Error *41 is a wrong paper size or type error. Make sure that you have chosen the correct paper size and type in the printer configuration. Easiest way to get there is through any application going FILE > PRINT > Configure.
If deleting from the queue does not get rid of the error, on the printer two resets are also available.
#6 is a partial reset
#9 is a full reset
My apologies...The print queue is a place where the print jobs are stored until the printer is ready to deal with them, these are tracked on the computer not the printer. You can see the queue in most Windows operating systems by going START > Settings > Printers. When you double click the printer your trying to print to you'll get a list of pending print jobs. If these are backed up you are not going to be able to print until they are gone. So you click on each job and hit the delete key. Once these jobs have gone to the printer the computer can no longer manage them, so then the next step if the first doesn't work is to clear the printer, this can be done with a reset. I believe you can just hit #6 enter or #9 enter on the printer. However, I would suspect that once you clear the job in queue that is trying to print to the wrong paper size, type, etc. that you may be good to go.
It's possible that the system board is damaged. Do you have it on any type of surge protection?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
But how do I clear the system to make it work. I do not have the HP set up for all its functions. Just a printer and fax.
You are dealing with someone not computer savvy, deleting from queue mean? and when you say #6 , I just hit #6 enter or ok>
every time I hit cancel it prints a extended self test report
It is crazy, I checked the queue there is nothing there, when I hit#6 enter, it goes into the menu.
