Question about Samsung SPP-2040 Photo Printer
Print only 50% of one complete picture
Hi
this is arash.i have a very bad problem with samsung spp-2040 printer
when i try to print one picture after completing the operation of printing i face that only right side of pic is apear and left side is disapear.
please help me
  • 5 Answers
I have posted a possible solution.
Try this: http://www.fixya.com/support/t467694-print_problem_spp_2040
Posted on Dec 21, 2008
    Guru:
  • 1,049 Answers
If this is actually a printer issue I suspect it's a memory problem. There should be a setting to print data "raw" without caching, or "as you go"...I can't remember the exact wording. Either way, if your not buffering the jobs and the problem is memory, that should slow it down but will fix it. If it doesn't, I would suggest you look at what your trying to print, because it is most likely related to what your printing and not how. Like the previous job not sending a carriage return, indicating a form feed, or some other oddity.
Posted on Dec 09, 2008
Only printing 1/2 the image of the selected photo, I have tried changing the printer cartridge but still only prints 1/2 the selected image, any ideas why this is happening?
I am not familiar with that particular printer, but it could be as simple as making sure you have the entire picture selected..but it sounds more like the cartridge is either clogged or there is a setting that needs changed...try aligning the cartridge(s) and printing a test page. (that part is usually under a maintenance or troubleshooting type section) if that turns out fine, then there may be a setting thats off...look at your print settings...you may have a separate section just for printing photos...even if you don't, look at your page setup.. look specifically at the margin settings...that might be where the problem lies..you can always play with the margin settings- i would recommend saving them under a custom setting if you want to keep them, instead of default though...that way you have your regular settings for general printing... and do a "print preview"...that might be a good idea anyway, so you wont have to waste ink and paper trying to get your stuff to turn out how you want it (plus that will show you if margins are set right)...for that, there should be a checkmark box you can select to always do print previews...
also, look to see if you have a selection or checkmark box that says "fit to page" or where you can select how many copies you can print per page..this can be used for everyday printing, as well as for photos...
you may even see a spot where you can select the size of photo to print...usually you can pick to print "wallet size or 4x6, ete." and how many to print on a single page...maybe even multiple sizes per page...these are several options for you to look at...hope it helps :)
Jul 30, 2015 | Samsung SPP-2040 Digital Photo Printer...
Picture not completely printed
check the sheet to be in the right position for the picture..if it is a portrait (vertical ) and it is set for a landscape (horizontal) ..it will print just 3/4 of it ..always get into the print preview and set those things ...
Jun 16, 2010 | Samsung SPP-2040 Photo Printer
Can i print from an image saved on my computer?
yes u can easily do that, juss save the image on the hard drive of your computer, go to file, hit print, n it will print.
Nov 01, 2009 | Samsung SPP-2040 Thermal Photo Printer
Rafique:- Samsung SPP 2040 paper problem.
If its new, You may contact nearest service center.
Mar 27, 2008 | Samsung SPP-2040 Thermal Photo Printer
Print problem spp-2040
This may be caused by a broken plastic lever for the thermal head inside the printer. This is not particularly difficult to fix, but it not be attempted if you have more than two thumbs.
  • The case is not difficult to open, nor is removing the pc board in the printer, but I suggest getting a service manual on the web for disassembly instructions. Reconnecting the LCD cable is painful. Search for "SPP-2040 service manual."
  • Remove the printer assembly from the case.
  • Remove the PC card from the printer assembly being very careful of the cables.
  • From the top, look at the shaft that controls the up/down motion of the thermal head. At the end opposite the motor, inspect the white plastic lever. There should be no cracks evident, nor should the lever be "loose" with respect to the shaft. If this is not the case, this is not your problem. There is a "flat" on the shaft that should keep the lever from rotating.
  • Remove the "upper plate." Two small screws and a spring at the opposite end.
  • Rotate the lever so that it aligns with the "flat."
  • Using small buss wire (or a paper clip), wrap the wire around the round part of the lever.
  • Twist the ends of the wire tightly and as close to the lever as possible. There is not a lot of space here. Trim off the excess wire and position the wire as shown.
  • Reassemble the top plate & spring.
  • Reassemble the printer & test.
Hope that this has helped. al
Mar 25, 2008 | Samsung SPP-2040 Thermal Photo Printer
Spp 2040 printer ribbon
  • Open the door on the right side of the printer.
  • Push "up" on the green lever above the ribbon cartridge. The ribbon should pop out slightly.
  • If it does not pop out, then try prying out the cartridge while pushing up on the grean lever.
  • Pull out the ribbon cartridge.
Feb 14, 2008 | Samsung SPP-2040 Photo Printer
ERROR INSTALLING FIRMWARE
See Working for me. In the fireware zip file. There is 2 firmware. One for model 2020 and one for 2040. Select the correct one for your printer model.
Dec 31, 2007 | Samsung SPP-2040 Thermal Photo Printer
Samsung SPP-2040 Photo Printer Logo
192 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
