Burning with a CD-R is not a problem for me. No issues whatsoever. However, inserting a DVD+R gets me nothing. The drive will read it as a DVD-ROM. When I load the DVD, it gives me the option of opening a recordable folder. When I try to send a file to the folder (via right click-send to E:) I get an error message: Unable to copy file with the options of retry, skip, cancel.
If I try to send the files to a writable folder prior to inserting a DVD+R, the files show up in the E: as "waiting to be written." However, when I put the DVD+R into the drive, the files disappear and the recording session is no longer an option!
This is extremely frustrating!!
I pulled the drive out of the case and found this S/N: 34F12775111
I'm not sure what else to try at this point. Any ideas? I hope so! Thanks in advance!!
Comment by Soulja1, posted on Feb 27, 2007
Dell Dimension 8300
Windows XP
P4 2.6GHz
512MB Ram (2x256)
120GB HD
System is about 3+ years old. Never tried to burn to DVD before this week! Sorry for all the follow-up posts, just trying to make sure you get as much info as you need!!
That in mind, I'm using Sony DVD+R Ver.1.3/1x-16x discs!
Also go to My computer, right click on your dvd drive and go to properties, then along the top row of tabs, the end one should say 'Recording', click on the tab and make sue that 'Enable CD recording on this drive' is ticked, and just below make sure that the dvd you use is showing in the drop down window.
Finally if you still have trouble, my advice would be to use a dedicated programme for writing to cd and dvd for example Nero burning Rom or Nero 7 being the later version.
In this nero you use your drive as a 'floppy type' drive, where you right click on file and send to and it writes straight to the disk and also enables you to change the file or delete, unlike windows programme.
Was this solution helpful? Show your Appreciation by rating it:
Post a New problem for NEC MultiSpin ND-1100A DVD+RW Burner
Email this problem
Can you Help with these CD and DVD Burners problems?
My Nec ND-1100A DVD+rw will...
