Question about Kenmore 24032\24036 Top Load Washer
Kenmore oasis stops. message says "F" then "50"
Every time I try to wash with my kenmore oasis it stops after one minute and gives a message that flashes "F" then "50". how do I fix the problem?
  • 198 Answers
F50 means motor stalled.it means that the controller board (Part # W10122535 ) burned out.
Posted on Jan 07, 2009
I have a kenmore elite oasis washing machine, type 580. when starting cycle it stops with code F 50. Any suggestions?
It's telling you that it did not detect motor movement. This could be failed motor control or something else. It is probably an RPS or the maching/motor control board but there are a few other things that it could be. Not an easy problem for DIY.
Jun 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washer flashes F 50
possible problem with connection on rps sensor..this is located under motor rotor underneath machine ..lean machine back remove bolt in bottom of motor remove 4 screws holding motor stator coil in place connector with brown wires push clip back and pull connector on and off several times ..this will help clear and residue that may causing a poor connection electrical contact cleaner may help in the cleaning process
Oct 30, 2008 | Kenmore Oasis HE 27082 Top Load Washer
3 quick beeps during cycle if you can get it to stay in a cycle
MY KENMORE OASIS HE IS DRIVING ME CRAZY! THE CYCLE SIGNAL CONTINUES TO BEEP AT LEAST 25 TIMES, STOPS FOR MAYBE 20 SECONDS, THEN BEEPS AGAIN ABOUT 25 TIMES. THE WASHER WORKS GREAT, BUT IT WILL NOT STOP BEEPING! HELP!!!!!
Sep 13, 2008 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore Oasis washing machine is completely dead
discconect power for about 10 minutes,, then plug it back in should fix if not call repair possible control board failure ,,,,,,
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27062600 Fault code 50
Any solution? I have the same F50 error code.
Apr 29, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis 27092---won't respond after error message cleared
THERE HAVE BEEN ISSUES WITH THE CONNECTORS ON THE MOTOR CONTROLLER AND MAIN P.C. CONTROL.
IF YOU CAN GAIN ACCESS TO THE CONSOLE, WITH THE UNIT UNPLUGGED, TRY DISCONNECTING EACH CONNECTOR FROM THE BOARDS, ONE AT A TIME, AND PLUG THEM BACK IN. THIS WILL CLEAN THE CONTACTS ON THE BOARDS AND MAY REMEDY THE PROBLEM.
DISCONNECT ONE PLUG, THEN RECONNECT IT. THEN, MOVE TO THE NEXT.DO THIS UNTIL EACH PLUG HAS BEEN REMOVED AND RECONNECTED. THEN PLUG IN THE WASHER AND SEE IF THERE IS ANY CHANGE.
Apr 05, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
165 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
