Question about Vivitar VIVICAM 5188 PINK BNIB Digital Camera
Cant format memory card
Ive got a vivital vivicam 5188, and i have a 4gb sd memory card that will fit this camera.
i know that the memory card has to be formatted in order for it to work
but i cant work out how to format it!!!!!
the instructions that came with the camera arent exactly helpful either
PLEASE HELP
han
Justanswer.com is a website that can answer such questions for a very reasonable fee.
Posted on Jan 23, 2009
Vivitar Vivicam S130
should me via menu - settings - storage - format - internal memory if you are using a sd card just insert it into a computer and delete the ones you wish, formating and sd card will remove all photos
Apr 30, 2014 | Vivitar ViviCam S130 Digital Camera
I bought a 4g memory card and it will not format.
The 6320 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in devices not designed to take them. You will have to use SD cards, 2GB and smaller.
Jan 30, 2012 | Vivitar ViviCam 6320 Digital Camera
How do I clear the internal memory?
This should do it - this comes from the manual Formatting will do what you want.
Formatting an SD Memory Card or Internal Memory This utility formats the internal memory (or memory card) and erases all stored images and data. 1. Press the button to turn on your ViviCam 3785. 2. Press the MODE button twice to enter [ ] Playback mode. Then press the button to enter the Playback menu. 3. Select [Delete] by using the / buttons, and press the button. 4. Select [Format ] by using the / buttons, and press the button. 5. If you want to format your SD memory card or the internal memory choose [OK] by pressing / buttons, then press the button to confirm.  To cancel the action, select [Cancel] instead.  [No Image] pops up after the SD memory card or internal memory has been formatted. Note:  Be sure the SD memory card is properly inserted into the camera before formatting it.  To format the internal memory, be sure to remove your SD memory card first.  Formatting will erase all information (even unrelated , non-camera data) from the memory/card.  For complete compatibility, be sure NOT to select FAT 32 as the file system when you format the SD card in your computer. Memory cards formatted in FAT 32 file system will not be recognized by this ViviCam 3785.
Jun 16, 2011 | Vivitar ViviCam 3785 Digital Camera
Ive got a vivital vivicam 5100, and i have a 4gb sd memory card that will fit this camera. i know that the memory card has to be formatted in order for it to work but i cant work out how to format...
If your camera can indeed use a 4GB card (your manual will tell you if it can), to format it, simply go into the menu and find "format"and follow the on-screen instructions.
Nov 03, 2010 | Vivitar VIVICAM 5188 PINK BNIB Digital...
Can a 4gb memory card be used in a vivicam 6324 and if so how do i formatt it it keeps saying memory full?
If it's actually a 4GB SD card and not an SDHC card then it can be used. However, the SD specifications actually only go to 2GB, so almost all cards larger than that are SDHC cards. While SDHC cards will fit into SD slots, they are electronically incompatible and will not work.
Given that the camera isn't formatting it, I'd say that the card is an SDHC card. I suggest using SD cards 2GB and smaller.
Oct 11, 2010 | Vivitar ViviCam 8018 Digital Camera
How do I format an SD card for a Vivicam 3785?
You can format the SD card in your ViviCam 3785.
This utility formats the internal memory (or memory card) and erases all stored images and data. Make sure your SD card is in the unlocked position.
2. Press the MODE button twice to enter Playback mode. Then press
3. Select [Delete] by using the up/down arrow buttons, and press the OK button.
4. Select [Format ] by using the up/down arrow buttons, and press the OK button.
[OK] by pressing up/down arrow buttons, then press the OK button to confirm.
has been formatted.
If you need a manual for your camera you can download a free PDF at
http://www.retrevo.com/support/Vivitar-3785-Digital-Cameras-manual/id/200ag818/t/2/
Please rate this solution. Thanks.
Jan 15, 2010 | Vivitar ViviCam 3785 Digital Camera
I have a 2GB SD Memory card thats won't format and says its full
per manual... camera supports UP TO 256MB... your camera can't recognize a 2gb card.
Mar 08, 2009 | Vivitar ViviCam 3705 Digital Camera
Samsung s830 SDHC Problem?? Camera Dies!!
emm... I have got an 2 gb SD memorycard for mine to and it wont work. Read on several places that the camera can only handle 1 gb memory card... Dont know if that's true thou.
Feb 16, 2009 | Samsung S830 Digital Camera
Cant format memory card for vivitar vivicam 5188
I cannot format the sd card. The camera stays in the busy mode.
Dec 09, 2008 | Vivitar VIVICAM 5188 PINK BNIB Digital...
Size of sd card
Hey there harad82, many digital cameras have difficulty formatting and thus difficulty recognising larger size memory cards. This limitation is due to the date of design of the camera, and the only recent availability of the larger memory cards. Also the processor power onboard many cameras is quite limited and cannot handle too much information, such as when one of these cards begins to fill. This can result in lost data. I would suggest you try one before purchasing, perhaps a friend can help with a loner or you can check your cameras specs for limitations on card size. The smaller size cards (512mb or less) rarely cause these difficulties. If you need help with specs please respond with your camera make and model#. Good Luck!
Feb 25, 2008 | Vivitar ViviCam 5299 Digital Camera
Vivitar VIVICAM 5188 PINK BNIB Digital Camera Logo
108 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
