By M0nica L - usenet poster
my cd has a very weak/poor volume, what can i do?
Clarification Request
by swestside, posted on Jan 21, 2008
Playing on your computer? Try double clicking the speaker icon in the bottom right hand corner of the screen and maximizing the Wave and Volume Control.
Solution #1
posted on Jul 24, 2008
I beleive that you may need to reinstall the drive and update the drivers,
if youve got XP OS then you will need SP2 updates also.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Apr 28, 2008
If you recorded the music yourself then it might be that you did not bring up the levels high enough in the mastering. To find out, play a commerical CD and if it is loud, your mastering is a problem. You absolutly do not have a cable conection problem. That is so incorrect. You might also not have your volume up either the master or the headphone, or you just do not have it hooked up correctly in the first place. Your SCSI goes direct to your CD burner, if it had a connection problem it would not see the drive and has nothing to do with low volume.
Solution #3
posted on Aug 08, 2005
Rogers - usenet poster
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
1. Check all cable connections to make sure they're secure.
2. Replace the cable connecting the CD unit to your receiver.
3. Clean the contacts on the player and receiver with electronics-grade contact cleaner.
Suggest a new solution for this problem
Post a New problem for Zio Corporation CD-RW Burner
Email this problem
Email this problem
This Problem Also Relates To:
HP (346789-001) CD-RW/DVD-ROM Combo Drive
HP (350208-001) CD-RW/DVD-ROM (Combo) Burner
HP (377402-B21) CD-RW/DVD-ROM Combo Drive
HP 300e (900956) DVD+RW Burner
Memorex (320232340 (32023234) CD-RW Burner
Memorex (32023292) DVD±RW Dual Layer Burner
Sony (VGPDRWBX1) DVD RW Dual Layer Burner
Can you Help with these CD and DVD Burners problems?
Zio Corporation (DM-3000) CD-RW Burner
ACARD ARS-2021D Copy Smart Plus...
All copys now made with this... Answer This...
Repair Service
Find CD and DVD Burner Repairman Near You:
