hello i have a sony sony str-de845 it has been sitting unplug with all cables un hooked , while i was remodling the house went to plug it up ywsterday it will not come on or do nonthing, try a couple pluges in the house ,but still does not come on . it work well before i stoped using it , if any one can help, i am dissable and on a low income, and dont no what to do . thanks a lot eddie
Open it up, check by where the power cord comes in there should be a fuse. Check to see if it is blown. If so it is an easy fix. Replace the fuse with same type. If not the capacitors are gone and that is expensive to replace.
I moved and am reconnecting the unit. The Rear speakers are not working in any mode. I reset unit to...
(More)
I moved and am reconnecting the unit. The Rear speakers are not working in any mode. I reset unit to factory specs per the Sony manual instructions... to no avail. I do not have anything connected to the surround inputs. Although I have the Sat/TV, DVD and Video 1 inputs connected. Prior to moving, I discovered the right rear channel not functioning (I noticed the right rear speaker problem after a Direct TV installation tech switched out my Direct TVR. I assumed that it was a loose wire) now it seems neither of the two rear channels are working.I disconnected and reconnected the speaker wires. I ran the onboard "tone" check and the three front speakers function and supply the 'white noise' indication. The rears are silent when the display indicated that they were being tested. Are the rear speakers fuse protected? Anyone with an idea of what might be going on??
Sony STR-DE845 1)Rear channel speakers no longer function. Unit makes random clicking sound from...
(More)
Sony STR-DE845 1)Rear channel speakers no longer function. Unit makes random clicking sound from relay 2)Display intermitantly works
Plug it in and demo starts, never stops and power switch will not stop it Switch opens &...
(More)
Plug it in and demo starts, never stops and power switch will not stop it Switch opens & closes normally.
