Brother MFC-465CN fails to reconise a black ink cartridge. Says no cartridge even with a brother cartridge fitted.
    Problem Solver:
  • 9 Answers
Well i know a lexmark, when i change the ink i always X in where it says a new cartridge . even if i refill my ink cartridge i never hit old just because i took it out. sometimes it will not recognize it if it old.than follow the step of a new cartridge installed. and print a test page and alinement just like you our setting it up for a new cartridge. sometimes if the computer doesnt reconze the printer i have uninstalled and reinstalled..hope this helps a little.
Posted on Dec 09, 2008
How can I fix no cartridge error on brother mfc-465cn
It sounds like it may actually be the "print head" which is what the carts fit into. These can and will go bad. Sometimes you can find replacements on ebay etc. But you need to make sure it is exactly the same part number. There could also be a number of other issues, the cart contacts could be dirty or damaged (another print head issue resolved by replacing), counterfeit cartridge, bad cart. These are the most common, but not the ONLY issues that can cause your problems. I'd check prices for replacement print head vs. new printer.
Jul 18, 2014 | Brother MFC-465CN InkJet Printer
My Brother 465CN recently decided that even though I have a new black ink cartridge in, that there is no cartridge.
The code is within the ink cartridge itself. If it is not a main brand cartarage, you may have th esame problem with both . I would suggest buying a main brand one .
heads can be cleaned with a tooth brush and alcohol. Dry well.
www.brother-usa.com
Jun 29, 2014 | Brother MFC-465CN InkJet Printer
I have a Brother MFC-465CN and it says the Black Ink cartridge is empty. However, the cartridge is full. I cannot print until this is resolved - ow can I fix this?
Hello I am an expert on printers are pretty good Brother.Brother But the ink is running out fast .. I got home Brother MFC-210C.
So I took ink and slid ho.
. I hate Brother printers!. So I broke down and I saw that there is a color sensor and instead I chose colors I had crouched low and showed that the paper is full of the good? Try it at home if you can.
Jul 30, 2012 | Brother MFC 240C All-In-One InkJet Printer
I just installed new ink in my Brother MFC-465CN and the black will not print.
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
Dec 16, 2010 | Brother MFC-465CN InkJet Printer
Brother Mfc-845cw and Mfc-465cn both stopped printing Black about the same time. Using Non brother Ink. Tried cleaning, replacing carts, unpluging maching. how can I fix this.
the black ink that was used in the refilled cartridges was probably to thick for the nozzels on the head, you can try buying the original cartridges and then cleaning again, or check with the store you got these cartridges from as some of them offer a warranty
Nov 20, 2009 | Brother MFC-465CN InkJet Printer
Black will not prtint. All the colors print fine on my Brother MFC 465CN. Have already: 1. Changed black ink cartridge 2. Reloaded printer driver Almost seems like some deeper issues where it...
GENERAL PRINTER TROUBLESHOOTING ADVISE:
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. If the printer has a cleaning option either on the printer itself through the menu system or on the computer through the print driver, you can use that afterwards. Some printers will let you re-run the cleaning utility several times. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expects you to have is not installed. Double check that the ink is correct against the manual or written instructions inside the printer. Not every cartridge that fits the printer necessarily works.
Nov 08, 2009 | Brother MFC-465CN InkJet Printer
Does not print properly-even after installing brand new cartridge
most likely your ink nozzles have clogged up.
try several cleanings, if it still does not work, you probably have to get the printhead replaced.
Jun 26, 2009 | Brother MFC-465CN InkJet Printer
Replace black ink in brother mfc-465 inkjet & now it won't print
are you using brother oem ink? you ,may check and see if the seal is still on the cartridge, if not try and take a paper clip and insert it in to the air hole on the catridge, some times it gets clogged up. brother tech
Jan 13, 2009 | Brother MFC-465CN InkJet Printer
Brother mfc 465cn printer
If you remove the empty cartridge, you will see a small window on the egde that plugs into the printer, in the center. This is where the printer optically scans for ink levels. On the empty color cart, you can try covering that raised spline with electrical tape or by coloring it with a black permanent marker. That should fool the sensor into thinking your ink is full.
Oct 31, 2008 | Brother MFC-465CN InkJet Printer
Use MFC-465CN withou cartridges
in order to scan you need to have ink in cartridges?... great design!!! cheat the printer - use black electric tape to cover transparent slots at the back of your cartridges (printer will think that it has ink and it should stop that annoying beeping)
Aug 05, 2008 | Brother MFC-465CN InkJet Printer
212 people viewed this question
k24674
jasbo
jasbo
