Question about Sanyo HT32744 32" TV
Remote broken and need to turn on Closed Caption
Purchased an OEM remote.
Posted on Dec 10, 2008
How do I turn off closed caption on Model TP2784C101?
If the remote control have a "CC" button on it, press it once to cose the Closed Caption option. If the remote do not have a 'CC" button, enter TVs menu option, surf through, come towards closed caption adjus window, and make clsed caption function to OFF, if it is ON.
May 21, 2012 | Philips TP2784C TV
My closed caption is on and I can't turn it off. I don'want the writing on the screen
Did you try turning it off with the closed caption button on the remote? Its labelled cc. If you dont have the original Vizio remote you will need to go into menu-settings and find the closed caption and turn it off there
Oct 24, 2011 | Vizio L37 Television
I have a Sanyo TV DP32648 and the closed caption won't turn off. i don't have the original remote and even now have a programable logtech remote. how do i turn off the closed caption
You will need to have CAPTION button on the universal remote control to turn on/off the caption, if it does not have that function then you will need the original remote.
SANYO remote model GXBJ is needed for this TV.
You can get used one for $20 on EBAY or a lot more for new one at:
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=DP32648&brand_pn=SANYO_DP32648&mode=large&v=1&uuid=A13140757813801
Aug 23, 2011 | Televison & Video
Cant turn off closed caption
sherrillbrom
With our VIP receiver models, you have an option to turn on/off closed caption through the receiver. Press the Menu button on the remote, which will display the Main Menu on the TV screen. Press 8 (Preferences) and then press 6 (Closed Caption). On the Closed Caption screen, press 1. On the Closed Caption On/Off screen, select CC Off and then press Done from the TV screen (using your DISH remote). This will turn the feature off on the receiver. Test to see if it is turned off by watching a program that has CC. If it still appears, then the feature is activated through your TV. Please refer to your TV manual to turn the feature off. I hope this helps.
Ray Calo
DISH Network
Feb 21, 2011 | Televison & Video
Lost remote, somehow child turned on closed caption without remote,how do I disable closed caption without remote?
Find a button on the tv manual control said Menu,press it. Goto tv menu find and turn off all CC1,2,3 and text 1,2,3.U should have no more closed caption.
Sep 12, 2010 | Philips Magnavox 20MS233S 20" TV
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Closed caption for durabrand
if you have the menu button on the tv itsself then you can go from there to remove th closed caption
May 10, 2008 | Durabrand DWT1905 TV
Closed Caption won't turn off
cannot turn off closed caption on 27" insignia. the option screen which illustrates the closed caption category, is not highlighted and you cannot manually choose that option from the remote control.
Dec 08, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Closed caption activiting on everytime tv is turned on
If you have the Suddenlink remote and the DVR box you can turn captions on or off by accessing a technical menu. To do this, press POWER and Menu buttons together (menu 2 times) to bring up a special menu. Select Closed Captions. On the popup menu select closed captions and using Select button change to OFF or ON as you wish. The trick is to get the menu to come up. Timing of pressing the two buttons is frustrating and it may take a few times befotre you get the special menu.
Oct 02, 2007 | Televison & Video
Closed caption
Solution #1posted on Jul 23, 2007 By QTV1 Rank: Guru Rating: 93.33%, 6 votes Press menu on the remote. Press the cursor up or down button untill the word CC is highlighted. Press the cursor right button to select Closed Caption 1. You will likely have to do this with the original remote. A universal remote may not allow you to do this.
Jul 22, 2007 | Philips PR1902C TV
Sanyo HT32744 32" TV Logo
65 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
