Question about Rainbow E series Canister Wet/Dry Vacuum
Power head has power but motor won't run
I started the vacuum yesterday and it sounded a bit off. So I checked the power head, it was running but sounded almost plugged. I shut it off and checked it; the belt was fine and the bar was turning. I turned it on and it still sounded odd so I hit the stop button on top of the power head and now it won't run at all. The red light is on but the power head itself doesn't run. I've turned it off, undone all the electrical plug ins and replugged them in but it's a no go. What on earth did I do wrong??:(
  • catinthehat4 Dec 10, 2008
    Thank you. I took it apart and was able to turn the belt but didn't take out the brush. I did get it going again but it's just not itself. You may be right about the motor....Thanks again, though. This is an awesome site!!
  • Rainbow Expert
  • 324 Answers
Circuit brealer switch may be bad, but the fact that Rainbow nozzle made this strange sound makes me think that it may have happened because there is something wrong with the motor.
While unplugged - remove the brush and belt. Try turning brush ends - see if they yurn easily... Try turning the motor shaft - see if it turns and if it does - if it turns smoothly and if makes any strange sounds...
To really test the motor you can just bypass the circuit breaker switch.
Posted on Dec 10, 2008
Roller bar will not spin on dc25 animal
If the brush bar motor is running try putting on a new belt. If the motor is not running it may be the main switch, the switch that activates when you recline the handle, the motor itself or a loose wire or connector somewhere. Check the connection between the vacuum and the power head. If power isn't transferred properly the motor will not run.
You have to closely check all these areas to find the problem.
Mar 05, 2017 | Dyson DC25 Animal Bagless Upright Vacuum
The beater bar in my vacuum does not go around and there is no suction in the power head?
Turn up side down- check if belt is intact- I would remove belt ant look for an obstruction. Not familiar with this vac but some motors have replaceable bruches on the motor. Try running and feeling for suction. The motor should sound strong when running. Remove beater brush and check for freedom of movement.
Jul 28, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Hoover spirit 900 canister wont turn on?
see this causes and fix it. God bless you
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced
If the vacuum cleaner motor doesn't run the on - off switch might be turned off or defective. Test the switch with an Ohm meter or continuity checker.
Sep 27, 2012 | Hoover Vacuums
Beater bar motor quit, now the main motor quit. Replaced the on/off switch. still nothing
If the vacuum cleaner motor does not run the motor itself might be burned out. Check the power switch first to be sure the motor can get power. Then, be sure the motor shaft can turn freely, that nothing is obstructing it. If the motor can turn freely and is getting power but still won't run it will need to be replaced.
Sep 27, 2012 | Vacuums
Power is not coming on
Sep 27, 2012 | Wagner Spray Tech Wagner 915 1,500-Watt...
Power light on but motor won't run. where do i
the motor carbon brushes need replacing which is a most difficult job to get the cleaner disassembled. Brushes are easy to fit if You have replaced carbon brushes in other appliances etc..
Getting to the brushes in the Kirby is very difficult...
Lee in Australia
Jul 28, 2011 | Kirby Generation 3 Bagged Upright Vacuum
Not working  I hit the switch and there is no sound of a motor.  Nothing is happening.  It was working seconds earlier and suddenly it stopped.  The plug was in and I replugged it into...
If it was just a broken belt you would still hear the motor running. most likely its in your cord or switch. check the main cord, connections to the switch, and also the motor supply cord that goes from the handle to the vacuum head.
Feb 26, 2010 | Oreck XL Ultra Bagged Upright Vacuum
Kenmore Progressive Canister Vacuum -Model 116 22812200.
hello... you might want to try checking the elbow or neck of the power nozzle for blockage. Remove the wand from the head and look through it. Also look through the wands . If there is no blockage, maybe there is a problem with you nozzle. Reattach all the parts and turn on the machine, turn on the power nozzle. Can you hear the other motor start? If so, check to see if the belt is turning. If it is not, and you definitely hear the secondary motor, then you need a belt. If it doesn't make any sound then, with the machine still running, press the button on the upper part of the power nozzle, this should reset your motor. I hope these tips helped ya, let me know, by giving feedback when asked. thank you, Rene (The Vacuum Doctor)
Nov 10, 2009 | Kenmore Vacuums
My bosch turbo jet vacuum
open the head. there is a dc 120 v motor with a belt.
check for ac power going in to the rectifier board and dc comming out.
sometimes the black wire breaks inside the motor housing.
it is hard to open and close the motor housing side where the wires run and closing the power head is fun as well.there is a transformer for the light and wires have to be routed just right to close it up.
good luck
Paul G. Canada
May 07, 2008 | Bosch Turbo Jet Bagged Upright Vacuum
Power head
If you have checked the power delivery down to the powerhead and you have current running to the powerhead, then you likely have a burned fuse. There is a fuse built into the powerhead motor and is usually located on the field winding. This is not easy for a novice to replace and even most professional repair shops will replace the motor. It is possible to replace the fuse if you know what you're doing, but if the fuse blew, there may be a more serious problem, after all, the fuse is there if the motor starts to experience distress and the fuse will blow to avoid any electrical issues. The fuse can blow if something is jammed into the roller and causes the motor to labor heavily. If this is the case, then the fuse can be replaced safely. If the motor is burning out, then a new fuse will just blow immediately after replacement. What I do is take the fuse out and run the motor without it to see if the motor is still viable and replace the fuse if the motor proves to be o.k.
Feb 08, 2008 | Eureka 6831A Bagged Canister Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
365 people viewed this question
Top Rainbow Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
