Can't get the closed caption on my orion 13 inch tv
The menu only has channel set up , picture, language and v chip. I cannot find how to get to the closed caption. My remote has a closed caption button but nothing happens when I push it. It is not the original remote.
My t v sound went a week ago so i tried putting my caption on but cant find it model # 27pt543537a
Posted on Feb 18, 2009
  • 60 Answers
You need original remonte control to do that if in the front panel of your tv dont have menu button
Posted on Dec 10, 2008
On an orion tv, how can i get channels after 13??
In the menu, find antenna/cable. Locate cable and program from there.
Dec 20, 2014 | Orion1934 19" TV
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
How do I get closed captioning on a Samsung TV model TXJ2754?
Hello
Your TV displays the closed captions that are broadcast with some
television shows. These captions are usually subtitles for the hearing
impaired or language translations. All VCRs record the closed caption
signal and most pre-recorded commercial video tapes provide closed
captions. Check for the closed caption symbol in your television
schedule and on the tape's packaging: .
1 Press MENU repeatedly until you see the Setup menu. Press CH
to select "Caption."
2 Press VOL+ to open the Closed Caption menu.
3 Press VOL + to turn closed captioning on.
Misspellings and odd characters can occur in captioning. Also, there may be a
captioning delay after changing channels. Neither situation is a TV malfunction.
4 Press CH to highlight "Mode." Press - VOL or VOL + to choose
"Capt." (captions) or "Text." In caption mode, captions appear and
cover a small portion of the picture. In text mode, information unrelated
to the program, such as news reports, are displayed and
often cover a large portion of the screen.
5 If you wish, use CH , CH , or VOL + to change the captioning
channel or field. Then, press DISPLAY to return to normal viewing.
 Different channels and fields display different information, such as additional
languages or supplemental information
Nov 23, 2010 | Samsung TXJ2754 27" TV
My TV seem to be on wide screen and it shows half the picture, how do I set it up on full screen? No other material is connected to the TV
Hello
If your TV displays a black box type shade on the screen means that your TV may be set to "Text" mode. To clear the screen, select "Caption Off mode".
To do this, press "MENU" button to display menu functions on the screen. Press "channel up or channel down" button to select the function "CAPTION". Press "Volume Up or Volume Down " button to select the mode you wish. There are five modes that you can select; Caption-Off; Caption-C1; Caption-C2; Caption-T1 and Caption-T2. As no other matereial is connected to your TV, you just select "CAPTION-OFF". When done press the Menu button again to exit menu display. Ok.
Oct 22, 2010 | Durabrand DWT1304 13" TV
Need to know how to put the tv on close caption
Captioned programs are marked in TV listings by "CC". so press the cc button on the remote and the closed caption option will be applied.press that cc button again to turn off the closed caption option.
1) Check the size and manufactured year of your television. If it was made after 1993 and is larger than 13 inches, it has a closed captioning system built into it. Otherwise, you may need to purchase a separate closed caption system, which are available at a number of online outlets.
  1. 2)Turn on your TV and access the menu for closed captioning. The precise location of the menu varies by television set. Most are accessible by pressing the "Audio" or "Set Up" menu on your remote, then scrolling down to the "CC" or "Closed Captioning" option. Check your owner's manual for precise instructions.
  2. 3)Turn the closed captioning option to the "On" position. It will then run closed captions for every program that broadcasts them. Newer sets may allow you to adjust the size, font and colors of the closed captioning letters to fit your individual tastes.
  3. 4)Tune to a particular program for a few minutes to make sure the closed captions are working. Note that while many broadcasts run closed captioning, not all of them do. If the captions don't appear, check your TV listing to ensure the program includes them.
  4. 5)If you're watching a DVd on your TV, access the DVD's "Set Up" menu. It should have captioned options, which allow you to show captions in English and possibly other languages as well.
  5. thanks.
Nov 11, 2009 | Televison & Video
Cannot turn CC off.
Features preferences
Caption service
This allows you to select the Closed Captions service levels of analog
broadcasting to be displayed.
Closed Captioning allows you to read the voice content of television
programs on the TV screen. Designed to help the hearing impaired, this
feature uses on-screen ‘text boxes’ to show dialogue and conversations
while the TV program is in progress. Captions will appear on the screen
during captioned broadcasts.
& Select Captions service.
é Press the cursor right.
“ Select the desired Caption service:
• CC 1, 2, 3 or 4
Dialogue (and descriptions) for the action on the captioned TV program
shows on screen.
Usually CC 1 is the most used. CC 2 may be used for alternate languages
if they are being transmitted.
• T 1, 2, 3 or 4
Often used for channel guide, schedules, bulletin board information for
Closed Captions programs, news, weather informations or stock market
reports.
Not all Caption services are necessarily being used by a TV channel during
the transmission of a Closed Caption program.
Features menu
& Select Features in the TV Settings menu.
é Press the cursor right to enter the Features menu.
“ Select the menu items with the cursor up/down and adjust the settings
with the cursor left/right.
Closed captions
This displays the transmitted CC- or CS-text on the screen according to
your chosen CC or CS service in the Setup, Features preferences menu,
This text can either be permanently displayed (assuming that the
service is available in the broadcast) or only when mute is active.
& Press the cursor right after having selected Closed captions.
é Select On, Off or On during mute.
Oct 28, 2009 | Televison & Video
Black square in the middle of screen
your closed caption is on, this might be set on the cable box or the tv, look in the audio or set menu. If you dont have the remotr you should be able to navigate the menu on the tv with the onset controls
Jul 10, 2009 | JVC AV-36150 36" TV
How do I get to closed captioning on the TV?
You will need the original remote. The TV/CAP/TEXT button turns it on and off. The CH.1/2 button switches between channel 1 and 2 of the closed captioning.
Dec 08, 2008 | Orion STV2763 27" TV
Black box on screen
go into menu find
cc settings and
change setting to off
(make note of the one thats
causing the problem)
Dec 02, 2007 | Sansui DTV2760 27" TV
Black square in the middle of the picture
You have the set configured to display "text 1 or Text 2" in the closed captioning menu. You will need to turn closed captioning off to get rid of this box.
Jan 13, 2007 | Craig CTV-41904 19" TV
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
