Hourglass picture I have a Panasonic 32'' tv model# CT-32G13W . The sides curve inward giving an hourglass look. can I fix it myself? I have time and patience.
    President:
  • 2,992 Answers
This is called "pincushion distortion" and there is correction circuitry in the set to take care of it. Obviously it isn't working. Sometimes this is due to parts failure, but it often happens because of bad solder connections to some of the parts. I don't have a service manual for this model so I can't give specific part numbers or locations. But if you have patience and some electronic soldering skills you can try repairing it. Flip up the circuit board so you can see the bottom (the solder side) and start in the area where a connector plugs onto the board that goes to the coil of wire on the neck of the picture tube (the "deflection yoke" it's called). Work around that area and look for solder connections that are visibly cracked or very grainy looking. Good solder joints look smooth and shiny. The bad connections (if that's the cause) will probably be found to transistors, 3-leg parts that may be mounted on metal heat sinks. In fact, make anything in the area mounted on a heat sink the first parts to check. Because the get hot, they are the first ones to develop bad connections. Heat up and resolder any connections that look doubtful. A strong light and a magnifying glass may help.
Some warnings:
- UNPLUG THE TV BEFORE YOU START.
- SOME PARTS CAN STORE A CHARGE THAT CAN SHOCK OR KILL YOU EVEN AFTER THE SET HAS BEEN OFF FOR A WHILE.
- With the back off the set, some TV's are unstable. Be careful of the set tipping. You may want to lay it face down on a padded surface before you start working.
Solder connections that go bad are a major cause of problems in TV's, so this might get you going. Just work carefully. If it doesn't take care of the trouble, the problem is part failure and that would require test equipment and the service manual to locate.
Posted on Dec 09, 2008
2 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: Panasonic 32" CT-32G13W
That's good you have time and patience.
You should have service manual and electronics knowledge to recognize and test / check parts in tv.
Problem is in Pin Out area of tv and you can have new parts from Panasonic Parts.
You can buy service manual from Service Manual net
Good Luck.
Posted on Dec 11, 2008
Picture curves in at the sides after switch on
That sounds like the convergence has gone bad. For help with this issue call our service manager at 3037706535 or click the link below
PANASONIC TV REPAIR AT AAAA TEVA
Jul 07, 2010 | Panasonic CT-27SL14 27" TV
I have a Panasonic CT-32D31 TV and I've been noticing some shrinking and curvature of the picture from both the right and left sides. Is this something that can be fixed quickly, easily and most...
Your symptom sounds like a damaged component in the pincushion circuit.
When this circuit fails the picture will have an hourglass shape to it with black in the middle on the sides, or you will see square objects as hourglass shapes.
I would recommend that you have a local service center diagnose the set for you and give you an estimate of the repair.
I have seen this type of repair run from $150.00 - $200.00.
The cost of the repair or replacement of the set is completely up to you. I would most likely recommend that a replacement may be in order, as most television sets are becoming cheaper all the time.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Jul 09, 2009 | Panasonic CT-32D31 32" TV
High pitch squeal, buzz, no picture
Tossed the television and put a new one in.
May 16, 2009 | Panasonic Televison & Video
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
Good Luck.
Dec 11, 2008 | Panasonic CT-32HXC14 32" TV
PANASONIC 32" CT-27SL14 model
This is a problem with the pincushion and convergence circuits. Are you planning on repairing this yourself? If so, I'll look up the circuit designations and parts. If not, expect a parts cost in the $15 range plus the local labor rate.
Dan
Jul 03, 2008 | Panasonic CT-27D31 27" TV
Vertical hold
If the picture is in an hourglass shape this has nothing to do with vertical hold. Besides, on all these sets, the hold and parameters are all uPC controled through a firmware routine that is burned in to an EPROM.
It is obvious that there is a failed component somewhere because of the hour glass shape. The area of failure is most likely in the pin amp section. If the hourglass is from the sides, it would be horizontal pin. If it is top and bottom, the fault is in the vertical pin section.
A common cause is from a capacitor that has failed in the mentioned area. Sometimes it can be an IC or other type of component in the pin amp area, but not as often as failed capacitors.
You can take the set in to service the fault. I don't think you can fix this yourself unless you are trained in TV service and have the experience and setup to troubleshoot for the bad parts, and do this type of service.
Jerry G.
Apr 19, 2008 | Panasonic CT-32HX40 32" TV
Apex PF3230 TV with pincushion problem.
too dangerous for a home repair as this requires replacement high voltage components and adjusting the set with the back off while running.
Take to repair store.
Nov 08, 2007 | Apex Digital PF3230 32" TV
The screen picture bulges inwardly on the right and the left
you have defective horizontal linearity! replace the capacitor at the hot side mostly 160uf 180V or 160uf 160V.
Oct 02, 2007 | Recoton Advent Advent Q2035A 20" TV
Panasonic CT-32hX41 vertical picture problem (hourglass)
this product has a pincushion problem and requires servicing but unfortunatley it is what we call in the business NECO
Dec 05, 2006 | Panasonic CT-27HL14 27" TV
Televison & Video Logo
426 people viewed this question
Top Televison & Video Experts
Electro Med Services...
