. DO THAT before you do anything else. 12fixlouie
Feb 03, 2010 | Acer AL2016 W 20" TFT LCD Monitor
"Battery Empty" Message
extra dose 12V power pinch for 3 sec
Jun 18, 2009 | Olympus FE-20 Digital Camera
Motherboard manual
There's two versions of your motherboard listed version 1.0a and version 2.0 i've listed the links for updated software, drivers, bios and manuals for both, though version 1.0a doesn't have a listing for a downloadable manual it has all the other bits and pieces, i've also listed the link to help you identify which version your mainboard is:
software,drivers,bios etc, ver 1.0a:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=95&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
software,drivers,bios, manuals ver 2.0:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=210&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
version ID help:
http://www.ecs.com.tw/extra/productinfo/MB.htm#ver_mb
Hope this helps you out
Nov 01, 2007 | EliteGroup P6IWP-Fe Motherboard
No sound, No video, power LED blinking 3 times
had the same problem with mine and I replaced horizontal deflection transistor located by the high voltage tranformer, its the big transistor by the heatsink, check for any shot and replace if you find problem. worked for me
Apr 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Olympus FE-100 camera
well the mainboard is off, send it to a repair centre to be replaced.
Apr 02, 2007 | Olympus FE-100 Digital Camera
EliteGroup P6IWP-Fe Motherboard Logo
342 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
