Question about Brother SX-4000 Typewriter
My typritters wheel fell out and the keys are not lining up ciorrectly, what do i do. i have a brothergx7750
  • Anonymous Dec 17, 2008
    Brother SX-4000 changed the wheel, letters typed are not the letter that actually type
  • Brother Master
  • 3,594 Answers
Remove the printwheel, check and be sure all of the spokes are not bent or mis aligned, be stre the ribbon and L/O tape are not interfearing with the printwheel reinstall the P/W turn off the machine and turn it bacr on.
DickyO
Posted on Dec 11, 2008
Took the back tire off my john deer sabre 14.5/38 and now it wont move ....stays on
check to see if the key is in place. some models have a key that locks the wheel to the axle. if it is not in place it wont move. when you took the wheel off it probably fell on the ground.
Jul 17, 2017 | Garden
Tractor will not move when put in gear knocking sound right rear wheel
check to see if the key fell out of the keyway where the wheel meets the axle. If the key is gone there will be no traction
Apr 14, 2017 | Garden
Why doesn't it move forward or in reverse?
Many tractors and mowers have a key way on the axle and axle bore on the wheel hub.. Did you remove the tire and wheel from the mower axle? ..if you did most likely the drive axle key fell out of its slot on the drive axle and when you replaced the wheel it has no way to drive the wheels..try this start the mower put it in gear and try to move..have someone watch the end of the axle at the wheel
..if the key is missing the axle will be turning..but not the wheel..any good hardware store should carry them. just measure the depth and width of the key..something like 1/4,3/8 etc...good luck..
Aug 16, 2015 | Ariens Garden
2003 santa fa wont start, the dash board lights are on and the radio is playing but the car won't turn over.The key turns in the ignition with no resistance, we had to disconnect the battery to save it.
That means the linkage rod fell off your key cylinder. (this happens whenever someone tries to steal your car) the push rod presses your ignition switch. If you know how to pull your steering wheel off, you can replace the key cylinder (if some of the casting is broken) by going to a junkyard. Get a cylinder with a key (you can make copies of the new key later) If the key cylinder was ok then just reattach the rod and put the steering wheel back on (being careful to keep the wheels facing forward before you remove the steering wheel so that you put it back the same way)
Oct 20, 2013 | 2003 Hyundai Santa Fe
When I removed the rear wheel of my lawn tractor,the keyway fell out. how do I reinstall it?
I assume you are having trouble keeping the key in place while you slide the wheel back on?
I've sometimes used a bench grinder and taken the leading edge off the key (the edge catching the first part of the wheel as you slide it on) to stop it catching on the wheel slot, also a dab of thick grease under the key to help hold it in position.
Some coppercote or similar anti-seize grease in the wheel's key slot would be a good thing too.
Sep 08, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Key cylinder is broken how do i remove
cant drill to replace. you need to remove steering wheel and go into it that way......
Aug 18, 2012 | 1995 Chevrolet Tahoe
Right wheel fell off how do I put it back together need a schematic
if your wheel fell off there is no shematic that i know of however check to see if the studs are stripped if so pull the wheel ( POP-OFF THE BEARING CAP WITH A FLATHEAD SCREWDRIVER) unscrew thew wheel nut and pull the wheel (being careful not to drop the bearings on the ground ) then with an old nut or board (2 by 4) or something similar so you don't flare the stud so that it wont go through the hole. drive studs out and replace (fairly cheap). when you put the new studs in make sure that the teeth on the back of the hub line up with the teeth on the studs before you drive them in.if the whole fell off make sure that the threads on the spline (shaft) are not damaged. if so repair the threads and get new bearings . ( bearings only go in one way) and nut and cotter pin. (if you don't know that the race is any good take the hub to the auto parts store and ask the attendant at the counter) when reassembling do not over tighten the wheel nut and BE SURE TO PUT THE COTTER PIN IN AND BEND 1 PRONG BACK.
Sep 08, 2010 | 1987 Ford Ranger
Tipped it sideways to change tire and it will not move forward or reverse.
if it was a rear tire the key that locks the wheel to shaft probably is not in shaft either fell out when removed wheel or slid out when reinstalled.if u try to drive tractor have someone watch the axle to see if it spinns inside wheel. hope this helps
Aug 14, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
Brother SX-4000 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
