Question about Home
I have a chip in my bath tub
Chip in the bottom of my bath tup
    Scholar:
  • 68 Answers
This is something best handled by a tub resurfacer. It is an area of specialized repair. Results varied depending on material tub is made of. Cast iron tubs Show repair more so than fiberglass. Check for tub resurfacing in Repair Service Link.
Posted on Dec 09, 2008
For a tub overflow washer (Part# PPC826-3) where should the "thick end" go - top or the bottom? Is pasting a little silicone recommended on it so that it has a better seal after I tighten the screw?
The thicker end goes up because of the sloped end of the bathtub. You should not need to apply any sealant - the gasket is compressed as the screw is tightened.
Dec 06, 2016 | Plumbing
How to clean a whirlpool bath tub
There are three main things to tackle when cleaning a hot tub or whirlpool bath. Those things are:
1. Bacteria
2. Grease
3. Grime and dirt
To address all three of these issues you'll likely need separate products. There are liquid versions of the degreaser and cleaner, and there are tablet versions for sanitizing.
Simply fill up the whirlpool bath with warm water, put the cleaning liquid in the cleaning outlet (or if you don't have this, just pour it into the bath). Put the tablet in the bath and then just run it.
This should do the job.
Pure Spa Whirlpool Bath Spa and Hot Tub Cleaning Kit
Nov 17, 2015 | Jacuzzi Whirlpool Cetra Whirpool Drop-In...
I want to clean the jets in my tub they look mouldy
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link at the bottom to the cleaning products I can find right now. There may be others out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Feb 27, 2014 | American Standard 9330.014 Adhesive Bath...
Oil type substance is streaking down the side of the tub and apperars to be coming out of the jets any ideas how to fix it
This sounds like bacteria coming from the water lines. When was the last time you ran a cleaner through the jets?
You should run a good Jet Clean type product of Maintenance Product in order to prevent the build up of bacteria in the water lines when the bath tub is not in use.
RodUS Parts Center888-521-6183
Feb 22, 2013 | Home
How to replace broken jet nozzles in whirlpool tub
Hopefully your tub is not too old because this will make replacing the nozzles very difficult as they are no longer made.
If in fact you have a Jacuzzi Brand bath you can get what is still available for bath jets here. The diagrams will give you an idea of how they come apart.
Jul 08, 2012 | Home
I have been told there is a way to adjust bath tap temperature under the bath is this true? Thanks
Yes and no, depends on what tub you have and what is underneath. Most tubs have the filler spouts up top like a regular old tub. If you want more hot water, you just open up the hot water, but if your tub fills from the bottom somehow, or has a heating unit in it, then it can be adjusted. It has a motor under there for pumping the water around. It is in a trap door on the tub or the tub surround. You will have to peek in there to see if there is a water valve with thermostat of some sort. I have never seen one, but you never know. Hope this helps.
May 15, 2010 | Home
Bath waste
! goes over the threaded piece that screws into the piece that goes under the tub...and the other goes between the tub and the waste assembly thereby creating a sandwich with one on top and one underneath the tub....then screw the piece down tight through the tub and into the waste assembly and your good to go.....
Good luck and thanks for rating my effort.....the Fang.
Mar 25, 2009 | Lefroy Brooks BATH WASTE KIT - LB1370-ST -...
Kenmore washer tup wobbles easily
there is a little hole on the back panel where it goes,it most likey rust out,put it in the hole right next to it on the wall,this spring keeps the water from leaking out the top back when filling and rinsing
Mar 16, 2009 | Kenmore Washing Machines
How do I use my Whirlpool bath?
youneed to make sure that the switch is on first .their should be a switch for the tub on the wall somewhere.find the switch than push the button on the tub,also make sure that their is water in the tub that is past the jets before pushing the button on the tub.
Feb 07, 2009 | Whirlpool Home
Difference tubs and air baths
whirlpool tub has jets that circulate the water, where an air bath uses bubbles that rise gently from the bottom of the tub. Whirlpools are typically used for therapy, air baths are used for a much gentler experience. Air baths can be used with aromatherapy/essential oils. Both offer a spa-like experience.
Aug 27, 2008 | Whirlpool Pearl Ballade True Bathtub with...
Home Logo
559 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
