Question about 2wire Wireless-G 802.11g ADSL Gateway
Connecting ATT 2wire to Acer Computer
I recently got the ATT DSL which comes with a 2wire modem/router. Setup on my desktop went smoothly but when I tried to connect via wifi to my Acer it would only let me connect via the wifi connection options on my Sprint USB modem. It would not let me set up via the connection options on the computer itself. The signal strength is not spectacular - about 40% to 60% strength. I suspect that if I could connect via the computer itself, connectivity on the laptop would be better. Help!
  • kfiawo Dec 09, 2008
    No software available for the router unless you're referring to the Sprint modem
  • 2,460 Answers
Is the Sprint USB modem a Sprint card? Do you have both of them plugged in at the same time?
I'd like to tell you that 2wire router/modems are easy. They're not, but what you have is pretty basic. I've seen, and I still have, the 1800 box give out two sets of IP addresses, one for wireless and one for wired. Let's hope that is not the case.
Plug your laptop into the router with a cable and don't plug in the USB modem. When it comes up, drop into DOS (Window R run cmd) and type IPCONFIG /ALL. You will be given an IP and Gateway. If it starts out 192 or 172, then you are connected to the 2wire. If it starts 169, you aren't.
Go into the wired connection, by right clicking My Network Places, highlghting Properties, and left clicking. It should only bring up the LAN card, since you didn't plug in the USB modem. Take a look at the info for the LAN card. Is it enabled? If not, repair the LAN one, if it is, right click on it, highlight Properties, and left click again, opening a window that has TCP/IP v4 or just TCP/IP.
Highlight that, and click on Properties again. It will open up the window where you can check the boxes for Obtain an IP address and DNS servers automatically. Check those and click O.K.
Now here's the worst part. If they already were checked, this probably won't fix it. I have an 1800 series on my bench and access to a 2701HG. Post back your model number as a comment and I'll go into programming.
I'm guessing that pulling the USB modem card and checking Obtain DHCP automatically on the LAN card will fix it.
Carl
Posted on Dec 09, 2008
    Sergeant:
  • 399 Answers
Check out whether u r using proper cable between the two.also replace the cable if its very old.u can get the cables at radioshack.
  • 4,806 Answers
So what you are saying is that your laptop will not connect to the wireless router with its built in wifi card?
if your using Vista, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the + sign next to "network adapters" and right click on the wireless network and "uninstall" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again
regards
  • Lee Hodgson
    Lee Hodgson Dec 09, 2008
    Ginko its called networking m8 lol
  • 837 Answers
How far away from the router are you?
  • 107 Answers
Are you using a router for the wireless or is it built in? Also If you can connect the laptop via ethernet I can remotely assist you, see my page here for that and mention this post and I will not charge you.http://www.crossloop.com/EricMitchell
    Genius:
  • 1,550 Answers
You have not properly installed the software on the laptop . Thats why you have a signal strength very less . Try installing the software properly with proper settings .
  • 19,396 Answers
To connect through the computer you need to use an ethernet cable, please provide more details, the problem is not clear.
  • Ginko
    Ginko Dec 09, 2008
    The laptop cannot connect in a n efficient way through the computer, the router is already a computer. The modem can be separate from the router.
    You need to setup the router using a LAN cable, then connect directlyu to the router using the laptop wi fi, that is the way it works.
    I do not understand what you mean by connecting rhe laptop through the computer.
  • Ginko
    Ginko Dec 09, 2008
    If the Internet and the wireless is working, do not change any settings , just explain what you want to do.
    Connecting through the computer instead of connecting straight to the router can be done, by setting a proxy internet connection, but this will be slower and you need a wifi card that supports access point mode on the computer.
    If the sygnal is weak , test that you are connecting to the right network (not by default to a neighbour's one) , that the router antenna is not unscrewed, and that there is no obstacle between the router antenna and the laptop wifi.
How to install to att 2wire 2701hgb modem router
Plug power cord into back of modem and then into an electrical outlet. At this point you should see the lights on the front of the modem beginning to come on.
Check the front of the modem for a solid green DSL light. If the light is still blinking, allow a few more moments before proceeding to step 5. A blinking DSL light indicates a break in the network and will require the help of your service provider if it does not turn solid green.
Open your internet browser and type the default gateway into address bar. The default gateway will be provided by your service provider. Newer model 2Wire modems automatically direct you to the installation instructions when the browser is opened.
