Question about RCA F20645 TV
RCA F20539DG The TV was working fine but now there is a relay "clicking" noise when the power button is pressed. It will click several times and sometimes will actually turn on again and work fine (once it's on). Seems it will stay on and work as long as it's not turned off, then you have to put up with it never turning on again (click click click) or just let it keep clicking/cycling until it finally turns on again. Any ideas of what needs replacing before I just throw parts at it? I'm an electrician but not electronics guy. I am aware of the dangerous HV interior parts to fire the tube, etc. but am not uncomfortable working on it "unplugged".
  • l3xl3 Apr 09, 2008
    same thing, keeps clicking then turns on for a few seconds but before the screen turns on, it will turn off again
    Novelist:
    Champion:
  • 236 Answers
YOU might have a bad relay or a bad solder connection in the relay control circuit. Sounds like a bad solder joint. Stargazer
Posted on Mar 03, 2007
SOURCE:
Tv won't turn on makes clicking noise
that click is the power relay, but i have seen several diferent ways this can happen, is it clicking so fast it kinda resembles a buzz noise or do you just hear one loud click when you turn it on? email me maxtek73@yahoo.com.
Sep 08, 2013 | RCA P52960 52" Rear Projection Television
Visio VP504 fhdtv10a - When I plug it in, it has an amber logo light and makes a click noise (like a relay). When I press the power button nothing happens.
These are problems gradually developed in TV over the years. You may have to look for any dry solder, change the capacitors that look 'puffy' and try.
Jul 30, 2012 | Televison & Video
52" rear projection tv has no power and fuse is ok
The clicking noise that you are hearing is actually the power relay. Normal operation by either the remote or the power button on the front panel, you would normally hear a soft click just after the press of the power buttons to turn the unit on or off. When you initially plug the unit in to power, you will hear the same click noise. Being that you are hearing it all the time indicates a failed relay. TV's now a days, or at least ones built during the last 15 - 20 years have different Printed Circuit Boards (PCB). There are PCB's for power (which youre dealing with now), sound,video and so on. The PCB that you need to repair your clicking issue will run you about 80 U.S. dollars for the part plus the average going rate for repair from a qualified service tech. You could purchase the part from Thompson Consumer Products repair and fix it yourself, but be aware, there will be no warranty on the part itself unless an authorized tech does the work. Located on this PCB is the power on/off relay, fuse, usually 4-5 connectors for power to different PCB's (depending on model and features). Now depending on how old the TV actually is, you may want to invest in a newr set, the reason why I say that is, is because the new power unit may and can overload the other boards and cause damage to them and now you have a new problem to deal with( along with more money being tossed down a hole.
Good luck
Sep 19, 2009 | RCA P52926 52" Rear Projection Television
How to put cod in rca remote. for rca sdtv
press tv button, then press and hold setup button, then press power button several times until tv shuts off. As SOON as it shuts off, press enter.
Jul 05, 2009 | Televison & Video
RCA F32649 32" guide plus TV
you need to check the fuse ,maybe it's busted.
Sep 04, 2008 | RCA F32649 32" TV
Power button makes a click, click sound
The sound is coming from a failed flyback auto transformer. You will need to replace that.
Jun 14, 2008 | GE 25GT507 25" TV
RCA Model 32V434T chassis ATC010A
for shure your fly back transformer is bad is a commom problem in this chassis
Mar 29, 2008 | Televison & Video
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
F36650
Three clicks only==bad xformer==#2078 Asti. RCA original sometimes hard to get.#257805. NOTE:There is no lamp to change in your set.
Sep 25, 2007 | RCA F36650 36" TV
RCA F20645 TV Logo
435 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