Click on "Run System Setup Wizard" in the lower right-hand corner. It may require the system password. This password will be provided by your service provider.
Select your timezone and click 'Next.'
Enter your ISP provided login information and click 'Next'. This should authenticate your credentials on the network and complete the installation.
Jan 02, 2013 | NetGear RangeMax Dual Band Wireless-N...
I have an at&t 2wire 2701hg-b but i dont have at&t internet i have charter and i am not able to figure out how to get my internet to work with this router please help
att 2 wire is a Adsl Modem (Requires a telephone line jack to get the signals) but charter communication is a cable internet service (not DSL) , Requires a TV cable service for internet .
These two jacks differs and there working differs ..
Means : Att works with the username and password type of authentication but charter requires the MAC address of modem for authentication .
Therefore for a cable internet 2wire 2701hg-b modem cant be used . But yes in case charters has username and password authentication and works with the telephone jack in house then its possible to use the same modem.
Aug 19, 2011 | 2wire (2701HG-B) Wireless Router
We have 2 desktop pc's. One in one room and the other in another room on the far side of the house. Both are connected to the same telephone line. The 2wire homeportal 100 hg died and I went to Radio Shack...
well in a hard spot if your using dialup as means of connecting to the internet then only one PC at a time can use dialup connections now if say it was a DSL modem then from the DSL modem or DSL Router Modem you would need RJ-45 cables from the DSL router modem to the two PCs
Apr 22, 2017 | 2wire HomePortal 1000HG DSL Modem and...
Hot to make my gateway 2700hg-d modem/router
you just need to things for ATT your user name and password that you registered to them. Then you need to get inside the 2wire by using the IE or Mozilla. On the address bar, type in 192.168.1.254. Inside you will see there setup then just follow the prompt but if you got lost on the process just call att dsl
Mar 07, 2010 | 2wire 2700HG-B Router (2700HGB)
Att dsl internet on deskop and want wireless for my laptop
Yes you can buy a different DSL modem and that should not be a problem , then once you have the new DSL you just contact ATT and they will set up the settings on it...
Oct 09, 2009 | 2wire 2700HG-B Router (2700HGB)
I went from a ATT dsl modem to a net gear modem and i cannot get the net ger mode and linksys mode to talk to the computer
Most DSL providers use PPPoE (Point-to-Point Protocol over Ethernet) to establish Internet connections for end-users. To set up a Linksys router, you need to enable PPPoE on the router’s web-based setup page.
To setup a Linksys router with a DSL connection you need to perform four steps:
  1. Verifying Internet Connection
  2. Connecting the Devices Together
  3. Checking the LEDs
  4. Setting-up a DSL ISP on a Linksys Router
Connect the Broadband modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If not, contact your Internet Service Provider.
Aug 01, 2009 | Linksys Wireless-G Broadband Router
Can I use AT&T 2WIRE 2701HG-B DSL to ant ISP?
look if u wish to go for verizon service,,they will provide u with a wireless modem as well,,but if u tell them that u hav a modem then they might configure this modem only,,both ATT and verizon are DSL service providers with PPPoE connections.the only thing u need is the username and passwrd from verizon which u have to setup on the first page of the 2wire setup page,,both the connections are dhcp based.so no other connection settings change required.But when u talk with verizon make sure u tell them of the 2wire modem
Moreover verizon has wireless broadband service which is actually a express card tat u have to put into your computer and u can go online anywhere u go within ur country{it works like a mobile phone}
best of luck,,keep me posted
May 14, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
2wire att dsl modem/router on vista
Connect your DSL to wireless router and enable automatic ip on wireless. check whether DHCP is enable in DSL router or not.
Apr 24, 2009 | 2wire 2700HG-B Router (2700HGB)
Connecting ADSL wireless modem router to COMCAST
unfortunately you can't because the 2wire is a dsl modem it has to use the phone line to connect to the internet, it would be different if it was just a router but since it is a modem it needs that connection to the phone line in order to work
Oct 15, 2008 | 2wire (1000-400108-001) Router
CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Sep 06, 2008 | 2wire (1000-400108-001) Router
Open Questions:
See all 2wire Wireless-G 802.11g ADSL Gateway Questions
2wire Wireless-G 802.11g ADSL Gateway Logo
129 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
